What did you do to your bike today thread
Discussion in 'Australia' started by dazza67, Nov 22, 2014.
  1. hoorang
    hoorang Rather be riding than working
    Feb 16, 2015
    908
    Curlewis NSW
    If you buy a complete crank check it for true, the last wiseco crank I used had 9 thou run-out. I gave it to a local guru who tweaked it to less than a thou and it never had run so smooth.
    Put mains in regardless, gearbox bearings check by feel. If there's any doubt to the counter shaft bearing behind sprocket drop one of those in too. Lots of compressed air and brake cleaner through all of the oil galleries.
    And don't over tension the cam cap bolts.
    Check the little screen on the bottom fitting of the oil tank in the frame as they can choke up on metal from failing big end and starve the oil pump and cause head cam journals to bind.
    flinders_72, AUSSIEADV, OzCRU and 2 others like this.
  2. AUSSIEADV
    AUSSIEADV Long timer
    Sep 5, 2006
    6,998
    Ned and Wild's fight site
    Is a rod kit and sourced out crank assy viable financially in one of these Tim?
  3. hoorang
    Feb 16, 2015
    908
    Curlewis NSW
    Only if you have a crank guru you really trust. Next crank I need done will be going to RK Engineering. That guy does some really impressive repairs and rebuilds.
    OzCRU and AUSSIEADV like this.
  4. OzCRU
    OzCRU Been here awhile
    Feb 16, 2015
    584
    Sydney Australia
    Trying to source replacement parts to rebuild Mikuni BST40 carbs.
    Don't you hate it when stuff gets discontinued!
  5. flinders_72
    flinders_72 Long timer
    Apr 21, 2008
    1,798
    Murtoa, Australia
    Thanks for that. I'm considering this kit https://www.ebay.com.au/itm/YAMAHA-WR250F-WR-250F-WISECO-CRANKSHAFT-CRANK-KIT-WPC141-03-2012/232325336120?ssPageName=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
    Amazingly, the barrel, piston, rings, valves, etc look pristine but I'll go over those closely as the next job.
  6. hoorang
    Feb 16, 2015
    908
    Curlewis NSW
    That's cheap, I had an 04 model WR250F and that bike took me everywhere. It covered 16,500kms in 2.5 years and the only internal work I did was put a high comp piston at 12,000kms. Valves never moved either. Bloody good little bike.
    Replaced it with a new 07 that siezed a big end with only 2200kms on it.
    flinders_72 likes this.
  7. OzCRU
    Feb 16, 2015
    584
    Sydney Australia
    Well don’t I feel like a dufus- turns out I don’t need parts for BST40, cause it would seem I only have BST36’s - that’s what you get for trusting what you read or have been told rather than pulling something out & measuring it. Lesson learned.
  8. Toe - Cutter
    Toe - Cutter 666
    Sep 3, 2010
    542
    S/Coast nsw Planet of the apes.
    T
    Took it for a boat ride
  9. Onlock
    Onlock Adventurer
    Apr 5, 2018
    21
    Australia, melbourne
    Fitted up a new rear d606 and my new kriega us-20 tail bag ready for an adventure
  10. Scottyx
    Scottyx Been here awhile
    Aug 31, 2017
    118
    Sydney
    Cut my just arrived shelf chain so now I have a spare bit of chain for my tool kit
  11. Scottyx
    Aug 31, 2017
    118
    Sydney
    20180525_183954-756x1008.jpg when the chain on the bike wears out I'll have a cut to length one ready to go
  12. Toe - Cutter
    Toe - Cutter 666
    Sep 3, 2010
    542
    Yes
    I own an adv pig
    A big bore
    Mid bores
    And this 1 fitty. ❤️
    One advantage of the little banger ..
    422k to res
    That's 433k to 8.6 ltr !
    Nigh on 50 k to 1litre
    3.5 ltrs res 175k
    600k to 12 ltrs
    Oh and a cripple can do a valve check in 5 mins
  13. Not the Messiah
    Not the Messiah Old enough to know better, but slow learnin'
    Jan 19, 2013
    944
    Melb'n, 'Straya
    Discovered a de-laminating front tyre. At 12.20pm on Saturday when the shops all shut at midday and the sun was shining. Arrrrrgh.
    I had a half worn spare under the bench for such an occasion, so it was out with the tyre levers and get it done.
    Two hours, including time spent finding tools (it's been while, I've been paying professionals to do my dirty work).
    TKC80 Conti on 1200 GS. It had a slow leak and I suspect that I may have run it "only a couple of pounds low" for a bit too long and a bit too often. Those puffy bits around the side of the knobs are only a few mm of rubber, quite soft.
    Scary to think how close this might be to disaster.
    Greater diligence required by the operator......
    Cheers
    Brian
    Kiwirich likes this.
  14. Boxa
    Boxa 2 Smoking Barrels
    Jul 22, 2014
    309
    Adelaide Hills
  15. tHEtREV
    tHEtREV Encouragement award recipient. tEAM iDIOT.
    Apr 14, 2007
    11,211
    Middle Park, Brisbane, Australia
    I got a shitty CBR125 to replace my Spada when it got stolen and I was surprised how well it went, but you had to keep on it all the time and I found I was speeding a lot more than I ever had with any other bike, so when I got the Spada back I decided I had to get rid of the CBR because I new I would lose my license if I kept riding it.:lol3
    Mickalmus and flinders_72 like this.
  16. Just Dan
    Just Dan Bugger, Burnt toast
    Jun 7, 2006
    2,611
    Hobart, Tasmania
    Absolutely, I am finding I am speeding a lot. Mainly in the 50 - 60 kph zones. I am always traveling about 20 kph over on the 125.
    The overseas reports reckon it does 50kph in first gear. I find that hard to believe. I gunna have to give it ago.
  17. Mickalmus
    Mickalmus Long timer
    Mar 3, 2014
    1,626
    Queensland, Australia
    Stuck it back on the battery charger.
    Gave it a new MT60 back tyre to match the front. The chain got a half a clean with WD40 and a rag to get rid of the excess blackjack.
    All ready for a ride to bunno's for a snag.
  18. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    10,898
    GodSowncountry Australia
    Yesterday to be accurate. Took Ratty for a spin to check the "new" brake/tailight stays in the bike (tick), test drove a new-to-me jacket (tick), grabbed the newspapers (tick) and just had a really nice ride eh (tick).
    Ordered a new front disk from fleabay too.
    Kiwirich and braaap! like this.
  19. BOOTLACE
    BOOTLACE Bikie Scum.
    Dec 24, 2005
    8,929
    Methane Central..(Sth Gippsland)
    Delivered Heidi to her new home
    Bloody!
    At least it's a good home...
  20. Scottyx
    Aug 31, 2017
    118
    Sydney
    Nice bike. Is it too soon to ask "do you miss it"
    I checked the capacity of my beverage bag. 14 with room for ice 20180527_165015-1008x756.jpg
    UncleGra likes this.
