What you did on or with your D/S-Adv bike today
Discussion in 'The Sandbox - AKA Flatistan' started by Huzband, Mar 3, 2014.
  1. Milkweed
    Milkweed It's not me, it’s the bike.
    Nov 1, 2011
    719
    Fleming Island, Florida & Coeur d’Alene, ID
    Maybe my last CDA Idaho ride of the year. 58 degrees and sunny. Yay!
    Much better than when it was 33 degrees and icy on Saturday.
  2. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    9,640
    Cowford, Fl.
    Installed a new Shorai battery this evening. Helga's rockin' & rollin' again. :ricky
    beefcake morris likes this.
  3. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    9,640
    Cowford, Fl.
    You're right, but now I believe it was actually broken/separated plates. I monkeyed with it yesterday before taking it out just to see what I could find. Ignition on everything lights up & cycles through. Hit the button, solenoid kicks, then everything resets. Volt meter showed 12.4 at rest, pretty close to normal. Hit the button and BAM, down to 7-8 volts. I've had this happen twice before & both times it was broken/separated plates. Just sitting there they make enough contact to show good voltage, but as soon as they're shocked with a power pulse they separate and all (well, enough anyway) connectivity between the polls is lost. And that's why jumping didn't work. Never did in my previous instances, either.
  4. beefcake morris
    beefcake morris Long timer
    Jan 21, 2013
    1,356
    Starting to prep for Trans GA:
    - Put a new Pre-Filter on the rottweiler air intake on the 1190
    - Installed a separate light switch for the 7100 lumens light bar (aka sun switch)
    - Waxed the the plastics
    Oil change coming up on soon, then I am ready to rock and roll.
    Huzband likes this.
  5. DaveBeezy
    DaveBeezy Been here awhile
    Jan 2, 2015
    581
    Jacksonville, FL
    2C1CFBE4-B8E6-4F28-AE0A-E30AE065F714.jpeg C3D150C3-C8FB-4BA7-9F15-145A910B04D6.jpeg
    Washed bikes and lubed chains.
  6. motomike14
    motomike14 Thumper Crusader Supporter
    Jan 2, 2010
    3,192
    Florida
    didn't get to work on bikes, but had to swap out a battery and a fuse in my s/o nephew's car. 4 of them stood around while I swapped the battery using nothing but a 10mm wrench and a screw driver to remove the air intake. they all thought it was some form of advanced wizardry. this was after he proclaimed "I looked it up online, it said it's probably out of fuel" while I showed him the volt meter displaying "6.7 v."
    rider1150gsadv, Dr.Z, Mugwest and 3 others like this.
  7. Buzztail
    Buzztail Buzztopian OG Supporter
    Sep 30, 2007
    13,991
    BUZZTOPIA, 32327
    I’d love to start a shop called Snowflake Automotive Repair just for stuff like this.
    “Yes, it needs a battery and two gallons of gas. That’ll be $1196 on your dads credit card.”
    Bill would read:
    R&R battery $20
    New battery $96
    Two gallons of gas because you said it needed it $80
    Should have learned to use volt meter $1,000
  8. Mugwest
    Mugwest .
    Oct 18, 2005
    16,995
    3rd Ring of Buzztopia
    They'd pay. And think that was a smart move in the Opportunity Cost model :fpalm
  9. elBeardo
    elBeardo Get busy living
    Mar 22, 2018
    256
    Saskatchewan
    Looooooooong day at work today so took the bike out to watch the sunset and have a brew. B3E20F4E-2431-40B2-BE7F-E8EB1C282A0D.jpeg
  10. Philip Kuntz
    Philip Kuntz Fleasy Rider Supporter
    Aug 17, 2006
    5,562
    Central FL
    DRZ 400, 3K, 6 pack of Corona, $12, chiggers, fauck, I have chiggers!
    Don't sit on the ground man! Especially near water.
    Tore the AT apart. Decided to check the air filters, it has started to burn oil. Filters looked brand new. Air box full of oil, now I know where the third air box drain line is, going to extend all of them a bit when I re-assemble. Keeping those drained is part of regular maintenance. Replacing air filters with Twin Air foam filters.
    Figured, while I have crash bars and fairings off, I will check the valves. 4 hours later, I have the cover off. Radiators, air box, throttle bodies, and coil tray need to come off. Valves are spot on at 23k. Was supposed to be checked at 16k.
