What do you think about Oil Additives?
Discussion in 'Dakar champion (950/990)' started by Nriku, Nov 2, 2019.
  1. Nriku
    Nriku Adventurer
    Sep 1, 2014
    13
    Hello all!
    I'm about to make an oil change to my KTM 990 Adventure S and I'm thinking on filling this oil additive before putting the new oil:
    https://www.aditivox.com/xenum-mflush
    I want to put it meanly because gears are a little bit rough (something "normal" on all bikes with oil about to change), the fact that the last time that I did an oil change there were a few metallic parts in the screens and also because the clutch lubrication tube was clogged 3 months ago and I needed to open the case and solve it.
    Has anyone tried this brand? Another one?
    What's your opinion?
  2. getonyourbikeandride
    getonyourbikeandride Been here awhile
    Dec 28, 2015
    384
    New England
    Just say no to all additives. Use a good 4-stroke motorcycle oil, everything you need is in that.
  3. skuikka
    skuikka Been here awhile
    Jun 23, 2009
    247
    Finland
    I dont see any point in additives either.
    These engines take tons of abuse with no problems if the oil is changed frequently. Mine is at 90k km now and there is stile metal in the magnet and screen avery once in a while. But since it still works as a 950 should, I believe there is still some left in right places.
    The rollers on the shift fork might go bad if you keep hitting stuff with the shift lever and that will make the shifting sticky but only additive to prevent that would be some sort of sedative for the driver.
    CROSSBOLT likes this.
  4. Steve27
    Steve27 n00b
    Oct 29, 2019
    6
    Hull, England
    Ditto - good quality modern oils have outstanding additive packages ‘built in’. Best to stick with them unless there is real evidence to do otherwise. That evidence is difficult to come by without a very expensive laboratory.........
  5. Trailrider200
    Trailrider200 Long timer
    Nov 2, 2010
    1,218
    Exit 10A, RT 42
    stay away from oil additives unless u are going to do used oil analysis before, during and after using the additive, to see results. Reason most additives can completely disrupt the add pack of the oil you are using and thereby cause excessive wear.
    diesel oils are better and more cost effective.
    http://www.lngpublishing.com/LNGmagazine/index.cfm
    this months issue
    http://viewer.zmags.com/publication/e9f4b3fd#/e9f4b3fd/1
    see article Two-wheelers love oil too!
    JASO spec'd motorcycle oil are basically the same specs as heavy-duty diesel oil standards.
    JASO does not test oils, manufactures pay a fee to JASO and state their oil meets the specs.
    see article, another grade for the heavy-duty upgrade?
    even better diesel oils coming into the market much better wear protection and using a 10w30 for better mpg.
  6. gearheadE30
    gearheadE30 @LC8Adventures Supporter
    Jan 20, 2012
    2,228
    Indiana
    Likewise no to oil additives. I am by no means an oil expert, but deal with quite a bit of oil analysis at work with people who do know a lot about engine oils. No additives, as you have no idea how it will interact with the additives already int he oil as Trailrider200 said.
    Generally, more frequent oil changes are always better, and are going to do more for your engine than additives. You may get away with two oil changes per filter change - with how I use my bikes, I tend to change the oil around 1500 miles and change the filter every other oil change. On longer trips where I'm not purely off road, I will stretch that out quite a bit more.
    Use an oil weight that is in line with manufacturer recommendations, especially on the "hot" side of the number considering the performance nature of our engines. That means no 5w40 or 15w40 in my book. I tried it once out of necessity and instantly had a noisy engine when hot off road. Typically, I use 20W50 due to availability. Bearing clearances, piston clearance, ring pack, etc. are all designed with a specific oil capability in mind. Modern engines that use XXW20 and XXW30 oils have much tighter tolerances to be able to handle them.
    Diesel oils can be a good fit in some cases, as current CJ-4 and CK4 oil designations require a very capable oil to be able to deal with soot, fuel dilution, acidity and volatility, and viscosity stability over the extended oil drain intervals required by today's diesel market. However, I am not sure how relevant those capabilities are for a gasoline engine with a wet clutch in the oil. I typically recommend motorcycle-rated oils because of the clutch. I have seen too many slipping clutches from incorrect oils to want to risk it.
  7. Trailrider200
    Nov 2, 2010
    1,218
    Exit 10A, RT 42
    diesel oils do not have the additives that can cause clutch slippage which gasoline engine oils have.
  8. Spyrious
    Spyrious Want to go offroad
    Oct 9, 2016
    236
    Greece
    How does an diesel oil cope with motorcycle transmissions?And what about oils that are both for gasoline and diesel engines?For example Castrol Supercar 10W60?
    #8
  9. Trailrider200
    Nov 2, 2010
    1,218
    Exit 10A, RT 42
    did u see my above post about JASO?
    transmission gears are not cut whereas they highly shear motor oils. many automobile manual transmissions many yrs ago used automotive oils, and now just about all use transmission oil. The gears and how they are cut in final drives are the type that highly shear oils.
    #9
    Spyrious likes this.
  10. Spyrious
    Oct 9, 2016
    236
    Greece
    Yes i saw that and i checked the magazine in the link you posted,but it wasn't very clear to me (english is not my native language).
    #10
  11. Nriku
    Nriku Adventurer
    Sep 1, 2014
    13
    Thanks for all your recommendations!!
    I think that the answer is clear: just use recommended oil, renew it frequently and avoid additives.
    I will follow your comments, thanks again!!
    #11
  12. armstrongracer
    armstrongracer Adventurer
    Jun 24, 2018
    34
    Dublin, Ireland
    Everyone is pretty much correct here, stay well clear of additives and stay well clear of car oils too in my opinion. Some of the trace additives they put in car oils like Molybdenum disulphide can cause permanent clutch slip. This advice is based on 25 years of racing experience, 20 years as an automotive engineer and a degree in Metallurgy.
    #12
    Crazygreek and TheBritAbroad like this.
