1. ADVRIDER Print Magazine!
    We're doing two more print magazines year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
We are gone, another trip over a long distance (going RTW, back home for now)
Discussion in 'Ride Reports - Epic Rides' started by Thomas B., Apr 24, 2016.
  1. squadraquota
    squadraquota mostly harmless
    Oct 23, 2007
    872
    Lowlands
    Well, it probably is extremely dangerous… for the mental health and well being of those that invent such silly rules! :loco
    After what you have seen and experienced on your travels, it must be a bit challenging to adapt again to the solutions we in the western world have conceived for such major problems :hmmmmm
    CruzCtrl, Thomas B. and Bt10 like this.
  2. XR Valdeez
    XR Valdeez Long timer Supporter
    Jul 7, 2009
    1,012
    So. Cal
    WOW!
    Glad you two are safely home! What a ride, to say the least!
    It was an absolute pleasure to meet you and share the road with you! I'm glad we had some good times and rode through some of the prettiest country Patagonia had to offer.
    Take your time getting re-accustomed to being home. I'm sure it will take a bit since you were gone for so long.
    Ride safe and ride far!
    Steve
    Thomas B. likes this.
  3. skibum69
    skibum69 slave to gravity Super Supporter
    May 14, 2006
    15,095
    New Melbourne, Newfoundland
    One day the motor will be back in my 640.
  4. RICK IN BALI
    RICK IN BALI Adventurer
    Jul 1, 2017
    48
    Truly some fantastic scenery down there. Safe travels
  5. RICK IN BALI
    Jul 1, 2017
    48
    TRY COCA COLA, IT ROTS EVERYTHING ELSE !!!
  6. Thomas B.
    Thomas B. desert racer
    Feb 15, 2010
    1,267
    Switzerland and around the globe
    Was busy again and all bikes are getting close to being street legal again. Subframes are changed, repaired shock is back in Sandras bike, and the bikes are running again. (and the BMWgot a new Batterie as the old one was weak after Standing around for 3 years).
    Here is what we look like today
    my bike before Transformation
    the rear is off after some Hours of work
    and done
    Ready to ride again
    CruzCtrl, scudo, NSFW and 19 others like this.
  7. Thomas B.
    Feb 15, 2010
    1,267
    After the bikes I was busy cleaning and storing all the Things we had with us. Especially the bags and the tent needed a good scrub to be halfway clean again.
    I looked at my maintenance charts I keep for every bike I own and thought some numbers might be interesting for some of you inmates. They are not complete I guess, but give you an idea about how the bikes performed and what I had to do to keep them running over the last 3 years.
    Before our departure I took the bikes apart (there is a rebuild thread in the thumper section) completely (frame and engine), gave them a good check, replaced what was necessary, and brought them into a good shape as they were not new – 15 years old and 60000 km of partly hard life. We did ca. 90000 km on the KTMs during this trip and had following problems, repairs, things to take care of:
    · 1 crankshaft bearing went bad, took the engine apart and replaced it (that was the one major issue)
    · Front wheel bearings on both bikes and rear wheel bearing on one bike went bad, replaced (that was after all the water in Russia)
    · 1 ignition coil went bad, replaced it
    · 1 fan stopped working, replaced it
    · 1 leaking fork leg, replaced seal (I rebuild both forks after 42000 km)
    · 6 flat tires (not bad for 90000 km with 2 bikes -180000 km and thousands of km of dirt)
    · 1 chain guard replaced on each bike
    · 1 bearing in the linkage of the suspension on each bike was going bad so I replaced them
    · 2 rear and 1 front brake disc replaced on each bike
    · 2 front and 2 rear brake pads on each bike
    · 3 chains and sprockets per bike
    · 4 front and 5 rear tires per bike
    · 15 oil-changes (I change the filters every second time)
    · A couple of air filter cleans
    · Some small electrical problems that I fixed
    · And one shock just started leaking on last couple of hundreds of km before home, but made it without losing all its oil
    · Apart from that - normal maintenance
    I probably forgot some things, but that was most of it and it gives you an idea what work I had to do during those 90000 km.
