What is that smell?
Discussion in 'GS Boxers' started by Richard2112, Aug 1, 2020.
  1. Richard2112
    Richard2112 '00 R1150GS - RIP GhostRider!
    Jun 29, 2008
    490
    Vancouver, BC
    Hi gang,
    A question for all you fine folks.
    Bike: 2000 R1150GS ABS
    Odometer 89000 Km
    The bike has been in storage (in a heated garage) for the last 5 years and ridden only once or twice a year (injuries stink).
    This winter opted to get her out of mothballs.
    New stuff included:
    • New Plugs
    • New Fuel Filter and in-tank hoses
    • New battery
    • New brake lines
    • New brake pads
    • All fluids replaced (clutch brake, engine, FD, tranny and clutch .. couldn't find the blinker fluid reservoir though, thinking JVB could tell me where it is ;) )
    Bike ran great - only problem: Burning smell.
    When the bike is hot there is a smell coming from the central tranny area that smells of burnt clutch.
    It isn't coming from the new brake pads, it is central engine area.
    The clutch is just fine - working flawlessly (not slipping and good engagement position)
    Thinking it may be a blown clutch slave cylinder, I removed the starter to find that the inside flywheel area was dry (no oil) and looked OK. I did notice a bolt connecting the flywheel to the clutch system was loose (half out and not even snug). I made sure they were all snug.
    The starter was filthy.
    I cleaned it out with a tonne of brake cleaner and can easily move and retract. Some very thin coat of machine oil on the starter bits and back into service. Works fine, and smoother startup.
    My thought is that if the starter wasn't fully retracting, it would spin, overheat and likely stink. Sure enough the starter did smell of that 'burnt' smell.
    So my question: Could that have been it? Could the starter's inability to disengage cause the smell? It has significantly lessened since I cleaned the started, so perhaps that was indeed the culprit.
    Should I be sourcing out a new starter or start considering ripping the clutch apart? Or do nothing and put my worry beads away.
    I am hoping that someone else out there may have an opinion or share their own experience.
    Richard
  2. ExodusRider
    ExodusRider ExodusRider
    Jun 9, 2015
    2,037
    Houston, Texas
    Every time I ask that same question..
    my punk niece/ nephew always answers:
    "It's your upper lip!"
    Hope this helps...
    PaulBarton and Richard2112 like this.
  3. C3trevor
    C3trevor Adventurer
    Jun 12, 2020
    10
    Calgary,alberta
    Dust burning off?
    Rick92040 likes this.
  4. Richard2112
    Jun 29, 2008
    490
    Vancouver, BC
    Oddly enough, the Mrs and I joked about that very thing :)
    However, the bike had been stored with a cover - so it was quite clean.
    The other option is that some fluid from one of the many changes, dripped onto something hot and stunk up the joint.
    Just hate not knowing, as it may come back to bite me if I ignore it.
    Richard
    C3trevor likes this.
  5. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    5,707
    DC metro
    Beyond what you've already done, about all you can do is carefully & repeatedly check for any signs of leaks, oil, etc.
    Unless there's oily residue along a seam between major components, obvious leaks, or unexplained low fluid levels, it's probably fine.
    My vote: worry less & ride more!
    Callisto224, Rick92040 and LAFS like this.
  6. The Fabricator
    The Fabricator I didn't know it wasn't possible so I did it.
    Mar 30, 2018
    214
    Petaluma, Ca.
    Possible leak from the clutch slave onto the Cat. Or oil leak from the rear transmission shaft seal onto the Cat. I had the rear seal fail on my 2000 R1150 GS. Oiled the clutch. Started slipping which is why I looked at the slave/seal area. Mine did not leak on the Cat because the slave has a gasket that did not leak. Maybe yours does. When replacing the seal, I slotted the gasket to allow leakage for an indication of leakage and a prevention of clutch oiling. The slave can be removed in situ with great effort. The wheel and shock must come off. [The seal can be replaced also.] There is a horizontal pipe in the way that CAN be removed, just have to tip the subframe up. THAT is a pain. [I didn't.]
    I would not think a non-retracting starter pinion gear would cause a smell. The implication is the starter armature is spinning at 20x [?] engine speed and creating a smell from heated bearings [?] brushes [?]. Nah. You would most likely notice a sound of a starter spinning 20k RPM.
    That the armature is SHORTING and drawing MUCHO amps is more likely. In that case, I would expect lazy cranking speed, 'battery troubles' and an armature turned blue and worn down brushes. And lots of heat.
    Richard2112 likes this.
  7. jmb711
    jmb711 Adventurer
    May 2, 2019
    64
    Northern Nevada
    Dead mouse in the muffler? :hmmmmm
    Richard2112 and rg sw wa. like this.
  8. Coma
    Coma Long timer Supporter
    Jul 11, 2012
    2,369
    The Emerald Coast
    One of my first clues to the sight glass seep was a hot oil smell. My first thought was I love engine smells second thought was hmmmm It did used to do that. Sure nuff, shiny by the glass then I could see the fins were grimy.
    #8
  9. PerazziMx14
    PerazziMx14 Been here awhile
    Oct 9, 2011
    943
    Mouse pee!
    #9
  10. * SHAG *
    * SHAG * Unstable
    Nov 28, 2001
    5,652
    Bradford, Pa
    Spider pee too! :nod
    #10
  11. Richard2112
    Jun 29, 2008
    490
    Vancouver, BC
    Thanks everyone.
    I can confirm it isn't urine of any type - regardless of what photos you have purportedly showing me urinating on my bike :1drink
    Clutch slave seems ok, at least there are no other indication that it blew (clutch fluid was clean, no oil around the flywheel/clutch area).
    Sight Glass was replaced at Stealership some 30K ago ... new one is bone dry.
    I think I'm at the stage to just ride it and chalk it up to a few too many years of sitting and something burning off.
    Thanks again everyone for the great input!!! :clap
    Richard
    #11
  12. Welshman
    Welshman B.U.F.F.
    Feb 21, 2005
    1,642
    Jo,burg dry and dirty.
    Best idea yet. :photog
    #12
