what to do with a wet tent after a heavy rain.
Discussion in 'Trip Planning' started by pghchico, Aug 19, 2014.
  1. cejnys
    cejnys Been here awhile
    May 27, 2013
    835
    Houston, TX
    I really like the hammock idea; never done it....always tent. How difficult is it to find a spot to attached the hammock?
    #21
  2. _cy_
    _cy_ Long timer
    Sep 25, 2011
    6,842
    Tulsa, Oklahoma
    pack it away in a larger bag if you have one available. then put tent up ASAP to dry unless you are headed home. then put your wet tent inside any clothes dryer on low .. works great and you don't have to set tent up at home.
    #22
  3. jredford
    jredford Ninja Racer
    Feb 29, 2008
    1,148
    H town...
    Throw it away and go to WallyWorld to get a new one.:rofl
    #23
  4. ibgary
    ibgary Long timer
    Oct 18, 2013
    1,084
    Colorado
    Very rarely a problem. Trees don't need to be big, and there is a method for hanging a hammock from a pole or stick. You tube. I've watched but not tried.
    I have packed under the tarp, while is was raining. Worked pretty well. Cooking under the tarp is easy.
    I like the Kelty Noahs Tarp 12 x12, 60$. Should be called the origami tarp.[​IMG]
    Sent from my HTC One_M8 using Tapatalk
    #24
  5. WAH III
    WAH III Been here awhile
    Jan 2, 2011
    177
    Advance NC
    I always carry a small plastic trash bag to put the wet fly in when necessary. This keeps it from getting anything else wet once packed away.
    #25
  6. ta-rider
    ta-rider Returned from Africa
    Jan 14, 2012
    170
    Brasil
    I allways pack a wet tent like a dry one and pitch it the other day like normal. One day the rain will stop and the tent will be dry again. Just dont forget to take the tent out of its package every day otherwise it will start to live inside ;)
    #26
  7. lhendrik
    lhendrik Putins Puppet
    Dec 10, 2008
    2,799
    New York
    #27
    9Realms likes this.
  8. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    15,154
    Canada's ocean playground
    I use a hammock and tarp solo and recently picked up a tent for the daughter and I.
    The tent I have is an MSR Elixir which is referred to as a "dry pitch tent". Many manufactures make this sort of layout.
    I can take down the tent, and keep the fly and vestibules still standing. This way I'm packing everything up relatively dry, with only the fly being wet. A few shakes of the fly and most of the water is off. The fly is stuffed to the size of a softball and stored seperate from the tent.
    Same thing for the hammock. pack up everything and leave the tarp for last. I even move the rear of the bike under the tarp so even packing the bike I'll stay dry.
    I've since incoorperated the hammock fly for extra protection for tent camping.
    #28
  9. bill_in_pittsburgh
    bill_in_pittsburgh ADVer in training...
    Oct 23, 2009
    54
    Richland, WA
    What I do:
    Normally, I pack the tent either into a hard top case (waterproof) or an Ortlieb dry bag (also waterproof).
    If I need to pack the tent wet, then I'll usually separate the tent and fly, and pack each in a nylon mesh stuff sack (available at REI). I'll tuck these into a bungie web on the back of the bike, so that both are exposed to air/wind - they'll get pretty dry if it isn't raining the next day. Whenever I stop for gas, I'll pull each out of the stuff sack, and rearrange so that a wet surface is facing out and it can dry.
    I'll also try to stop a little earlier the next day so that I can set up the tent (freestanding), and move it onto different sides in the sun so it can dry. I'll lay out the fly on the bike or the ground to dry as well.
    #29
  10. live2ridetahoe
    live2ridetahoe RN
    Jul 26, 2004
    1,639
    Concord, CA
    I'll be packing a dry bag for my sleeping bag. When I put it all together, if wet, at least the bag will stay dry. See page 1 and 5 of my Mongolia thread for packing method.
    Tahoe
    #30
  11. FinlandThumper
    FinlandThumper Banning Snowflakes Super Moderator
    Jan 30, 2008
    14,385
    Helsinki
    I'll echo the advice of bill in pittsburg. I personally put the inner part (if not too wet) into the bag and stow it, then I strap the soaked fly to the outside of the bike and, at stops, air it out and re-fold it. That way the wind dries it out and it doesn't get everything else in the dry bag or pannier wet. I always have a small bungee net along for strapping random things on top so that's how I secure it.
