Wheel bearing disintegrates - F800
Discussion in 'Parallel Universe' started by tmex, Aug 24, 2009.
  1. XRman
    XRman Long timer
    Dec 9, 2006
    8,184
    SW Victoria Oz
    I hope you are starting to mend by now. Your jaw should mend well if they used surgical plates to fixate the fracture. You might also have cracked some molar teeth internally, which may not show up for some time afterwards. Symptoms: sensitive to cold and chewing fibrous foods.
    I had a similar crash on my DRZ when I got a screw through my knobby tyre at speed. The sudden loss of pressure made the back end swap form side to side violently. I managed to hang on from 60 mph to stationery and then topple over. Scared the crap out of me though.
    squr3l likes this.
  2. squr3l
    squr3l alpaca
    Apr 2, 2015
    282
    LA
    Thank you. I have recovered surprisingly well considering the shape I was in and now have 2 lighter Hondas to keep me in the saddle. I did in fact crack a molar but not too badly and had that repaired a while after my jaw healed. The shoulder was the worst of it. The doctors in Fairbanks didn’t think they could do anything with it, but I found a good shoulder specialist in CA that put a Ti rod in and pieced it back together. Then I put in a year of physical therapy to try to get back in shape.
    10B474A8-A5EE-491D-8DCC-8013F7F442EE.jpeg 3AA1591C-A6D4-4579-ADB4-81FA053E87CF.jpeg 5086AED4-1C11-45F9-B5C1-F9DA313485DD.jpeg 001196BA-FE9A-465C-942E-402750BDBBC3.jpeg
  3. seandiddy
    seandiddy Psshhh, Yeah!
    Jun 15, 2013
    37
    NOCO
    So the part BMW call the inner socket, which is an aluminum spacer between the sprocket bearing and the rear, right side axle bearing, has a lot of play in it, but looks normal. Should this part rattle around when installed?
  4. Motoriley
    Motoriley Still riding like crap after all these years.
    Feb 14, 2003
    3,104
    Deepest darkest burbs of Montreal
    Mine was always loose until the wheel was installed. Then it would be tight as the axle was torqued.
    QUOTE="seandiddy, post: 35225354, member: 278788"]So the part BMW call the inner socket, which is an aluminum spacer between the sprocket bearing and the rear, right side axle bearing, has a lot of play in it, but looks normal. Should this part rattle around when installed?[/QUOTE]
    Sent from my iPad using Tapatalk
    seandiddy and The Maz like this.
  5. BMuldoon
    BMuldoon Adventurer
    Dec 27, 2016
    11
    Bondi, Sydney
    Having a bearing driver makes the job a lot easier
  6. BMW-K
    BMW-K F800GS FTW!
    Nov 11, 2004
    3,202
    Smyrna, TN
    The F800GS really does love to eat bearings, doesn't it? 31,000 miles on mine and I've gone through two sets of rear bearings (just installed the 3rd), a set of front bearings, one set of steering head bearings...
    Never had any other bike go through them like that!
    seandiddy likes this.
  7. seandiddy
    Jun 15, 2013
    37
    NOCO
    Has anyone found after market seals cheaper than the Bimmer ones? I just priced new rubber for the front and rear and they are coming in at just under $100.
  8. The Maz
    The Maz Clueless and lost
    Feb 14, 2013
    556
    Medicine Hat , AB
    Any bearing shop should have seals
    On the 800:
    3- 30x47x7
    1- 25x47x7
    BygDaddee likes this.
  9. rodrigzj
    rodrigzj Been here awhile
    Dec 13, 2014
    436
    Culver City, CA
    Wow I just had a rear bearing failure this past weekend riding home from Big Sur California!
    I heard the same tick tick tick and had a slight wobble below 30mph.
    I inspected the bike and saw nothing out of the ordinary. Thinking it was a tape weight came Loose. Well coming home riding at 50 mph just cruising I felt hesitant on left turns. When we stopped I let my friends know how apprehensive of riding. Especially doing left sweep turns.
    We kept on came to a view point and inspected the bike and I found aluminum shaving on the rotor side (left) of the bike. We moved the rear tire side too side and finally saw that the rear bearing blew out. I think I have done some bad damage to the hub and the rear brake caliper.
    I was lucky we weren’t on a 80 mph pace. Or things would of been not so good. Time too tear down this rear tire and get to work.
    Here some pics!
    I feel lucky! I didn’t crash like I have read hear!
    Gotta say this is not a good feeling seeing that this is a constant problem!
    [​IMG][​IMG]
  10. squr3l
    squr3l alpaca
    Apr 2, 2015
    282
    LA
    Glad to see you made it out ok that situation in one piece. That could have been bad.
    rodrigzj likes this.