    The BMW we bought and sold to ride the lower 48 in winter ran over 27000 km troublefree apart from oil and tire changes and valve adjustment.
    CruzCtrl, scudo, Dusty Rider and 17 others like this.
  8. DunkingBird
    DunkingBird Been here awhile Supporter
    Aug 20, 2016
    493
    Switzerland, Bern
    :lift:thumb
    Dirk S. likes this.
  9. joenuclear
    joenuclear Still here....
    Mar 16, 2007
    10,276
    Fort Smith, Arkansas
    Wow! 2 air filter cleanings? You must have kept a large distance between bikes.
  10. XR Valdeez
    Jul 7, 2009
    1,012
    So. Cal
    Good write up Thomas! Not bad at all given the terrain and time you two spent on the road.
  11. fastring
    fastring Been here awhile
    Aug 5, 2012
    710
    Monroe, GA
    Thanks for sharing the maintenance log, that is interesting data!
    Thanks for sharing your travels, I enjoyed the read!
  12. Normlas
    Normlas Been here awhile
    Jun 24, 2011
    559
    New Zealand - JAFA
    Hi Thomas and Sandra, congrats on a great trip and a safe return home. It was lovely to meet you guys and hang out, next time we'll have to do some serious riding together!
    I've been home a month now and still haven't really adjusted to it at all - feeling very restless! It will be interesting to see how you guys adjust to life back home.
    Best wishes!
  13. Thomas B.
    Feb 15, 2010
    1,267
    A couple doesn´t mean 2!
    I surely cleaned the Filters more than twice, but not too often as I hate doing it. I do use the Twin air filter oil and I think it is very good because even if the filter is very dirty there is not the smallest grain of dirt after the filter.
    The filter on Sandra´s bike is Always dirtier than mine that is because she Always rides behind me (although she does Keep her distance when it is dusty) and her bike is lower than mine so Closer to the Ground (might be another reason).
    but definitly more than twice:D
    scudo, Yannick and joenuclear like this.
  14. Thomas B.
    Feb 15, 2010
    1,267
    Hey Arjan,
    setteled in quite well at home . Had a lot to do on the bikes getting them Ready for Inspection which is next Monday. All 3 bikes iin one day.
    Apart from that I am thinking About new travels allready and trying to do some short trips around here. Did a ride to Italy to meet Ed (flyingdutchman177) and relax at one of the lakes in the moutains.
    Take care and say hi to Lisa from us
    Cheers Thomas
    Normlas and roadcapDen like this.
  15. SDR82
    SDR82 Adventurer
    May 16, 2016
    60
    NL
    Hi Thomas and Sandra, i've found your report through Ed's european Edventure, I see i have some catching up to do here as i'm only at page 3 yet.
  16. Thomas B.
    Feb 15, 2010
    1,267
    You got a Long way to go in that case :1drink
    SDR82 likes this.
  17. creambulgaria
    creambulgaria n00b
    Aug 10, 2010
    1
    Bulgaria
    Excellent RR.
    roadcapDen and Thomas B. like this.
  18. bwear
    bwear n00b
    Oct 2, 2019
    6
    NM
    Thanks for the RR! I came late, but really enjoyed it! Keep it up!
  19. SirLancelot
    SirLancelot Adventurer
    Jan 12, 2019
    48
    Antwerp - Belgium
    Thanks so much for this wonderful RR - kept me highly entertained during quite a few hours. Your great pictures confirm nature is still the best show on Earth!
    Looking forward to your next trip report.
    Thanks again Thomas & Sandra for sharing this epic journey with us!
    Peter640 likes this.
  20. Thomas B.
    Feb 15, 2010
    1,267
    Glad you liked it.
    well the next trip is Always in planning (actually there are Always several ideas), but unfortunatly life got a hold of me and I cann't leave in the near future.
    We are working on it though.
