Wheel bearing disintegrates - F800
Discussion in 'Parallel Universe' started by tmex, Aug 24, 2009.
  1. bross
    bross Where we riding to? Supporter
    Nov 10, 2005
    7,165
    Osoyoos, BC
  2. JRWooden
    JRWooden never attribute to malice...
    Jul 5, 2008
    6,863
    The great state of confusion
    Here in the USA for some silly-assed reason the things seem to cost $15 - $20USD each...............
    I'm not quite understanding it ..........
    Need to look into it a bit deeper..............
  3. Grinzold
    Grinzold Adventurer
    Dec 13, 2008
    59
  4. Snowy
    Snowy Long timer
    Dec 2, 2008
    2,598
    The SKF I buy in Australia cost me about $5 each. From a bearing shop. I do buy them 10 at a time. My DR 650 uses the same in the rear wheel. Different in the cush drive.
  5. Nickhob
    Nickhob Armchair adventurer
    Nov 7, 2013
    1,521
    Nyon, Switzerland
  6. Reaver
    Reaver Why am I still here?
    Aug 7, 2008
    22,196
    CR
    Quit digging for excuses and do it.
    What is the cost of failure?
    Did you find my bearing puller yet?
  7. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    6,355
    Hiding off Hwy 6, B.C.
    6204 2RSJ are the exact bearings in the spindles of most older "made in the MTD factory" ride-on mowers. Off the shelves just about anywhere in Canada for about $7.00 in the standard version. Even in my little village where the only business is the garage/post office. From buying a few either "made in Bulgaria or Argentina".
    New aftermarket spindles for them mowers will come with Chinese bearings. They last a few hours under my mowing conditions.:lol3 So I replace them with SKFs "2RSJ" in the standard version. They last longer but will still fail. Will try the C3s next time in the Explorer version.
    As for my BMW....It is a K so maybe nothing to do here but the "standard" SKF I installed in my swingarm to replace the expensive FAG/propriatory BMW bearing sure didn't last very long so I happily went back to OEMs.
    SKF has a pretty good website.....designations and suffixes/prefixes are reasonably well explained.
    http://www.skf.com/ca/en/products/b...prefixes-and-suffixes/suffixes-g-k/index.html
    Oh well....I was only looking for/crossreferencing mower bearings this morning.Took me back to ADV.....but now I know that I may have spares if one of you guys break down in Western Canada. Just shout for help, I may be home.
  8. IckyBob
    IckyBob BroManiac
    Mar 5, 2012
    2,037
    Canada
    You need a bearing removal tool?
  9. Loutre
    Loutre Cosmopolitan Adv Super Moderator
    Nov 28, 2010
    14,334
    :o)
    I let my local shop do them for me after my last bearing failure that completely ate up my OEM spacer. The independant wrencher my bike was towed to suggested that these aluminium spacers were just a failure waiting to happen. then again he didn't know how to remove the inner bearing of my rear hub (ended up doing the work myself in his shop). My first failure was at 48k kms, second at 78k kms. I'm now at 93k kms and they still look fine after installing these SS spacers. I always carry 3 spares with me just in case and plan on changing them every 30k kms if they haven't failed before.
  10. JRWooden
    Jul 5, 2008
    6,863
    I'm a good-for-nothing slacker :1drink
    I have tire change coming up ... will have some SKF Explorers by then ...
    My usual go-to for cheaper tools wants too much cash for their kit:
    http://www.harborfreight.com/blind-hole-bearing-puller-95987.html
    Kits are cheaper on ebay --- here's one:
    http://www.ebay.com/itm/5pc-Blind-H...Slide-Hammer-Removal-Repair-Kit-/262056689986
    If you already have a slide hammer I could just bring the actual pullers to save weight...
    Of course I predict the threads would not match the slide hammer you have and you'd need an "adapter"
    Have not found source for JUST the "blind" pullers but at $35 for the kit ....
  11. Reaver
    Aug 7, 2008
    22,196
    CR
    No, but you don't need a BMW either. Proper tools make a difference. They also fill the garage.
    Jimmy, my Ebay comes up all Spanish. Need to get sorted here. It's the same kit as HF I'm sure. Get that ASAP so you can use it first, then bring it here in Nov. I'll report how good it is for the bearing changers here. :thumb
  12. IckyBob
    IckyBob BroManiac
    Mar 5, 2012
    2,037
    Canada
    Well said. I just ordered the motion pro bearing removal tool. Will let you guys know how it works out in the near future.
  13. machinebuilder
    machinebuilder Long timer
    Jun 6, 2008
    1,547
    East Tennessee
    I have the motion pro set. It is one of the handiest tools I have. I use it more at work and have pulled bearings out of some very difficult spots with it.
  14. Nickhob
    Nov 7, 2013
    1,521
    Nyon, Switzerland
    Thats what I used and it was childs play :clap, literally a minute per bearing
  15. Loutre
    Nov 28, 2010
    14,334
    :o)
    I just use a tire iron and a hammer :hmmmmm
  16. IckyBob
    IckyBob BroManiac
    Mar 5, 2012
    2,037
    Canada
    I used to use a punch and a hammer. Although time consuming it does work. I found it to be a pain in the ass and the chance of damaging a bearing and or hub is high. So I spent the cash and got the motion pro kit for 115$. Money well spent.
  17. Loutre
    Nov 28, 2010
    14,334
    :o)
    Well who cares if you damage the beering since you want it out? for 115$ I could buy 23 beering if shit is hitting the fan. not second guessing your purchase or anything just my 2cts
  18. Mauser556
    Mauser556 Been here awhile
    Aug 2, 2016
    221
    Watford City, ND
    Well, count me in for a left side, hub failure. Had it sent to Woodys with grim news the hub is toast. It didn't lock up on me when it happened, but still...
  19. Dirt wolf
    Dirt wolf I'm your huckleberry
    Feb 27, 2013
    589
    Prescott Arizona
    Check them when you change tires. They are cheap and easy to replace. Don't wait for a catastrophic failure.
  20. cactus_reese
    cactus_reese Been here awhile Supporter
    Jun 2, 2008
    207
    Tucson
    The interweb just saved me from disaster. While riding home from my Globe ride, I began hearing a tock, tock, and sometimes a clunk while decelerating. I checked all over the bike and couldn't figure it out. It felt like it was in the gear box. I got on the forums and started reading a long thread by someone with similar symptoms. Finally at the bottom of the thread was the answer. When he took it to the service department, they determined it was his rear wheel bearings. I put my bike on the center stand and turned the rear wheel. It let out a loud squeak (no squeak when the wheel was loaded by the bike weight). I removed the wheel and put my finger on the inner race and turned...yep, bearings are toast! The spacer bushings also had groves worn in them. Now the wheel is in the shop awaiting parts.
