What Did You Do To Your KTM Today?
Discussion in 'Dakar champion (950/990)' started by DeeGee, Apr 12, 2010.
  1. Spyrious
    Spyrious Want to go offroad
    Oct 9, 2016
    223
    Greece
    I'm looking at them myself for some years, but they are too expensive for me.
    outbacktm, Mr Head and Peltsi like this.
  2. Mr Head
    Mr Head Adventure Hippie Supporter
    Sep 21, 2003
    15,386
    San Clemente, CA
    Yes, expensive, but reading a couple of stories where guys broke their OEM connectors out in the back of beyond. I'd had one rock hit and ding the knob on one side. Decided that would be the warning.
  3. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,206
    North of North Plains
    So with those Powercell fuel connectors...does an additional pair need to be bought in order to drain the fuel tanks? Because they don’t let any fuel go through them when they are uncoupled, right?
    Dusty likes this.
  4. Mr Head
    Sep 21, 2003
    15,386
    San Clemente, CA
    There is a connector with a piece of line available for purchase. The short answer, yes.
  5. Whodatschrome
    May 4, 2015
    3,206
    I didn’t see it on his website. I was kinda hopping for a “buy 3, get half of one free” sort of thing.
  6. Mr Head
    Sep 21, 2003
    15,386
    San Clemente, CA
    QD Thingy Link
    Whodatschrome and Dusty like this.
  7. Whodatschrome
    May 4, 2015
    3,206
    Masso75, majle, albani and 4 others like this.
  8. GenesiZ
    GenesiZ Adventurer
    Oct 20, 2013
    38
    Netherlands, Apeldoorn
    That's a clean bike!
    Whodatschrome and Jeff Sichoe like this.
  9. juames
    juames Have Fun, Don't Die!
    Aug 16, 2008
    3,196
    Ottawa
    Super clean! Also I noticed that your footpeg and sidestand are missing, and what is the little loop bolted to your passenger footpeg mount? :ear
    keener and Whodatschrome like this.
  10. Spyrious
    Oct 9, 2016
    223
    Greece
    The loop is probably to hold the side stand in place.
    Whodatschrome and juames like this.
  11. juames
    Aug 16, 2008
    3,196
    Ottawa
    Wonder if it would work for the center stand? Mine bounces in the rough stuff.
    Whodatschrome and Spyrious like this.
  12. Spyrious
    Oct 9, 2016
    223
    Greece
    Why not.Try it out.I may look in to it myself now that you mentioned it.
    Whodatschrome likes this.
  13. Whodatschrome
    May 4, 2015
    3,206
    Yes, it will work for the centerstand or sidestand, but not both at the same time.
  14. Crazygreek
    Crazygreek Adventurer
    May 28, 2015
    71
    Greece
    20191115_171547.jpg 20191115_154604.jpg Christmas gifts!
    Manny U, majle, Mane and 5 others like this.
  15. GenesiZ
    GenesiZ Adventurer
    Oct 20, 2013
    38
    Yesterday I let the 990 sleep (5 times, it was a tough track)
    Today I'm changing the airbox to foamfilter and ditching the SAS.
    Manny U, Koen, majle and 6 others like this.
  16. Whodatschrome
    May 4, 2015
    3,206
    If you look closer, you can see a large tab that’s welded next to the footpeg bracket. That’s for the EXC kickstand conversion that I’m in the process doing. I removed both the sidstand and footpeg so that I could weld in the bracket. My ultimate goal is to use both the OEM center and sidestand for everyday use. For racing I’ll remove both of them, then install a Pro Moto Billet kickstand. The stock side stand hangs down too low for me and it gets smashed on rocks. I’ve also lost the return spring twice so far.
  17. veetwo _tls
    veetwo _tls RENOVATIO:
    Nov 14, 2005
    2,716
    THE MALLEE OUT BUSH IN Sth Oz
    finally pulled my finger out my ass got a start with the 450RFR tower / lights & fairings (to be trimmed to mate to the PCP tank) all to go on my 07 950SER
    Very top tower will be warning lights -
    Neutral
    Low oil pressure light/buzzer
    High Beam Light
    Main power toggle switch (can remove main power fuse if need be for better security)
    Each side the Rally Max G be 2 x toggles to isolate individual power via PDM60
    Lights - PDM60 only
    Trailtech Voyager via PDM60 & toggle
    Trailtech Voyager pro via PDM60 & toggle
    Garmin Zumo 660 via PDM60 & toggle
    F2R / ICO Power Modual via PDM60 & toggle
    Nav Tower will be setup for following swappable options
    Left digital speedo remove put ICO there instead
    F2R Paper roadbook option
    Garmin Zumo 660 option
    Trailtech Voyager Pro option
    better get back to it
  18. GenesiZ
    GenesiZ Adventurer
    Oct 20, 2013
    38
    That's going to look good! Is it a lot cheaper than a Aurora-kit for the 9X0?
  19. veetwo _tls
    Nov 14, 2005
    2,716
    don't think Aurora do a kit for the 950 Super Enduro ? unless buy a 2019/20 450RFR kit (new style fairing screen) do as i'm doing
    It would save trimming white plastic side fairings as i have to do with the 2017-18 450RFR & how i'm going to mount the side fairings ;)
    I'm using Jon's KIT690 450RFR tower kit as i have one already have a KIT690RFR & know the build quality of his.
  20. veetwo _tls
    Nov 14, 2005
    2,716
    Main Power
    4 pin DPST toggles each side
    TT Voyager & Garmin Zumo 660 or (TT Voyager Pro when in use)
    F2R & Garmin Rino 650 / 750 UHF/GPS
    setup for the Garmin Zumo 660 (all holes pre drilled for the F2R roadbook & ram mount for the TT Voyager Pro)
