What did you do to your bike today thread
Discussion in 'Australia' started by dazza67, Nov 22, 2014.
  1. iconman
    iconman Good vibrations
    Feb 20, 2008
    1,147
    Denmark South West WA
    Put a few finishing touches to the 300 EXC ready for pit inspection tomorrow...
  2. UncleGra
    UncleGra Road Grime
    Jan 16, 2008
    7,131
    'neath the Southern Cross
    Yesty I was doing this...butchering a spring hook...
    ...grind a bit off here and there... drill a hole and insert a bolt and turn a cheapy spring hook spanner into a (hopefully ) workable spanner to fit this flywheel....buy the KTM tool and it'll set ya back $166.00.
    a second bolt might be needed so I can hold it steady like this..when I tighten up the flywheel nut....and yes , that is a hole in the flywheel...what happens when the starter motor eats some of the free wheel teeth...
    ....after I fit a new clutch sprag....posty is bringing it today I hope..
  3. iconman
    Feb 20, 2008
    1,147
    Got the EXC licensed today! :clap
  4. Perthite
    Perthite roo waker upper
    Jun 18, 2014
    763
    Perth WA
    shit hot! happy ring-a-ding-dinging!! :lol3
  5. neilaction
    neilaction Slightly Less Adventurous
    Jun 18, 2008
    8,769
    Perth, WA.
    :lol3 that is GOLD. :D
  6. troy safari carpente
    troy safari carpente Team f5oolery
    Nov 21, 2005
    38,145
    "Swednavia" - f5ederation of Scandwegia
    Motor oil & filter change (13 hours on the meter) 1300 ml of the good stuff + re-rear the back cog from 50 to 48 t.
  7. stujamur
    stujamur keep rollin rollin rollin
    Dec 12, 2009
    2,345
    Brisbane north side
    I spent 3 hours driving around trying to find somewhere to sell me a few m6x80mm stainless cap head bolts to tie in racks and subframe bracing. Each shop sent me to another . No one had any or they would only sell a box .
    Eventually got some only to find i wrote down the wrong size and should of been m8 . Doh !
  8. gateman
    gateman Long timer
    Apr 12, 2009
    1,963
    Norther NSW, Australia
    Dropped the coolant and fresh plugs gapped on the mig wire.
    Starts sweet as.
    All before 07:00:D
  9. Perthite
    Jun 18, 2014
    763
    Perth WA
  10. johnno950
    johnno950 Long timer
    Jul 17, 2010
    2,192
    Keep a eye out for condensation around bigend on crank,i stored a 2 stroker for a few years and before storage removed carby/reed block and filled crank well area with motor oil too cover bigend bearing.
  11. Perthite
    Jun 18, 2014
    763
    Perth WA
    cheers johnno :thumb
  12. klenoob
    klenoob Adventurer
    Nov 29, 2014
    31
    Newy/australia
    set of brand new tyres ...scorpion mt 60's ,bought a hand pump and pumped my forks up......(yawn) so tired...so much hard work...zzzzzzzzzzzzzzzz
  13. Beer'o'clock Baz
    Beer'o'clock Baz Long timer
    Feb 3, 2011
    2,347
    Flipped the Sherco today, funny enough I had a practise at it two hills prior but jumped back on, so practise doesn't make perfect
  14. Reeksy
    Reeksy high state of hiatus
    Jan 9, 2010
    1,606
    Mt Mellum
    Oh so glad to hear it's not just me who has these experiences.
  15. Reeksy
    Jan 9, 2010
    1,606
    Mt Mellum
    Repositioned my bars and all controls to see if it will reduce forearm pain. And glued some new grips on.
  16. GordyOZ
    GordyOZ Been here awhile
    Feb 10, 2013
    807
    Upper Great Southern
    epoxy repair to radiator on the Wee, checked valve clearances (no change from new) reassembled and looked at it, off to get distilled water and coolant, fill it up and test ride this arvo
  17. rsser
    rsser Riding into the sunset
    Oct 26, 2013
    525
    Terra Australis
    Fitted a Radguard this week. Good gear but the fuel line protector bolt holes had to be drilled out to get everything lined up.
    I'd knocked up some swingarm bobbins out of cap bolts and washers and they worked OK but I decided to get a couple of Evo bobbins with the Radguard order. They didn't fit; at a guess the thread is M10 coarse on the bike and fine on the bobbin bolts.
    Fitted an SW-Motech side stand extender and just about trashed it on the first ride. It drags when you're cranked over. Motorradgarage are all sniffy about it: it's never happened before and they've "sold hundreds", maybe I didn't fit it correctly, it shouldn't have happend. Derr.
  18. tripodtiger
    tripodtiger Off riding around on bitumen circles.
    Feb 16, 2006
    6,830
    looking for a smaller house & bigger shed.
    It wasn't today but I thrashed the little girl around Phillip Island GP Circuit. It was a perfect day too. Totally justified the money I spent
  19. GordyOZ
    Feb 10, 2013
    807
    large pinhole in radiator core sealed fine, the 6 super small ones that leaked as soon as I got it up to temp ruined my day, got no idea what hit it ........... packed it up and pottered round the hills for a couple of hours on the CB250 :)
  20. davorallyfan
    davorallyfan Commonist
    May 2, 2005
    18,554
    Capitalist
    Checked the air on the TR. Errol's 3D printed airbox mod is working a treat.