    Iridium plugs are in spec, supposed to replace at 32k. Fuck it, decided to do it now, I hope to not take this shit all apart again. 2 auto parts stores, no joy. CRFs only has them for $30 each, 4 required. O' Reily's ordered some for me, $14 each and $7 shipping.
    The problem with this bike is that you cannot risk drowning it. The air box is not accessible on the trail. I guess you could, but removing my Heed crash bars would be a bitch without air tools.
  11. kelly duke 2000
    kelly duke 2000 Retired, Gone Riding Supporter
    Oct 30, 2005
    615
    crystal river, fl
    What year 950 is that again?
    Huzband, YJake, Dr.Z and 3 others like this.
  12. Buzztail
    Sep 30, 2007
    13,991
    BUZZTOPIA, 32327
    :rofl:imaposer:photog:clap
    Huzband likes this.
  13. YJake
    YJake PAR Nation Supporter
    Apr 21, 2009
    4,928
    West Panhandle, FL
    :photog
    -Jake
  14. Philip Kuntz
    Aug 17, 2006
    5,562
    Central FL
    Hey, at least if doesn't have a shimmy!:D
    But seriously, I think I will sell this bitch before I take it apart again. Lets see how the re-assembly goes. I bagged and tagged all fasteners, shouldn't be too bad. Just gotta watch routing of hoses and wires.
    I thought about taking the exhaust valves out to the long end of range, decided against it. They are exactly at spec, and I don't expect they will ever move now.
    kelly duke 2000 and Buzztail like this.
  15. ineptizoid
    ineptizoid I'm scared hold me
    Sep 19, 2006
    9,511
    Underachievement Nexus of the Universe
    Yeah, as much of a PITA shim/bucket valve adjustments are, I’ve gotta admit they rock for long service intervals. My first DRZ went 32K with one valve adjustment early in its life, and was still in spec (at the tight end) when I sold it 3 months ago. I just shimmed my new-to-me DRZ to the large end of spec, and with 16K on the engine now, I shouldn’t ever have to do another valve adjustment again. Which would suit me just fine, because shims under buckets ain’t exactly easy to get to...
    I recall valve adjustments on my old XL350R taking less than an hour start to finish, even if all 4 valves needed adjusting. Takes a good bit longer on a DRZ...
    Buzztail likes this.
  16. motomike14
    Jan 2, 2010
    3,192
    Florida
    Funny you see a lot of AT come up for sale riiiiiight around 13k-15k miles. Guys don't want to do the valves on them. For some reason, shim and buckets scare everyone off. I don't know if they make them, but a pre-filter cover the air filters could help. Apparently twin air does not make them for those filters, but maybe get one and slice it up?
  17. Philip Kuntz
    Aug 17, 2006
    5,562
    Central FL
    Uni makes pre filters, but you have to cut the factory snorkels to install them. Doesn't make them any more accessible, but lengthens the service interval.
    Yeah, I got this AT with 16k on it. I knew it was due. This bike has screw type adjustments for exhaust valves, and shim under bucket for intakes. Just one cam to remove, if needed.
  18. ineptizoid
    Sep 19, 2006
    9,511
    I get it...there’s a dozen different ways for Murphy to get involved with a shim-under-bucket valve adjustment. At the very least, the level of disassembly that’s required for the process is tedious and time-consuming; PK said it took 4 hours to get his valve cover off, and yeah everything takes longer on your first attempt—but it’s still a PITA. And of course that’s reflected in the shop time dealers charge for a valve adjustment.
    Truth is, my animosity for shims and buckets comes from the fact that I lost my valve-adjustment cherry on an RFVC engine, and it set the gold standard. So simple, even an ineptizoid couldn’t screw it up!
    Philip Kuntz and sanjoh like this.
  19. Philip Kuntz
    Aug 17, 2006
    5,562
    Central FL
    From what I have read online, dealers want about 1k to do this service. One guy here on adv said he was quoted $800 to check them, and another 2-3 hundred if they needed adjustments.
  20. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    9,640
    Cowford, Fl.
    :eek7 Dang, for that money you could have a Duc 1200 Enduro with another 60hp.
    Philip Kuntz likes this.
