1. eNewsletter Sign Up
What Did You Do To Your KTM Today?
Discussion in 'Dakar champion (950/990)' started by DeeGee, Apr 12, 2010.
  1. Kona990
    Kona990 Been here awhile
    Nov 3, 2015
    323
    BC
    Tired of my gauges fogging up, time to dry them up and seal them up tight. 20200215_144919.jpg
  2. Cowtowner
    Cowtowner Been here awhile Supporter
    Dec 21, 2010
    582
    Calgary
    Made up a little harness to hook up a four way flasher on an '07 990 - used the stock plugs so that I didn't need to cut into the OEM wiring harness (thanks www.cycleterminal.com) and used a two way trailtech switch that a local moto dealer was selling cheap on ebay - position 1 for the existing aux lights, position 2 for the new hazards, and the kill switch to cycle through the modes on the speedo.
    Now just waiting on a couple Bosch 17025 O2 sensors to refresh to the Dynojet autotune O2 sensors - bought a couple on amazon but when they showed up last night it didn't look like it was the real McCoy so returnin 'em and project delayed. No matter - it's ski season in Cowtown!
    An inmate has spoken for the 2 into 1 Rottweiler full stainless steel exhaust that I'm replacing - I'm gonna miss that, the stainless steel headers are so much higher quality than the KTM 990 headers, but anyway, I'm switching back to 2 into 2 and Rottweiller doesn't build 2 into 2 headers anymore (or the 2 into 1 headers for that matter).
    Here's the trail tech switch and the little flasher hook up:
    Spyrious likes this.
  3. ferdinotch
    ferdinotch Adventurer
    Jan 6, 2020
    33
    South west of france
    Took 2hours to get this shit out of the bike.
    It s a .30, I'll upgrade to .50
    Spyrious and Whodatschrome like this.
  4. skuikka
    skuikka Been here awhile
    Jun 23, 2009
    221
    Finland
    Stared at this, thinking of a best solution to get more bottoming resistance.
    opanos likes this.
  5. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,120
    North of North Plains
    I also did a four way flasher conversion on my '06 950A a while back (ended up doing it on my 640A first). What i did was install a single jumper wire between the two front turn signal lights. I then installed a push button on/off switch (HDB stuff) that opens and closes the circuit. So in order to activate the 4-way, i have to flick the ktm turn signal rocker switch on (either to the left or right), then activate the push button switch. It then feeds power to all four lights. Not as convenient as an actual Hazzard switch, but SUPER basic with minimal wiring.
    Stephen, mountaincadre and Mr Head like this.
  6. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,536
    Here and There
    Any chance of a circuit diagram @Whodatschrome :deal
  7. Whodatschrome
    May 4, 2015
    3,120
    Super simple...
    Tee off a wire from the 12V+ input side of both front turn signals, and then connect them to your favorite on/off switch. The stock turn signal switch still activates each side independently (normally), until you flip the newly wired in switch ON. I happened to use a spare switch that I got from HDB. It’s the red one mounted above the speedo on the dash. When it’s ON, it bridges both the left and right side turn signals. I still run the standard incandescent bulbs. I haven’t had any issues with it yet. I suppose if I do, I can flip on my hazards...
    9B04DB00-9C34-4A83-8E8E-3410D1274FD4.jpeg 92D64924-D8D7-402C-9F2E-EA47499DC4D9.jpeg
    MadM and Spyrious like this.
  8. Commiehunter
    Commiehunter Been here awhile
    Aug 20, 2017
    648
    How do the crayon lines fit in?
    Also, I put my injectors back in without removing the throttle bodies. Those little metal puzzles finally paid off.
  9. albani
    albani Been here awhile
    Jan 3, 2017
    201
    SF Bay
    To indicate the factory magic goin on ;)
    Valves adjusted and goin back together. the 'o-ring' that seals the coolant pump cover to the sidecover is leaking pissing its nice Toyota long life coolant allover my shop. Here goes another week waiting on dumb shit that I should have known better and ordered. Winged a buncha other incidentals in with the order, why not. Busy as all shit this week with other stuff anyway so it kinda works out. In a month or so though, this sucker better be ready for some Johnson Valley. I did prime the oil system without plugs, it's an order of magnitude quieter with some oil pressure, small victory there.
