What have you done to your GS or GS Adventure today?
Discussion in 'GS Boxers' started by PWarren4, Oct 26, 2012.
  1. milq
    milq Long timer
    Dec 31, 2007
    1,232
    Southern IL
    I suspect it has something to do with the increasing amounts of license plate scanning cameras in use. The boys in blue are probably under orders to make sure plates can be read by the software.
    Dale402 and SmittyBlackstone like this.
  2. JMforPres
    JMforPres Long timer Supporter
    Apr 13, 2008
    1,434
    Charlotte, NC
    It is another reason to pull you over. I try to avoid stuff that lets them mess with me when they want.
    Jon
    SmittyBlackstone likes this.
  3. judgedelta
    judgedelta Been here awhile Supporter
    Dec 14, 2017
    508
    Mississippi
    Having been a municipal judge at one time, I have seen people put stickers on their tags as well as frames that cover the state and county. The law has to be strict because a lot people have no common sense whatsoever. Most of the cops I have dealt with won't write someone up unless it really gets over the line (unless you exhibit a bad attitude, of course)...
  4. sgnden
    sgnden Been here awhile Supporter
    Dec 3, 2010
    246
    Boulder, CO
    I’m going to connect my Hondo Garage Juiced Squeeze later today.
    I guess I’ll connect a couple of ring terminals and heat shrink the connections if I can find parts for that tiny wire.
    Sorry for the super basic question, but is it as simple as just connecting directly to the battery at the terminals? There are a few connections in there...just want to do it right. Thanks!
  5. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    9,790
    Zer0-Zer0-Zer0-Zer0
    You're good to go using those 2 as +/- connections... :thumb
    Rex Solgar and sgnden like this.
  6. deep6blue
    deep6blue Been here awhile
    Sep 25, 2015
    239
    USA
    There are vinyl wraps available in all kinds of designs and colors. Perhaps that may be easier and less expensive. Plus, you can change it again later.
  7. Bruincounselor
    Bruincounselor North Plains Drifter Supporter
    Apr 1, 2006
    2,015
    Wouldn't that leave it on all the time? I hate parasitic drains on my battery. You might want a switch of some sort in that circuit.
    Hogges and Callisto224 like this.
  8. Lead Wrist
    May 26, 2007
    9,790
    Zer0-Zer0-Zer0-Zer0
    That would depend on the rest of the wiring harness and how it's configured. If not integrated into bike harness, then a relay w trigger wire will be needed - ymmv...
    Higher priced lights have harnesses which are tied to bike electrical harness via TPMS port (Clearwater, Denali etc) and connecting the aux lights to the battery is just providing the power to the aux circuit while bike's ignition on/off controls the rest...
  9. rboett
    rboett posser noob 205
    Nov 5, 2002
    2,472
    nwa
    Got some new tires, TKC 80 front, TKC 70 Rocks rear, here is the rear
  10. Bruincounselor
    Apr 1, 2006
    2,015
    Mansplaining?
    The photo sure looks like direct battery positive and ground. A relay is a switch as are the fancy aux power boxes.....
  11. Lead Wrist
    May 26, 2007
    9,790
    Zer0-Zer0-Zer0-Zer0
    I tried to explain in previous post:
    - You have to provide power to the aux lights and that has to be done through wiring them directly to the battery - any lights will have to go through this step.
    - Depending on how the rest of the aux lights wiring harness is configured, ie. if the harness will be integrated into bike wiring harness or not, you won't ie. will need additional relay and switch to operate the lights... If all is integrated (ie. like w Clearwater), you'll use existing turn signal cancel switch to turn on/off the lights and wonderwheel for intensity adjustments. Other lights manufacturers (ie. Denali etc) will have similar set-up...
    You can take a look at Clearwater manual for installing their lights being that the lights are integrated through TPMS into bike wiring harness: https://cdn.shopify.com/s/files/1/0...00GSAW-R1250GS-R1250GSA-V4.2.pdf?v=1591136749
    Page 5 shows battery fused connection and rest of harness set-up - hope it's all clear now! :deal
  12. Bruincounselor
    Apr 1, 2006
    2,015
    @sgnden is installing a phone charger. He's asking if he can tie directly into the battery posts (see photo). He can, but will have parasitic drain on his battery (it will be always on). He gave no indication of having a Clearwater or other aux power solution so the above isn't pertinent.
    I merely suggested he might want a switch in there somewhere. Based on his apology, "super basic question", I'll assume he's not so good with the smoke in his wiring. Your reply that he's "Good to go" is true in that it will work, but may lead to a starting problem somewhere (hopefully in his garage) as his battery drains.
    I hope the OP hasn't been scared off by this pissing match.
    sgnden likes this.
  13. Lead Wrist
    May 26, 2007
    9,790
    Zer0-Zer0-Zer0-Zer0
    ^^ You may want to look up the "Hondo Garage Juiced Squeeze" installation instructions and see how it needs to be wired... :dunno
    sgnden likes this.
  14. Embret
    Embret Adventurer
    Oct 1, 2015
    78
    Arizona
    I have had a direct-connected "phone" charger connected to my last three Goldwings via a Y-connection to my battery tender connection at the battery. There is a small parasitic load from the USB charger, but if I recall my math from a number of years ago it would take months to run the battery flat based on that USB charger being connected all the time. I was worried about it until I did the actual math and then I chuckled. I've never had the battery killed by that connection. If the bike sits more than a week I plug it into the tender so it never becomes an issue. It is simply not worth the worry. When I'm on long trips I use that connection to charge my helmet while doing a museum or overnight, etc. I also charge up my USB battery bank for use on any devices that require charging at night that I might want with me and not on the bike itself.
    I would have no issue doing the exact same thing on my R1250GS although the battery is a smidgen smaller. I would have it done already but I haven't found a clean way of getting the power into my Vario Gehäuse.
    sgnden likes this.
  15. DBamaC
    DBamaC Counting down to retirement...
    Oct 6, 2016
    82
    BIRMINGHAM, AL
    I installed an eBay kickstand enlarger (really pretty decent) and a Puig headlight protector. Setting up the bike for mostly on road riding so I think I’m going to be happy with the protector.
    SmittyBlackstone and Callisto224 like this.
  16. Acousticplyr
    Acousticplyr Adventurer
    Jun 29, 2020
    80
    Pensacola, FL
    Have a link to that kickstand widget? Thanks!
  17. DBamaC
    Oct 6, 2016
    82
    BIRMINGHAM, AL
  18. RobLS
    RobLS The Navigator
    Jul 29, 2013
    291
    Atascocita/The Woodlands, TX
    Finally got around to getting another turn indicator switch.. via putting a screw in the spot.
  19. AdamChandler
    AdamChandler Ascending n00b
    Feb 29, 2016
    8,602
    Hanover, NH USA
    For every cheap bastard (genius) out there, there’s someone like me with the aftermarket warranty.
    But seriously, this is awesome.
    Dale402, BJMoose, sceep and 1 other person like this.
  20. handensco
    handensco Long timer Supporter
    Sep 19, 2008
    1,153
    Northern New Mexico
    I will have to remember that one
    AdamChandler likes this.
