What did you do IN your Garage today?
Discussion in 'The Garage' started by JimVonBaden, Dec 17, 2012.
  1. dmftoy1
    dmftoy1 Long timer
    Feb 16, 2012
    5,372
    Lexington, IL
    Worked on getting the fork tubes parallel on my buddies R90S, will go after last .002 tomorrow. UploadFile1568770831.900280.jpg UploadFile1568770831.880226.jpg UploadFile1568770831.853666.jpg UploadFile1568770831.827839.jpg
    skibum69 and SmittyBlackstone like this.
  2. AteamNM
    AteamNM Wonna Be ADVrider Supporter
    Mar 3, 2010
    5,200
    Sandia Mountains New Mexico
    Initiated hot water heater removal and not quite installion. 25 year old cold water line has a gate valve. Needs to be replaced with a ball valve. Also a bit of water damage restoration measures from the leaking heater. Hot water heater was working so identifying the leak took a bit of time until there was water spotted on the garage floor.
    Water turned off at the meter so no water in the house.
    SmittyBlackstone likes this.
  3. DHC-2
    DHC-2 Been here awhile
    Jan 28, 2012
    135
    Toronto, Canada
    Added one more. A GSX1250FA with only 4000 miles on it. Just finished changing all the fluids. Taking some time to get used to...keeping the VStrom though. 1568804368471.jpg
  4. JimVonBaden
    Feb 11, 2005
    90,996
    Alexandria, VA
    That is a lot of mold! :deal
    BTW, it is a water heater, not a hot water heater. No need to heat hot water! :-)
  5. broncobowsher
    broncobowsher Long timer
    Apr 21, 2010
    4,215
    Baking in AZ
    Put a catch pan under the new one. Every house in my neighborhood was built with the elevated hot water heater platform like you have, but none were built with a drain pan. Lots of destroyed drywall as they come to age. I put a drain pan under mine before it failed. There will be water on the garage floor (which is fine, I hose out my garage) but it will stay out of the house.
  6. racer1735
    racer1735 Long timer
    Dec 30, 2005
    1,372
    Amarillo/Canyon, TX
    I spent the better part of the evening disassembling my K1600GT to replace a broken left-hand heated grip. Required removing two of the tank cover panels, clipping five zip ties and figuring out which 'buttons' and 'clips' to either push or pull to release cables, wiring and the wonderwheel from the switch cluster. Got it all separated and installand the new grip. Plugged everything back in to test that things worked as they should (they did!). Then, I removed (again!) the cluster/grip to re-install the lower wiring cover. Realized I had an interference with the heater plug (extending too far out of the housing). I took things back apart, only to discover that the negative ('-') wire from the heater plug had pulled free from the wire-encased grip (and its deep enough inside that soldering isn't an option). Crap!! I reordered a grip this morning, but it will be five days or so before I get it. Live and learn.
  7. NurseBill
    NurseBill Been here awhile
    Aug 20, 2017
    900
    Central PA
    I mounted up a new tire on my KLX after spending a day skating around in dirt with a bald tire. Kind of don't like it though, awful skinny. it's also shorter than the one I took off.
  8. Laromonster
    Laromonster Lean, mean pacifist machine
    Jun 28, 2004
    2,145
    Behind you
    Mounted some fancy shmancy rearsets on a friends panigale cors received_393138404706597.jpeg
    dtysdalx2, racer1735, Mr Head and 5 others like this.
  9. Karlfitt
    Karlfitt Long timer Supporter
    Jul 30, 2013
    2,334
    Colorado
    Wow.
    Is there anything billet your friend hasn't bought??
    dmftoy1 and SmittyBlackstone like this.
  10. Laromonster
    Jun 28, 2004
    2,145
    Behind you
    He has thrown an obscene amount of money on that thing.
  11. Karlfitt
    Jul 30, 2013
    2,334
    Colorado
    I can't blame him.
    My personal affliction is carbon fiber.
    If I had the cash it would be everywhere.
    I just got a used Z4.
    The dash panel is cracked.
    I have been looking for replacements.
    There is a company that makes Carbon fiber parts for this, but I would have to replace a bunch of parts so it all matched.
    I stopped trying to count at 3500 for the parts.
  12. e rock
    e rock Been here awhile
    Nov 26, 2008
    537
    Florida
    Killed some Ratts with Poison.
  13. Lapchik
    Lapchik Tinkeritis posterboy
    Sep 5, 2012
    1,667
    Minnesota
    Did you have "nothin but a good time" chasing them "round and round"?
    trumpet, Tall Man, A_Vasiliev and 8 others like this.
  14. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,595
    Cremona, Italy
    Nice job.
    Keep an eye on the buttons, they tend to crack with age and let water in.
    That's what happened to my 500 that fried the screen. I bought a non working 400 on ebay, swapped the screen and the shell and my 500 was back on the road.
    Eventually buttons started cracking again after a couple of years.
  15. SilkMoneyLove
    SilkMoneyLove Long timer
    Nov 15, 2007
    3,139
    Minneapolis
    Teaching the basics. Changing tires. Checking air pressure.
    Trying to get the lessons in early (13) because by 16, she will know everything and Dad will be the dumbest guy on earth...gosh. :-) 20190919_182527.jpg
  16. JimVonBaden
    Feb 11, 2005
    90,996
    Alexandria, VA
    Finally assembled the Klim helmet I painted a few weeks ago, before vacation.
    Needs a little trim clean-up, but the shine is impressive!
  17. NurseBill
    Aug 20, 2017
    900
    Central PA
    Sometimes I just go out to my garage and just sit there. Anyone else?
  18. NurseBill
    Aug 20, 2017
    900
    Central PA
    Didn't Poison do "Nothin but a Good Time" or was that a Slip of the Lip?
    And when they are dead you can Dance, dance, dance!
    Tall Man likes this.
  19. DeepBarney
    DeepBarney International Bumbler
    Jan 7, 2014
    3,098
    Wichita, KS
    Yep. Just sit and stare. Sometimes I've been known to ponder when I'm feeling really contemplative.
  20. NurseBill
    Aug 20, 2017
    900
    Central PA
    It's quiet there. I have a big A/C window unit for when it's hot, furnace for cold, a TV that I never turn on.
