What do I do with this damn chain?
Discussion in 'The Garage' started by mysticbus, Jul 10, 2018.
  1. mysticbus
    mysticbus Mysticbus
    Mar 17, 2010
    909
    Daytona Beach, FL
    So I have had well over a hundred bikes in my 45 years of riding. When I was young they all had chains, and I did jack squat, I just rode the piss out of all of them.
    I got into BMW's around 28 years ago, and haven't had a chain since, so I have gotten quite good at final drive repairs and maintenance.
    I just recently bought my very first brand new motorcycle. A 2018 Africa Twin Adventure Sport DCT. And it has a chain.
    I have about 200 miles on it now, and it is about 10 days old.
    I have no idea what to do with this chain. Hard to believe something so basic has completely escaped me.
    How often should I clean and lube it... what should I use?
  2. Bovino
    Bovino Been here awhile
    May 11, 2013
    540
    Spain
    Clean and lube as necessary. Look at it now - that's how it could look all the time. That's it.
    Slack as stated in manual, or the good old two fingers up and down.
    I don't do rain or dirt on my road bike, so one clean after 5k kms is enough. No rule if yer offroading the thing. Water crossings, sand etc. all come into play.
  3. Sleepyc
    Sleepyc I have a Moto Boner!
    Apr 24, 2017
    1,081
    Cleveland Heights, Ohio
    On my bikes that have chains I follow this method. (Many people will do many different things, but this seems to work for me)
    If I am riding in the dry, clean... then lube every 500 miles with a nice chain lube.
    If riding in slop, rain, mud etc... I do one of the following. Keep a can of 4D-40 with me. (And NO it does not harm a chain, even o-ring, or x-ring) when I'm done riding if there is mud everywhere wash it off. Then spray with WD-40. If I'm out where i can't really wash the chain off, just do your best to get as much mud and gunk off and then spray with WD-40. This will keep the chain from rusting or going dry during your extended ride, or if you get home late and just want to sleep. Then when you get some time, give the chain a good cleaning and a good lube.
    Nice bike btw.
  4. sailah
    sailah Lampin' it
    Aug 12, 2005
    6,909
    Turning expensive metal into scrap
    Don't get into habit of putting bike on center stand and cleaning it in gear...
    I also ran with scissors when I was younger.
    LuciferMutt, mitchapalooza and nk14zp like this.
  5. tominboise
    tominboise Long timer
    Jun 17, 2007
    2,021
    Boise, ID
    I have several gallons of kerosene and a chain brush. I wash it down every now and then with the kero and brush. In between i will periodically lube with whatever leftover spray I find on my shelf. Leftover ATF on a rag works well, too.
  6. mysticbus
    mysticbus Mysticbus
    Mar 17, 2010
    909
    Daytona Beach, FL
    Gotta get me some Kerosene then, I guess figure out what kind of lube I want to use.
  7. whisperquiet
    whisperquiet Motorcyclist
    Aug 24, 2007
    1,784
    62298 in lovely corrupt/bankrupt Southern Illinois
    gonerydin likes this.
  8. mysticbus
    mysticbus Mysticbus
    Mar 17, 2010
    909
    Daytona Beach, FL
    #8
  9. outty
    outty (☞゚ヮ゚)☞
    Feb 4, 2018
    314
    Edmonton, Alberta
    Keep it clean, keep it oiled w/ whatever suits your fancy and keep it at the manufacturers recommended tension. Make sure to check the tension as instructed (usually unloaded on the side stand) and it should last you a long time.
    #9
  10. nevermind
    nevermind Slower, then Molasses
    Jul 26, 2008
    3,429
    Out back...
    On the sandbar called Florida, you need to keep the chain clean and adjusted. It is an o-ring chain and lubed internally. It doesn't help to coat it with sticky goo. You can use a teflon based spray or other spray that stays DRY in order to keep sand from becoming impregnated into the lube. You can use a light coating on exterior of the chain to help keep rust away, but a quick wipedown after washing will do the same thing. After washing, dry the chain off with a quick ride.
    https://www.amazon.com/DuPont-Teflon-Non-Stick-Dry-Film-Lubricant/dp/B018FTA5WA
    #10
    Navy Chief likes this.
  11. mitchapalooza
    mitchapalooza Rider is Air-cooled
    Sep 1, 2010
    130
    Bethesda, MD
    This.
    I did it too.
    #11
  12. Johann
    Johann commuterus tankslapperus
    Feb 11, 2006
    3,930
    Europe
    You will probably be surprised how long modern chains last and little adjustment they need. Might need a tweak or two in the first 1000 miles, then probably nothing for 15-20k miles. At some point after that it will start to need regular adjustment which is the indication that it´s on the way out. That is for a bike used on road, if used heavily offroad the mileage will be less. I normally put on lube about every 200 miles, always at the end of the day, but doubling that wouldn´t be a problem depending on where the bike is used.
    #12
  13. concours
    concours WFO for 44 years
    Dec 2, 2008
    6,574
    Kensington, NH USA
    I prefer chain lube with Moly.
    Google it. Short for molybdenum.
    #13
  14. Schmokel
    Schmokel I got peed on today.
    Jun 29, 2015
    13,318
    Up. And to the right.
    Don't stick sleeping bags in it.
    #14
  15. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    6,664
    Truckee
    Do nothing.
    I sometimes hose the mud off of it, and spray some lube on it. But I don't think it is all necessary.
    Adjust tension as needed.
    There has been documentation of chains that have been maintained vs not. Wear was about the same.
    Further reading on this below. Non maintaned chain about 25% shorter life.
    #15
  16. JeepDawg
    JeepDawg Long timer
    May 3, 2014
    1,560
    Famous Potatoes
    You will also get to the point where you can hear the chain when it's dry. It just sounds different and noisier than when it's fully lubed.
    #16
    shinyribs likes this.
  17. concours
    Dec 2, 2008
    6,574
    Kensington, NH USA
    Or tents.
    #17
    doc moses likes this.
  18. concours
    Dec 2, 2008
    6,574
    Kensington, NH USA
    Horseshit.
    #18
    Motomantra likes this.
  19. MrPulldown
    Aug 18, 2009
    6,664
    Truckee
    dogshit
    #19
  20. MrPulldown
    Aug 18, 2009
    6,664
    Truckee
    OK I found the post where this was mentioned so that I could reread the details. Yes a maintained chain will wear better/longer. By about 25%. OP decided that it was not worth the effort. I have read other similar accounts. My take away was, do what you want with chain maintenance. But it is not super critical with modern o-ring chains, that they need to be cleaned and lubed religiously.
    https://advrider.com/index.php?threads/dr350-thread.230695/page-1994#post-29391047
    #20
