What grade of aluminum?
Discussion in 'The Garage' started by DavidR8, Aug 18, 2019.
  1. DavidR8
    DavidR8 Wanna-be ADV rider
    Jun 14, 2013
    266
    Victoria, BC, Canada
    I have a Two Brothers exhaust can with a hole in it. It’s really more than a hole, it’s like a big gash in the side. IMG_5176.jpg
    The inlet and outlet pieces are in perfect condition but my bikes PO somehow managed to have this happen.
    I don’t want to just chuck the thing so I’m wondering two things:
    1) could I fashion a patch?
    2) could I fabricate a new can and put the inlet and outlet in the new tube?
    What grade of aluminum sheet would be the easiest to work with?
    Edit: a bit of Google-fu indicates that 3003 or 5052 would do the trick. 6061-T6 is not recommended.
    I’ve taken it apart and it’s nothing more than an aluminum tube with a baffle and packing inside. So low tech it’s almost laughable.
  2. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    4,797
    Mesa, AZ
    Find a 1000 or 1100 aluminum sheet.
    DavidR8 likes this.
  3. slacker1965
    slacker1965 .....no matter where you go......
    Aug 2, 2009
    95
    charlotte
    If you are going to replace the tube, just replace it with a tube instead of trying to make one. Lots of inet sources of tubing, eBay is easiest but there may be better/cheaper sources.
    If you live in a decent sized city, & have one, many metal suppliers will sell their 'drops' cheap.
    In case you don't already know this, you will need to know your desired inside diameter to match your cones, & desired wall thickness.....
    You could always upgrade to stainless steel, but it isn't cheap
    Either way, good luck with your repair
    Peace
    DavidR8 likes this.
  4. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    9,083
    Kentucky-Eastern that is!
    Looks like a previous patch got hammered.
    DavidR8 likes this.
  5. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    7,649
    below the sea
    Second the stainless swop.
    Depends on the grade, some grades can difficult for a novice to drill for example. Much less likely to get damaged while fitting or forcing into place though.
    You can get away with thinner material to offset weight gain.
    I live near a small rural town ie country - farming - growing - food - processing. We have quite a few stainless manufacturers/fabricators. I had a worktop made for my hob unit, very precise as you would expect from a laser. Nicely welded corners, whole thing looks and works like a charm.
    Cost around $150.
    Most places have workshops that can make what you need, especially if you can be a bit flexible. It is not beyond the bounds of possibility that the tube you need is a fairly standard size.
    You can also buy carbon fibre in tube form.
    DavidR8 likes this.
  6. Salsa
    Salsa Long timer
    Dec 12, 2006
    1,251
    Arizona, Alaska
    I would use 6061T6, the most common. 1100 is usually soft,soft,soft. Too soft for me.
    Don
    DavidR8 likes this.
  7. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    14,818
    the hills
    If you must 2024 will do the job. But is it really worth it?
    You can get 12"X12" hardened 2024 for $20 USD from Mcmaster.
    DavidR8 likes this.
  8. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,377
    Anchorage, formerly Spenard (hub of the universe)
    not 1xxx series... too soft. unless its really thick, you can dent it with your finger. if you have a local fabricator shop around they usually have scrap that is cheap or even free. if you want to hand form it find a piece of pipe the right diameter to wrap the sheet around. a little smaller is better than too big. break (slight bend) the front edge about 1/2" so it will lay flat. maybe straps to help pull the metal into place.
    #8
    bearcat1 and DavidR8 like this.
  9. nickguzzi
    Feb 17, 2010
    7,649
    below the sea
    If you can only get larger sizes, get one big enough you can cut, then overlap and rivet (presuming you can't weld) Use hose clamps to hold at right size.
    If using rivets, use the usual Al ones for Al and steel ones if you go for stainless. Stainless rivets are fairly hard to set by hand, choose the small size.
    And you can get so called waterproof rivets too, to stop seepage.
    #9
    DavidR8 likes this.
  10. shovelstrokeed
    shovelstrokeed Long timer
    Jun 20, 2003
    5,708
    6South Florida
    You just might try ordering a replacement can from 2 bros. They could have something in stock.
    #10
  11. DavidR8
    Jun 14, 2013
    266
    Good idea. I’m in conversation with them.
    Edit: Mark Jacobs is emailing me.
    President of Two Brothers!
    #11
  12. Zahnarzt
    Zahnarzt Crashes Much
    Sep 10, 2009
    797
    Sierra Vista Arizona
    What caused the hole?
    It looks like a recurring issue.
    #12
  13. DavidR8
    Jun 14, 2013
    266
    It’s in a new-to-me Honda Hawk. I suspect the can may have come from another bike as I don’t think there’s a way the chain could have done that on this bike unless the can was actually falling off the bike.
    The damage is about 12”-14” above the chain and is completely parallel to the chain line.
    #13
  14. kenny robert
    kenny robert Long timer
    Aug 21, 2015
    1,652
    south orygun
    what are the dimensions i have lots of core aftermarket bodies and some very nice condition
    wall thickness and a precise circumference and length
    if oval ,round can be easily ovaled but must start out with the same circuference at a given wall thicness/gauge
    #14
  15. kenny robert
    Aug 21, 2015
    1,652
    south orygun
    me i would l;ook for a used aftermaket can with simil;ar internal dimensio\ns ans a direct slip on fit size or a schosh bigger
    i have for \xample a akrapolish ti aftermarket can off a 450 mxer that woluld so cool on there you could get hookers for free
    #15
  16. Carlos M
    Carlos M www.motoxplorers.com
    Jun 17, 2002
    4,092
    Portugal, Europe
    I had a broken chain cut a slash like that through a Wings Ti can on a 990 KTM. It makes you think what other damage may that cause should it touch ones body.
    #16
  17. Wentwest
    Wentwest How's that work?
    Feb 19, 2007
    2,975
    Northern California
    I had a broken chain bend a shifter shaft enough that it always leaked oil past the seal.
    #17
  18. DavidR8
    Jun 14, 2013
    266
    I just measured it.
    It’s .080 thick
    Exactly 14” long
    Oval: 5” tall x 3.75” wide.
    #18
  19. DavidR8
    Jun 14, 2013
    266
    Turns out Mark Jacobs, President of Two Brothers Racing is sending me a new aluminum sleeve and repack kit to use with my end caps.
    What amazing customer service!
    #twobrothers
    #19
  20. kantuckid
    Nov 29, 2007
    9,083
    I was going to say this: by the time you run around chasing metal while burning gasoline it might make sense to buy a new can or a barely used one like the Delkevic I have listed in the FM. It is a welded, UK built, SS can w/removable DB killer and universal clamps.
    #20
    DavidR8 likes this.