    This, of course, only works on a day when it's dry. If it is raining hard when I get up, I usually stow it all together and follow the advice given above.
    #31
  12. levain
    levain STILL Jim Williams
    Oct 29, 2005
    9,440
    Providence, RI
    Stick it in the beavertail of course:clap
    Well, someday:deal
    <iframe width="560" height="315" src="//www.youtube.com/embed/_XJDLuPNOTM" frameborder="0" allowfullscreen></iframe>
    #32
  13. swoody126
    swoody126 Been here awhile
    Aug 26, 2008
    425
    denton, America
    +1
    for my ground sheet, i use a piece of old vinyl sign material, cheap & cuts easily
    all of my gear is separated in their own water proof/dry bags so items that do get wet don't share space w/ those that are still dry and/or don't like getting wet
    extra pieces of vinyl sign material are used to protect other items in my kit and i tie it on w/ sheathed solid core copper wire(individual strands from 12/3 romex electrical wire)
    the wire takes up way less space and weighs less than bungees
    sw
    #33
  14. Okie Preacher
    Okie Preacher Long timer
    Aug 11, 2010
    1,142
    In the middle...
    I pack all my "inside" stuff in a Sea to Summit compression dry bag (Sleeping bag, pillow, pad, etc.). The tent goes in a separate compression dry bag--then I carry both in a Wolfman Roll-Top Bag. The tent goes in wet or dry in the morning. If the sun comes out that day, thirty minutes stretched out over lunch has it ready to store. If it stays wet and rainy, it really doesn't matter because it is wet again as soon as it comes out of the bag.
    The best part is keeping all the "inside" stuff dry until the tent is up. Toss it in when the tent is set, unpack and a guy is good to go.
    #34
  15. The_Precious_Juice
    The_Precious_Juice 2015 Subaru Forester
    Jun 2, 2013
    7,823
    University of Montana
    If you want to take a couple hours break while while riding and if it is warm and sunny and windy, set up tent and get a jump on things. Later it may be too late or colder or raininy to do this.
    Take your time and enjoy yourself.
    #35
  16. Dubl-A
    Dubl-A SuckerDucker
    Mar 15, 2009
    1,884
    505
    I use the same bags, I pack the tent, sleeping bag and pillow in each...work great! :thumb
    #36
  17. Mastery
    Mastery Mr. Funny Man
    Mar 25, 2011
    2,435
    Hoosier Daddy?
    I carry one of those cargo stretch nets. If something is too wet to put away in the panniers, then it goes under the net which is over the pillion area, the top case, or the side cases and the item gets fluffed out and pushed back under the net at stops to continue drying while riding.
    #37
  18. engineered2win
    engineered2win Adventurer
    Sep 10, 2014
    31
    Columbus, OH
    There isn't always a solution to a problem. I was at the WEC race at COTA in Austin, Texas a few weeks ago and between the rain it was mid 80s°F with >80% humidity and even after laying out our rain gear for about 4 hours after the rainstorms it was still damp. In fact everything was damp: backpacks, shoes, clothes, etc. Had we not been staying in a hotel, nothing would have dried for 5-6 days. It would have been miserable camping in a tent with everything damp.
    #38
  19. live2ridetahoe
    live2ridetahoe RN
    Jul 26, 2004
    1,639
    Concord, CA
    One thing I have been using while camping has been 3 mil plastic sheeting. I bought it at Home Depot. I don't use a footprint for my tent. Rather, I cut the plastic sheeting about 12-18 inches larger than the footprint of the tent. I set up the tent and then put in the plastic. It's large enough that the plastic goes up the sides of the interior of the tent and creates a sort of plastic tub. This prevents water from the outside from getting to your gear, no matter how wet the ground gets.
    Tahoe
    #39
    SmittyBlackstone likes this.
  20. Cromoth
    Cromoth fan of the magic carpet ride
    Aug 24, 2010
    937
    MA
    Consider a floorless tent such as Kifaru or Seek Outside. Dig a little trench to direct water flow, inside stays dry. Bring a cot if you need to be off the ground.
    yes you'll still pack a wet tent so mesh bag, etc as others have said.
    #40
