we better have a 790 thread, i 'spose
Discussion in 'New Zealand' started by wairau, Apr 20, 2019.
  1. MrKiwi
    MrKiwi backwards & upsidedown Super Supporter
    Oct 16, 2009
    13,437
    New Zealand
    inquiring minds need to be satisfied
    Mc107 and Night Falcon like this.
  2. Oscar
    Oscar Master of the Universe! Supporter
    Apr 10, 2002
    20,089
    Karakariki, New Zealand
    KiwiPewe, dazzadm and MrKiwi like this.
  3. wairau
    wairau get in behind!
    Mar 29, 2011
    3,464
    urenui, taranaki
    if you ever get sick of that red one sing out
  4. Oscar
    Apr 10, 2002
    20,089
    That CL450 arrived a few weeks ago, and I have to say it's nearly as much fun as the RD.
    I had no idea they went like that...
    Muzz67 likes this.
  5. dazzadm
    dazzadm Long timer
    Jun 7, 2014
    1,395
    Gumboot Capital, NZ
    Oooohhh, it does exist. No ride photos? Or is it too shiny:-)
  6. Ohuraboy
    Ohuraboy Adventurer
    Sep 28, 2019
    14
    Auckland
    Hey guys, lve not had tubeless rubber before so how low can the rear tyre pressure go before it slips on the rim?
  7. Oscar
    Apr 10, 2002
    20,089
    We were up the 42nd last month and I had to ask myself the same question.
    I had Bridgestone AX41's on, and I wouldn't go lower than 25psi....
  8. wairau
    Mar 29, 2011
    3,464
    urenui, taranaki
    i’ve not had to reseat a bead with the little pump i carry, so i cant say whether it could or not. might try that next tyre change.
  9. Oscar
    Apr 10, 2002
    20,089
    Spray deodorant and a match....
  10. innathyzit
    innathyzit AKA Woodman
    Dec 30, 2008
    2,426
    Nelson NZ
    Did a dustybutt on my r100gs at 15psi front and rear . Tyre may have slipped on the rim, dunno. Was fine, in fact a revelation.
    Takataka likes this.
  11. MrKiwi
    Oct 16, 2009
    13,437
    New Zealand
    I normally don't go under 22 psi
  12. Ohuraboy
    Ohuraboy Adventurer
    Sep 28, 2019
    14
    Auckland
    Excuse the newbie, probably the wrong forum but a couple of Jaffas on very shinney new bike are looking to head out of Auckland tomorrow (Sunday 20th) for a ride to maybe Raglan or that way in general if there is anyone heading that way it might be good to tag along.
  13. Night Falcon
    Night Falcon Broke Engine Supporter
    Dec 25, 2008
    8,363
    New Zealand
    Look what's being officially released by team orange at Eicma this year :raabia
    KTM 390 Adventure
    Cost estimated to be arround $8K USD
    KTM 390 Adventure Specifications
    ENGINE
    Type Single cylinder, four-stroke
    capacity 373.2 cc
    Bore x stroke 89mm x 60mm
    power 44 hp at 9,000 rpm
    torque 37 Nm at 7,000 rpm
    compression 12.6: 1
    Fuel system Bosch EFI (throttle 38 mm)
    transmission 6-speed
    CHASSIS AND BRAKES
    frame Steel grid pipe, powder coated
    rear frame Steel grid pipe, powder coated
    Chassis Front WP APEX Ø 43 mm, adjustable in tension and compression
    Spring travel front 170 mm
    Rear suspension WP APEX shock absorber, adjustable in rebound and preload
    Rear travel 177 mm
    Rake 63.5 °
    trailing 98 mm
    Brake front Single piston, radially mounted
    Brake disc front Ø 320 mm
    Rear brake Double piston, floating
    Rear brakedisc Ø 230 mm
    SECTION Bosch 9.1 MP two-channel, curve ABS
    Tire dimensions front 100 / 90-19
    Tire dimensions rear 130 / 80-17
    DIMENSIONS AND WEIGHT
    wheelbase 1,430 mm
    seat height 855 mm
    ground clearance 200 mm
    tank capacity 14.5 liters (3.5 liters reserve)
    dry weight 158 kilograms
    Wonder if we'll see an R version :scratch
    KiwiPewe likes this.
  14. MrKiwi
    Oct 16, 2009
    13,437
    New Zealand
  15. Night Falcon
    Dec 25, 2008
    8,363
    New Zealand
    The global ADVbike market must be substantial I reckon, I can't think of any other bike segment (or cars for that matter) with so many new models currently available and in the pipeline. There's supposed to be an 800 KTM, a new 1200 DRBig coming out in the next year or two, not to mention the T7 which should be hitting the shops latter this month or next year.
    In a couple of years there will be lots of 2nd handers for us tightwads to chose from....the tiger will probably need replacing by then :D
    MrKiwi likes this.
  16. KiwiPewe
    KiwiPewe Coddiwomple Supporter
    Oct 10, 2016
    6,650
    New Zealand
    MrKiwi likes this.
  17. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,044
    Here and There
    Yeah... Sorta looks like a sheep in wolves clothing....
    :hide
