What have you done to your GS or GS Adventure today?
Discussion in 'GS Boxers' started by PWarren4, Oct 26, 2012.
  1. AdamChandler
    AdamChandler Ascending n00b
    Feb 29, 2016
    8,594
    Hanover, NH USA
    Thanks and she cleans up nicely!
  2. MattF44
    MattF44 Been here awhile Supporter
    Nov 8, 2014
    686
    Swampscott, Mass
    I'm new to GS ownership but that picture got me wondering. Is the process for dealing with a drowned bike to just remove the secondary spark plugs and go from there or do both need to come out.
    And, needless to say, I'm hoping not to have to use this nugget. Hell, I don't even know what size socket I need to get.
    Glad you made it out.
  3. AdamChandler
    Feb 29, 2016
    8,594
    Hanover, NH USA
    Ideally this should be something people avoid and the LC bikes (2013 and newer) are less likely to flood due to the higher intake than the oil cooled bikes. You can basically ford water up to your hip before you run a risk of flooding the engine and at that level, the hidden rocks, holes or river current is going to be so much many intermediate riders will be challenged. I've been riding above the wheels with water and it's really not fun.
    If you do hydro-lock, yeah you pull the spark plugs and blow the water out then immediately flush the oil 20 times. In every case I've seen a flooded GS, they've made it home but I think it's been rare that I've ever seen one continue functioning perfectly without a lot of time flushing cheap oil through the system to purge all of the H2O. Once internal components start to rust, it's bad news.
    I've luckily never had to deal with this on any of my bikes and boxers are better suited than traditional engines to purging the water.
    I've known a couple of riders (1 Canadian) who actually had their bikes totaled out thanks to hydro-lock. Surprising but somehow they pulled it off.
    LC Air Intake:
    OC air intake:
    So LC is a good 6" higher...it's actually higher than the muffler slightly.
    SmittyBlackstone, billll and MattF44 like this.
  4. marc11
    marc11 Been here awhile
    Nov 5, 2009
    831
    New York
    Front and rear tires mounted and balanced. Love having a no mar, tire warmers and marc parnes balancer in my house.
    How else can you get a set of tires for $100, work all day until 4:00 PM on a raining Monday and before 5:30 pm have your tires r/r and bike ready for that same $100 tire cost?
    Oh and do it all in your pajamas....
    Zubb, ATCguy, Magus and 6 others like this.
  5. CharlesH
    CharlesH Support those who support you.
    Jul 29, 2006
    483
    Albertville MN
    Which tire warmer do you have? I'm interested in the idea.
  6. DIRTLER
    DIRTLER Long timer
    Sep 5, 2015
    1,640
    Globe ''D'' Earth
    Sent Garmin Navigator back to Garmin for not working correctly. 4 months old, 1200 miles on GS 1250.
    regnaDkciN likes this.
  7. marc11
    Nov 5, 2009
    831
    New York
    Cheap Pit Posse ones from Amazon. I got the standard 17" ones which fit well enough forbth front. I think I paid $169 a few years ago. Best money ever spent. Tires get so hot you need gloves , you'll never get them that warm with other methods.
    scottdc and CharlesH like this.
  8. Myll
    Myll Been here awhile
    Jan 22, 2018
    283
    Illinois
    I like to struggle on the floor. Helps me get a lot of words out
    Zubb, Callisto224, mwoods and 6 others like this.
  9. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    7,713
    Sunshine Coast B.C.
    I made a hanger for my helmet.
    It was raining hard last week.
    Yev, regnaDkciN, Ritch814 and 26 others like this.
  10. Nashfast
    Nashfast 101st AB Sniper RVN Supporter
    Feb 12, 2011
    80
    Torrance, Ca.
    View attachment 2683044 Custom Denali Soundbomb Dual Tone 2 piece horn installation on my 1250 GSA HP awhile back like the one I installed on my 14 GSA
    Once all the panels were removed next the stock horn and bracket were removed. The Denali horn was then held up in the vacated area. The mounting surface of the new horn matched well with the OEM horn bracket when placed as high as possible in the space. Then the bracket was replaced and marked for a 90 degree bend to mount the Denali horn.