    (also reused the old gasket which cracked right at the cooling pump jacket to outside, causing the first leak)
    i should know better.
    Crazygreek, gremlyn, braaap! and 2 others like this.
  10. Whodatschrome
    May 4, 2015
    3,120
    I didn't want the mod to be too simple, so i added those extra crayon lines to add confusion. It looks like my plan is working!
  11. braaap!
    Mar 16, 2005
    4,536
    Here and There
    Cheers! that's very helpful! I have some of the HDB switches in stock too :)
    Sorry, another question. The sano tripmaster(?) switch block on LHS? Who, where, linky?
    Thanks again!
  12. Whodatschrome
    May 4, 2015
    3,120
    It's a Trail Tech "Striker remote switch" that i wired in as the Tripmaster. Like all things cool that Trail Tech made at one point, that switch is now also no longer available anymore. TT got bought out about 5-6(?) years ago. I used to be able to drive over there and just buy stuff off the shelf from them. Not anymore. Their policy changed with the new owners. Along with dropping LOTS of their product line. They used to sell a very affordable dual sport halogen headlight mask kit, some super slick illuminated TTO adjustable temp/volt gauges, terminal connector kits, ect. They have gotten rid of about 2/3rds of the products that they used to sell. The term "streamlining" was used multiple times in phone conversations that i've had with them. That switch retailed for only $25 too!
    braaap! likes this.
  13. Rharr
    Rharr Been here awhile
    Apr 5, 2014
    915
    Tucson Az
  14. skuikka
    Jun 23, 2009
    221
    Finland
    I want to keep the progression, just steepen the curve. I'm thinking of something like a backing shim underneath the PDS-piston comp stack to limit the maximum opening of the stack. Maybe, still thinking.
    Edit: Now that I look at these, I get the impression these are sort of rough "PDS emulators" for non-PDS shocks?
  15. veetwo _tls
    veetwo _tls RENOVATIO:
    Nov 14, 2005
    2,709
    THE MALLEE OUT BUSH IN Sth Oz
  16. bobone
    bobone Been here awhile
    Jul 7, 2016
    259
    italy
    LOVE IT!
  17. Rharr
    Apr 5, 2014
    915
    Tucson Az
    I don't think the hucks are for non PDS shocks, only reason i say that is there is a youtube video of Slaven talking about installing them on his KTM.
    Unfortunately there seems to be more info on the fork side of the hucks then the shock side. I have talked to a few folks with them and they love them, claim they can just slam there bike through stuff and just keep going, granted i have only heard about them being installed on thumper stuff not big bikes, but I am pretty sure the 9x0 shock is really not much different internally to the ktm thumper shocks.
  18. bobone
    Jul 7, 2016
    259
    italy
    i changed the chain and sprokets. poor chain. it was long overdue. 25000km of mud and sand and rocks and not much cleaning.
    Whodatschrome likes this.
  19. skuikka
    Jun 23, 2009
    221
    Finland
    I did some researching, it still appears to emulate the PDS. I'd say it sits somewhere between the Touratech bump stop and the Real PDS and is the only on that is reasonably easy to retrofit. The PDS has the needle to control the transfer between the pistons and it can be re-valved. The TT-bump stop is just a hydrostop. The Huck has shims but the transition is propably a bit rougher, alltough, I'd imagine the cup cuold be machined so that it "leaks" a bit more when the Huck piston enters.
    I like the idea and would possibly try it on a conventional shock but I have the PDS shock from 950Adv on my SE, so I'll fiddle something with the valving. For stock SE shock, this could be something worth looking in to.
  20. Mr Head
    Mr Head Adventure Hippie Supporter
    Sep 21, 2003
    15,042
    San Clemente, CA
