What the Frig do I do now
Discussion in 'Hacks' started by MGV8, Nov 3, 2012.
  1. MGV8
    MGV8 Long timer Supporter
    Aug 29, 2010
    1,727
    Canoe BC
    The other thing I wanted to fuss with is the Car brake. Having to stomp both pedals proves to be a challenge in a panic stop. Which with me tends to happen more often than not !!!
    I searched for ideas but didn't want to get carried away. Came up with this, each pedal is still independent but when I use the bike rear brake it will apply the car brake plus if it doesn't work I can take it off.
    As simple as it gets. we'll see if it works
    More to come
  2. High Octane
    High Octane Long timer Supporter
    May 31, 2013
    3,201
    South Dakota
    Here’s a pic of my 2 brake lever set up. If you add a threaded bolt to the bottom one you can adjust the engagement point for the car brake.
    2B6B9942-00A7-475F-9243-48C65B7FBAE1.jpeg FB6746DF-ECCE-4E2C-A7F2-00FC53736458.jpeg B8EF81EB-32D2-4FD1-BEAE-5BF87A1B60C9.jpeg
  3. MGV8
    Aug 29, 2010
    1,727
    Canoe BC
    Yours is what inspired me to solve my issue. Of course my solution isn't as elegant as yours. Function over form so to speak but nothing says I can't copy.
  4. High Octane
    May 31, 2013
    3,201
    South Dakota
    Well maybe there was something positive about my rambling posts.
  5. MGV8
    Aug 29, 2010
    1,727
    Canoe BC
    I'm tired after today. My goal this weekend was to get the rig onto it's wheels so I could measure Sag and Weights for Jeff at the Beemer Shop. He has my shock captive :D, and won't give it back until I give him some numbers. Didn't get much done yesterday but did finish my shock bushings. Which fit nicely. Then went for a Fat Bike ride with the young-ons which damn near killed me. Getting hard to keep up with the 50 year olds.
    So today I fussed over putting together the rest of the Leading Link from @LBS-USA Had to clean the wheels first. So it looked good for pictures.
    It doesn't come with instructions but the kit is so well made that it is kind of self explanatory. I guess I have put enough things together after some one else has taken them apart that things just fall into place. I did fuss over the brake lines and the Speed sensor routing a bit. Not sure I have it right but good enough for what I need today.
    Still I am amazed with the fit and the thought that Ad puts into his front end. All the bolts that are needed are in place, brake hoses, seal washers, Any thing that needs threads is and all the holes line up perfectly.
    Even the fender fits perfect.
    I was checking for any left over bits and had two plastic covers in my tray. Hmmm. Ok nice touch. As I said thinks of every thing.
    Oh yeah I had to fill all the fluids before I forgot. Lost the o-ring on the rear diff speed sensor but found the spare I have so that will have to be done later.
    draperg1, DRONE, Strong Bad and 9 others like this.
  6. High Octane
    May 31, 2013
    3,201
    South Dakota
    Beautiful
    draperg1, DRONE and FLYING EYEBALL like this.
  7. MGV8
    Aug 29, 2010
    1,727
    Canoe BC
    Once I was happy with the front suspension, Still have to bleed the brakes and recheck my line routing. It was time to mount the car frame, and see if my shock mount was going to work
    Cool it all fits back together just like it should. No checking alignment today, that is not my mission. Nothing should have changed really. I will check again once I have the ride height set again. I'm using the stock rear shock to get a base measurement.
    Wheels are on. I'm going to have to order a tire for the car. the others are good. Time to load it up to get a rough weight. Tub on first. Just set in place for now. It still need a good clean and I'm going to re-do the rock guard.
    Scales are ready.
    Base weight of the rig. Sans fuel, panniers and winch. I did put the top box on with 50 lbs of lead in it.
    Weight with me sitting on the rig
    Put all my camping gear on the tub. 80 odd lbs not so bad. Missing a few odds and sods but gives and idea of how heavy things get. Probably add another 100 to 150 lbs when I'm fully loaded with fuel, gear, water and food. The fuel tank is empty and I don't have my Roto's on the tub.
    The old race car scales come in handy. I still use them from time to time at work. When some Hot Rod comes in that needs to be corner weighted.
    Mission accomplished. I got Kathy into the shop to read the tape measure for me. Now I have some numbers for Jeff. 4 3/16 inch Sag with a stock GS shock. Too much? I think the spring on the car shock is too stiff. I will see what he thinks. It has almost no give what so ever. It was spec-ed for the front.
    I feel better now, it won't take much to get the rig rideable. I do have to lift the tub off again and finish what I want to do there. Plus tidy up all the wiring. Shouldn't take much now. Spring is just around the corner here in BC and I like to be riding first week of April.
