What Did Your Evil Twin Do Today?!?
Discussion in 'Parallel Universe' started by Motorfiets, Nov 14, 2012.
  1. dpike
    dpike BeeKeeper Supporter
    Nov 21, 2015
    1,770
    New Jersey
    Brady over at Storm Industries made a pair of crash bar bags for my Holan Pros.
    beautiful fit, this mans a genius, i can't recommend him more for any custom bags that need to be made.
  2. Nelso
    Nelso All the gear-no idea
    May 20, 2014
    530
    QLD Straya
    Added a Fuzeblock to get some switched power capability. Do you know how long it takes to install one of them when you tap the wrong f#$%ing wire??:baldy
  3. Sjones423
    Sjones423 Been here awhile
    Oct 31, 2015
    118
    Liverpool
    Been down to Devils Mouth, north Wales
    amecr1200gs likes this.
  4. Nickhob
    Nickhob Armchair adventurer
    Nov 7, 2013
    1,502
    Nyon, Switzerland
    I changed my front and back tires (to Karoo 3's) , tubes and wheel bearings. Bearings after 20k km's looked brand new on the front but there was the beginning of rust on one of the rears and definitely water mixed in to the grease. I always repack the bearings with a sh-t load more grease before installing.
    Also changed my front and rear sprockets (Keeping the front a 15T) and replaced the chain.
    Steering head bearings, fork oil, coolant, brake fluid was done last month.
    I'm convinced that regular preventative maintenance keeps my bike from having any real issues.
    So now I'm ready for a nice 8 days moto trip through Austria / Italy / Slovenia / Bosnia / Croatia and then back home to Switzerland in a few weeks time and then the Stella Alpina at the beginning of July. :clap:clap
    amecr1200gs and vasuvius like this.
  5. dpike
    Nov 21, 2015
    1,770
    New Jersey
    the simplest 15 minutes i spent doing anything to this bike
    progrip 714
    contrary to what i've read you do not need two sets to do this the 22mm fits fine on the left grip.
    break the glue bonds on either end, carefully slice the old grip off, heat the new grip in hot water, use a little aquanet hairspray lube on the bar, generously spray the inside of the new grip and slide on.
  6. Mongo357
    Mongo357 Been here awhile
    Dec 13, 2008
    221
    High Plains of NV
    My girl got some new grips too! Guess I can skip the how-to and just flash a pic.
    I'm one of the guys that hates the skinny grips. I used the grip puppies for years but now I thought I would try something different. These ProGrips have a "palm hump" and finger grooves. I'm hoping it will give the fat feeling along with more control in the rough off-road sections.
    morfic likes this.
  7. Lensgrinder
    Lensgrinder Long timer
    Aug 8, 2007
    1,532
    San Marcos, California
    Replaced brake bleed fittings with speed bleeders, made the job much easier.
    For any one interested part # is: SB 1010S for these bikes. Front and rear are the same.
    dpike likes this.
  8. Timinator999
    Timinator999 Adventurer
    Sep 4, 2016
    45
    Alberta, Canada
    Added a combination USB charger/voltmeter mounted to the windscreen support brace using p-clamps and 3 mm aluminum plate. Wired to the aux. socket under the "tank" cover.
    Also added a garage door opener by securing a compatible key fob style opener from the local hardware store under the "tank" cover with Velcro and wired in a waterproof button across the existing button.
    Drilled a hole opposite the Aux. power outlet for the push button. [​IMG]
    No more fishing around in my pocket to open the garage door.
    G-Mac, Met n GS and vasuvius like this.
  9. ForestFrog01
    ForestFrog01 n00b
    Oct 26, 2016
    2
    Moose Racing Windscreen +4inch
    Sent from my SM-G950W using Tapatalk
  10. dpike
    Nov 21, 2015
    1,770
    New Jersey
    new lipstick on the f700
    Discoblue likes this.
  11. G-Mac
    G-Mac Been here awhile
    Nov 26, 2007
    739
    Peterborough Ontario Canada
    Alright you've had enough time. Now what's the review on the new grips. I was looking at them too.
    Sent from my SM-N900W8 using Tapatalk
  12. Mongo357
    Dec 13, 2008
    221
    High Plains of NV
    I love them!! Very comfy, and I think they improve control. I don't have to choke-hold the throttle. So I think they help lesson fatigue, too.
    Here is a shot from my current trip. Guess the AquaNet was strong enough!! They started to spin on me.
    G-Mac likes this.
  13. Roostboy101
    Roostboy101 Narry Uvencherer
    Feb 15, 2009
    168
    Amish Country
    Started fabbing up my "skid" plate. I'm realistic in the fact that I don't jump logs so spending 2-300 bucks for a hunk of aluminum is dumb to me.
    To powder coat or rattle can
    Tewster2 likes this.
  14. dpike
    Nov 21, 2015
    1,770
    New Jersey
    f7 side plastics done.
    i asked her if she wanted me to break up the yellow a little bit and split it with some black, her answer "that's the best color bmw ever had, why would i want you to do that" :raabia
    f700gs badge stickers.. $100 each for oem :hair... i'll find some aftermarkets
    somewhere.
    if anyone is interested ColorRite has some quality spray cans in oem colors. amazingly fast shipping as well.
    vasuvius likes this.
  15. Pilotuh1b
    Pilotuh1b Been here awhile
    Apr 13, 2014
    295
    ACT
    Mt Coree in Namadgi National Park.
    Mongo357 likes this.
  16. Nelso
    May 20, 2014
    530
    QLD Straya
    OEM acrylic headlight guard started cracking around the bolts...
    ...so replaced it with a polycarbonate one...
  17. Steel_Cowboy
    Steel_Cowboy back in the saddle....homeward bound
    Jul 15, 2006
    943
    Northern Colorado
    Can you provide the contact information for Brady at Storm Industries? Thank you.
  18. dpike
    Nov 21, 2015
    1,770
    New Jersey
    Steel_Cowboy likes this.
  19. AntReed
    AntReed Been here awhile
    Nov 17, 2014
    290
    Kent, UK
    If this has been built to take some hits off-road then I feel like the bolts sticking out as they do might get you into a bit of trouble! Try sliding that thing over a log or even just bottoming it out might rip it off and in the process do more damage than it was designed to stop!!
  20. mss1958
    mss1958 Adventurer Supporter
    Nov 5, 2016
    24
    20170705_151146.jpg 20170219_104313.jpg A $300 skid plate didn't protect the oil pan. TIG welded the three cracks and good to go. Talking with Skunkwerks Moto Fab about another skid plate that mounts differently. 20170703_162207.jpg 20170703_135026.jpg
    shuswap1 likes this.
