What do I do with this damn chain?
Discussion in 'The Garage' started by mysticbus, Jul 10, 2018.
  1. mysticbus
    mysticbus Mysticbus
    Mar 17, 2010
    908
    Daytona Beach, FL
    #41
  2. gonerydin
    gonerydin Been here awhile
    Feb 14, 2012
    300
    Iowa, USA
    #42
    concours likes this.
  3. CaseyJones
    CaseyJones Ridin' that train
    Aug 10, 2010
    3,233
    Western Montana
    You don't understand it? What, the twice-monthly need to squat down beside the bike, on a spool-stand, with an old toothbrush, chain cleaner, chain lube, paper-towel roll... to do the nasty?
    The concern, on dirty roads?
    The fear, when you hear that chain start sounding on its race?
    You don't get, the LIBERATION of just changing rear-end oil once a season or whatever?
    #43
  4. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    6,992
    Kentucky-Eastern that is!
    I use Walmart Dupont Teflon aerosol chain spray lube-comes in two sizes. I have a cheapo ebay Chinese chain brush for that once in season clean up but usually don't need that for pavement.
    #44
  5. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    14,181
    New(er) Mexico
    I absolutely despise chain lubes that fling off. I've been using Maxima chain wax for years, but on my Ducati Scrambler, its chain is just about toasted at 12k miles. I've never worn out a chain that fast. Still using Maxima every 500 miles, still keeping the tension correct. I don't understand why this particular chain is biting the dust so fast. My previous chains went 18-20K. This chain is shedding all of its o-rings and developing a ton of stiff links.
    So thinking about changing chain lubes, but so many of them say they don't fling off but do. The BelRay super clean is good to go, huh?
    #45
  6. mysticbus
    mysticbus Mysticbus
    Mar 17, 2010
    908
    Daytona Beach, FL
    That's interesting, think you might have an alignment issue?
    #46
  7. LuciferMutt
    Aug 19, 2008
    14,181
    New(er) Mexico
    I am meticulous about using the alignment marks on the swingarm when R&Ring the real wheel or adjusting tension. It's possible the alignment marks are innacurate. I need to buy a chain alignment tool to be sure I guess.
    #47
  8. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    2,431
    Beaverton, OR
    Try the other Maxima. Crystal Clear it's called. I soak the chain, let it fling off, wipe it down once & that's it. So it flings off, BFD :csm
    I got 38 K miles out of my 138 HP sport bike with it, but I think a lot has to do with the chain itself. Some guys do well with WD-40. Not going to try it.
    #48
  9. concours
    concours WFO for 44 years
    Dec 2, 2008
    6,574
    Kensington, NH USA
    Think 'lowest bidder" and suddenly, the picture will come into focus.
    #49
  10. max384
    max384 Bandaided
    Nov 23, 2011
    5,012
    Eagle Rock, PA
    I used to do this when I was first starting out. How I cringe thinking back now.
    #50
  11. max384
    max384 Bandaided
    Nov 23, 2011
    5,012
    Eagle Rock, PA
    Some of us ride much more than a typical rider, and thus a neglected chain will not last a few years. Maybe a few months.
    #51
    16VGTIDave likes this.
  12. LuciferMutt
    Aug 19, 2008
    14,181
    New(er) Mexico
    I wondered that but was informed the stock chain is a DID.
    #52
  13. concours
    Dec 2, 2008
    6,574
    Kensington, NH USA
    Like every well respected name, there are products built to a price point. OEM's drive it way down.
    Tires
    Suspension
    Lighting
    Brakes
    Chain MODEL name should be on the side plates as well. Whatcha got?
    #53
  14. misterk
    misterk Been here awhile
    May 30, 2008
    440
    DFW Texas
    I use the same math, but with one addition....I havent had to adjust the tension on my Africa Twin in 14k miles. I have not had to touch the chain in 14k miles, I think twice I cleaned it with wd40 just to make it shiny :) My chain is ALWAYS quiet. Here is my secret......
    I also used the same oiler on my NC700 for 30k miles. Takes 10 minutes to install, no vacuum or electric parts:
    https://www.tutorochainoiler.com/
    I usually refill about every 3k miles. My swingarm or wheel has no oil residue:
    #54
  15. Vrode
    Vrode Hangin' Out
    Jan 21, 2014
    2,579
    Vermont
    Modern o-ring chains are pretty robust. A light clean/lube every 500 miles or so should suffice. Rain seemed to cause some rusting/kinking if I wasn't good about lubing afterwards.
    #55
  16. cagiva549
    cagiva549 whats a cagiva
    Oct 10, 2004
    4,921
    Cypress Tx
    I would expect a crap chain on a jap bike but euro trash usally comes with quality , my Duc had a did x ring , the KTM came with top of the line Xring , 30 to 40,000 mile chains on a high performance dirt capable bike I didn't ride th Duc long enough to ever look at what was on it . I think the Cagivas came with RK . I ran it aroud 25,000 but that was before I discovered bar oil so it got spray oil .
    #56
  17. max384
    max384 Bandaided
    Nov 23, 2011
    5,012
    Eagle Rock, PA
    So you expect a crap chain on a "Jap" bike? Where do you think the best chains are made?
    #57
    doc moses, bcbullet and Motomantra like this.
  18. cagiva549
    Oct 10, 2004
    4,921
    Cypress Tx
    They might make them there to sell to you as aftermarket but the mc manufacturers do not buy top of the line to sell you when you buy your bike , that's up to you . I'd be willing to bet you a buck no jap bike will come with a X ring chain when new . But I don't know for sure , I've never bought one . All my bike were built with quality parts when I bought them .
    #58
  19. MotoChris521
    MotoChris521 Long timer
    Aug 30, 2007
    2,400
    south west
    So are the "jap" parts that come on every KTM quality ?
    Edit . Looks like your Ducati even comes with "jap" parts . :imaposer
    #59
  20. max384
    max384 Bandaided
    Nov 23, 2011
    5,012
    Eagle Rock, PA
    They definitely do. Not all, I'm sure, but plenty do
    #60