    Measured the OEM horn bracket for the 90 degree bend for mounting the Denali Horn
    Here's the modified bracket with a new hole drilled to fit the center of the new horn surface and the excess length cut off. Re-Used the OEM nut plate to re-mount. IMG_0258.jpeg
    Horn with bracket installed at an angle for clearance required in original horn location. IMG_0259.jpeg
    Now mounted. Fits perfect with slight adjustments using Denali nut and bolt. IMG_0260.jpeg
    The compressor location will fit perfect in the plastic apron below the TFT instrument display. A 1/4" Pilot hole was the drilled in the center of the new area. IMG_0250.jpeg
    A 2" hole saw was used to cut from below to accommodate the 1-7/8' Compressor. Rough edges were sanded smooth. IMG_0252.jpeg
    The compressor now slid into location for mounting bolt fitting. Used a strip of velcro to fill in the extra space between the compressor body and plastic apron. IMG_0261.jpeg
    New hole drilled to move wiring and factory hole was used to mount the compressor
    Heres what the compressor attachment nut in the location on the 2014 GSA. (Forgot to take the shot on the 1250) Also shows the Relay location as close to the compressor as possible. IMG_0033.jpg
    Power to the relay from the Neutrino Element PDM. Trigger wired from the OEM wire. IMG_0376.jpeg
    Great to have a Ferrari sounding horn to replace the anemic roadrunner OEM "Beep Beep" BMW unit. Only used on special occasions when necessary to gain some cagers attention. This is the third one I've done and would do it again whenever a new GSA is purchased. Got to wear out the 2019 first.
    BJMoose, Rex Solgar, 18415 and 7 others like this.
  11. Acousticplyr
    Acousticplyr Adventurer
    Jun 29, 2020
    80
    Pensacola, FL
    I LOVE that Neil Peart quote. And I also respect what you did there as an homage to the man.
    His books and music are an eternal source of inspiration.
    Awesome.
    The hanger is cool, too!
  12. Carlisja
    Carlisja A wandering soul. Super Supporter
    May 29, 2014
    961
    Fairfax Station, VA
  13. falcofred
    falcofred aka Beer Scout Supporter
    Nov 30, 2008
    9,218
    Extreme N.E. Tennessee = Motorcycle Nirvana
  14. mikegc
    mikegc Long timer Super Supporter
    Sep 29, 2008
    5,917
    High Point, NC
    Torx head wood screws at McMaster-Carr.
    Mike
    sonnystile, GS Addict, flei and 3 others like this.
  15. mwoods
    mwoods Back for more adventures Supporter
    Mar 11, 2006
    453
    Just north of NYC
    Acousticplyr likes this.
  16. Bruincounselor
    Bruincounselor North Plains Drifter Supporter
    Apr 1, 2006
    2,014
    :stupid
    Please share.
  17. krussell
    krussell Gravel Warrior Supporter
    Nov 19, 2009
    4,450
    Portland, Oregon
    Mrs. Russell -> "So let me get this straight, you want to remove all the screws in the fence and replace them with new screws that are more legit?"
    Me -> "Yep. :-)"
    Unfortunately, they are SAE, which disqualifies them.
  18. GS Addict
    Sep 24, 2006
    7,713
    Sunshine Coast B.C.
    Thanks, I am on the hunt for Torx, for now Canukistan head has to do :-)
    SmittyBlackstone likes this.
  19. GS Addict
    Sep 24, 2006
    7,713
    Sunshine Coast B.C.
    mikegc likes this.
  20. GS Addict
    Sep 24, 2006
    7,713
    Sunshine Coast B.C.
    I found the picture on the net and had several sizes printed up.
    There is one on the inside of my topcase as well.
    SmittyBlackstone and Callisto224 like this.