    More to come
  8. steam powered
    steam powered just a regular punk
    Jun 17, 2018
    1,173
    New Zealand
    Did you just blank off the second hole in the lower fork bridge and run the new line from there?
  9. MGV8
    Aug 29, 2010
    1,727
    Canoe BC
    I haven't yet but that is the plan.
    draperg1 and steam powered like this.
  10. Sunday Rider
    Sunday Rider Adventurer Wanabe
    Jan 31, 2010
    2,864
    GTA, ONT, CANADA
    Just so enjoyable to see your progress, I don't know or understand welding, but that rig for the tub is impressive, so is the heavy duty double caliper setup in the front wheel. Also impressive is the living plant in the garage! Beautiful work Brian.
    draperg1 and LBS-USA like this.
  11. MGV8
    Aug 29, 2010
    1,727
    Canoe BC
    Thanks, over time I've managed to gather a great collection of parts made by others. I just disassemble and put things back together. On the plant, my girls gave me a little palm tree 30 years ago for fathers day. I have managed to keep it alive all this time. Probably root bound again so time for a bigger pot.
    Bobmws, draperg1, brstar and 4 others like this.
  12. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    13,901
    Omicron Persei 8
    Nicely done! I love the scales. I wish I had easy access to one of those.
    Bobmws, draperg1, MGV8 and 1 other person like this.
  13. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,976
    Minnesota
    Well played sir and that's actually below average weight for an oilhead with leading link forks and adv setup. I would have lost the actuator also under 1200 all up is almost extra frisky :lol3
    draperg1, MGV8 and LBS-USA like this.
  14. LBS-USA
    LBS-USA Been here awhile Super Supporter
    Jun 21, 2020
    374
    Seattle, WA
    +1 for EXTREME JEALOUSY on your car scales, may I have first right of refusal pretty please?
    I went to the internet university to do the math and the weight distribution almost exactly matches the last rig of mine that I was able to weigh:
    30% on the front wheel
    49% on the rear wheel
    19% on the sidecar wheel​
    I also found the spring rate on the shock ordered from TT-USA to be way too stiff, even at zero pre-load. I'll let you know what spring I settle in on, as they will re-spring a new shock for you (I have an appointment to have mine re-sprung while I wait).
    All in all, a very well-done refit, respect!
    TurTal, Bobmws, draperg1 and 2 others like this.
  15. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    10,138
    Tacoma, WA
    I'l echo Mike that my GS rig weighs out at 50/30/20 and that's with me and the (50-lb) dog onboard with all our gear for a multi-day trip. I was able to measure it at a roll on/roll off truck scale.
    Your comment about the speed sensor wiring was interesting. Looking at the pics I can see that with all the movement going on down there, it's a bit of a challenge. Unlike the stock bike where you just route it down the fork leg and forget about it.
  16. Prmurat
    Prmurat Long timer
    Oct 28, 2011
    4,017
    Scottsdale, AZ
    OH MY DOG ...so jealous of the scale!! When will Harbor Freight make one???
  17. MGV8
    Aug 29, 2010
    1,727
    Canoe BC
    I am tempted to deep six the actuator, It has enough play to clunk a bit. When new it was good but soon develops a bit of internal play. I have my strut that I carry incase if fails, if I get it set where I like the handling I may swap it in.
    I found it interesting watching the weight transfer. Getting on the bike took weight off the car. Etc Etc
    I got the Scales years ago. I found that it was the cheapest way to make our Hill Climb car faster, Paid for them selves in a lot of 2 dollar trophies. :lol3
  18. MGV8
    Aug 29, 2010
    1,727
    Canoe BC
    I'm not quite happy yet with how I have it routed. I know the caliper mount will move a bit with the suspension. Keeping out of harms way is about all one can do there. More of a concern was at the ball joint and the turn radius, there is just enough slack to not go tight at full lock in both directions. Basically still just clips to the brake hoses. We'll figure it out.
    The fun continues
    Bobmws and RidgeRunner56 like this.
  19. draperg1
    draperg1 PapaBear Supporter
    Mar 31, 2013
    900
    Martinsville, VA
    I weighed mine with a poor mans version (digital Fatman scales from Amazon). I block up the other 2 wheels the same height as the scale. I have tried it without blocking and the lbs are a little different but the percentage is the same. My K12LT/Hannigan Astro GT weighs a total of 1327.6 lbs. Front is 453lbs (34.12%) Rear 585.6lbs (44.10%) SC 289 lbs (21.77%) Sounds like we are all close on the %'s.
  20. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    8,036
    Fort Collins, CO
    "OH MY DOG ...so jealous of the scale!! When will Harbor Freight make one???"
    If Harbor Freight made it,... it wouldn't work! I've never gotten anything electronic from Harbor Freight that either worked or didn't work long. I hope your experiences are better than mine.
