What kind of water to mix with antifreeze?
Discussion in 'The Garage' started by Drop_Center, Aug 31, 2019.
  1. Drop_Center
    Drop_Center Long timer
    Sep 3, 2007
    4,349
    Rocky Mountains
    I have access to completely pure deionized water where I work. Wondering if this would be a bad idea? The distilled water at the grocery seems to be very acidic and is it trustworthy? Our tap water is very hard here in Colorado.
    What should I use and what if all my water is too acidic is baking soda an option?
  2. Tall Man
    Tall Man Emotionally magnificent
    Jul 14, 2007
    6,284
    The Occident
    To date, I've used bottled distilled water to create a 50/50 mix. That's the instruction evident on the label of the coolant bottle, irrespective of brand.
    Premix is remarkably expensive for what it is. I'll roll my own.
    spokester likes this.
  3. Bounder
    Bounder Typing...
    Mar 2, 2011
    1,997
    West Cork, Ireland
    Buy premixed stuff take the guesswork and potential error out of the equation.
    Honda car dealers sell stuff that works very well for bikes and isn't expensive.
    1greenmachine likes this.
  4. MattLikeyBikey
    MattLikeyBikey Been here awhile
    Nov 8, 2018
    423
    So Cal
    You can't do wrong with deionized or distilled. I often buy premix but that equates to about $4 to $8 for half a gallon of water and loss of usable coolant when a gal of distilled is 78 cents around here. The coolant manufacturers love when we buy premixed.
    concours and Drop_Center like this.
  5. Drop_Center
    Sep 3, 2007
    4,349
    Rocky Mountains
    So I take it the cheap water at the grocery is trustworthy?
  6. radmann10
    radmann10 Derf Supporter
    Apr 29, 2014
    1,149
    Phoenix, AZ
    Distilled water is the recommendation!
  7. Drop_Center
    Sep 3, 2007
    4,349
    Rocky Mountains
    Sorry, the cheap distilled water?
  8. markk53
    markk53 jack of all trades...
    Dec 20, 2007
    17,976
    Delaware Ohio
    Yep. No minerals to crust up the engine.
    #8
    996DL likes this.
  9. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    14,818
    the hills
    Distilled water cost $1 per gallon around here. That'd be cheap in my book.
    #9
  10. Wentwest
    Wentwest How's that work?
    Feb 19, 2007
    2,975
    Northern California
    I keep the last empty jug, buy a new undiluted jug, pour half in the old jug and fill both with distilled water. All done.
    #10
    996DL and HapHazard like this.
  11. severely
    severely almost a noob
    Jan 26, 2013
    699
    odessa MO/donna TX
    Please avoid the temptation of putting automotive anti-freeze in your motorcycle. Good luck
    #11
  12. anotherguy
    Jun 18, 2009
    14,818
    the hills
    Why? As long as it meets the specifications the manufacturer sets what's the problem?
    #12
  13. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    15,957
    New(er) Mexico
    This has the potential to rival an oil thread.
    Bottom line, use distilled water or premix, and don't use coolant containing silicates in a motorcycle (read the labels, it will tell you). If you like spending money, you can buy pre-mix at any motorcycle dealership (that sells water cooled bikes of some variety) that will be safe.
    #13
    bmw318tech likes this.
  14. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,799
    Hiding off Hwy 6, B.C.
    Please specify? The factory recommended coolant for my motorcycle does contain silicates.A low content but some nonetheless.:nod
    But no Nitrites or Phosphates.....!Same coolant used for my motorcycle is also used by quite a few car companies.:wink:
    De-ionised water!!! Usually on the shelf next to the coolant "to factory specs" I buy for my motorcycle.
    #14
  15. severely
    Jan 26, 2013
    699
    odessa MO/donna TX
    The high level of silicates are the issue.
    #15
    Dtx915 likes this.
  16. Drop_Center
    Sep 3, 2007
    4,349
    Rocky Mountains
    Per an different thread here, this is what I plan to use
    #16
  17. anotherguy
    Jun 18, 2009
    14,818
    the hills
    Well the specification states no silicates and the product has none it's fine to use. Reading is awesome. I am currently running this in my 2004 Aprilia Tuono. Seems to run 6-8* F cooler than it did too.
    Silicate and nitrite free.
    #17
    severely likes this.
  18. Cycle Goon
    Cycle Goon Been here awhile
    Sep 16, 2016
    772
    At every shop, they have a purified water tap. Water comes straight from the heavens above. Angel tears.
    You're an idiot if you think shops use anything other than tap water
    #18
    spokester, ohgood and sieg like this.
  19. Drop_Center
    Sep 3, 2007
    4,349
    Rocky Mountains
    Guess I'm an idiot, it would take a pretty special kind of asshole to use the water around here
    #19
    ArielNut likes this.
  20. anotherguy
    Jun 18, 2009
    14,818
    the hills
    Nah we just buy the $1 a gallon distilled. Use it in the occasional wet battery as well. Consult the mirror for more information on the idiot.
    #20
    beemerphile and Drop_Center like this.