  11. DSRPilot
    DSRPilot Adventurer
    May 25, 2018
    23
    Pittsburgh, PA
    Appreciate a little help to a Noob inmate.
    I read every post of every page of this thread and the related threads as my wife has a suspected bad hub (bearings lasted 6,000 miles).
    I had a post from Woody saved that pretty much had everything on one post that a bike shop would need to repair her hub.
    the hub specs including the crush, the bearings and high speed water proof bearing grease, etc...
    It had rx= somewhere in the text, and Woody has more than 1 of those. A forced computer reboot wiped it out and I've searched for it and can't find it.
    I'm now re-reading posts looking for it.
    If you know what I'm talking about or can find it as I'm not having any luck that would be great.
  12. bross
    bross Where we riding to? Supporter
    Nov 10, 2005
    7,136
    Osoyoos, BC
    This one...
    http://advrider.com/index.php?threads/wheel-bearing-disintegrates-f800.499504/page-75#post-23949006
    or this one...
    http://advrider.com/index.php?threads/wheel-bearing-disintegrates-f800.499504/page-69#post-19074691
    I use the following google search when trying to find obscure references, as long as you can remember a key word or two.
    search terms site:advrider.com inurl:"499504"
    where the inurl # is the thread #, can be seen in the address bar of your browser, right after the thread title. Search terms are what ever (hopefully) unique search terms you are looking for. In your example I used:
    woody rx= site:advrider.com inurl:"499504"
    hope this helps
  13. DSRPilot
    DSRPilot Adventurer
    May 25, 2018
    23
    Pittsburgh, PA
    Taking my wife's wheel to a local bike shop that says they can measure and hone the hub if needed.
    I bought bearings and filled them with green grease (boat trailer bearing grease).
    I have about 5 pages of notes in a word document for the bike shop in case they need it.
    Wish me luck!
    :twitch
  14. jackalsour
    jackalsour Xennial
    Dec 14, 2010
    1,107
    Transient
    My rear brake side wheel bearing just disintegrated and I'm now stranded in Burns Lake BC en route to Alaska
    Alaska Canada shared ride report post link:
    https://advrider.com/index.php?thre...he-road-updates.1298397/page-20#post-35376434
    I suspected a wobble about 100kms before and inspected the rear wheel and axle nut/position as the chain had just been replaced by a mechanic 228kms before. I watched the 2 mechanics swap the chain and none of us suspected anything at that point (unfortunately we didn't remove the rear wheel to inspect the bearings, it was Saturday afternoon of a long weekend)
    Rear hub, brake, spacer etc damaged. I think I may have to tow the bike back to Prince George and fly out
  15. outty
    outty (☞゚ヮ゚)☞
    Feb 4, 2018
    323
    Edmonton, Alberta
    What year of bike do you have?
    This is scary to me, considering that the bearing wasn't obviously starting to go, it just goes... that's borderline justification for a class-action lawsuit against BMW.
  16. Motoriley
    Feb 14, 2003
    3,104
    Get on the web and buy a used rear wheel.
    Fastest way to get back on the road.
    QUOTE="jackalsour, post: 35376659, member: 188596"]My rear brake side wheel bearing just disintegrated and I'm now stranded in Burns Lake BC en route to Alaska
    Rear hub, brake, spacer etc damaged. I think I may have to tow the bike back to Prince George and fly out[/QUOTE]
    jackalsour likes this.
  17. jackalsour
    jackalsour Xennial
    Dec 14, 2010
    1,107
    Transient
    2014 with about 22k kms. First 10k or more was strictly street and since last summer 50/50 off road. All bearings were inspected before this trip at about 15k kms
    I also had a 2012 that I rode all over Europe and Canada without issue. Rear bearings got a bit crunchy at 42k kms so there were replaced in June 2017 (after over 5 years)
  18. Motoriley
    Feb 14, 2003
    3,104
    Hey Jack. Forgot to say in my first response that I feel for you. Had the final drive crap out on my 1150 GS in Saskatchewan. Nearest dealer a day away. Hope you aren’t on a tight deadline. Used rear wheel should be 500 CDN. Good luck.
    QUOTE="jackalsour, post: 35376794, member: 188596"]2014 with about 22k kms. First 10k or more was strictly street and since last summer 50/50 off road. All bearings were inspected before this trip at about 15k kms
    I also had a 2012 that I rode all over Europe and Canada without issue. Rear bearings got a bit crunchy at 42k kms so there were replaced in June 2017 (after over 5 years)[/QUOTE]
  19. outty
    outty (☞゚ヮ゚)☞
    Feb 4, 2018
    323
    Edmonton, Alberta
    Welp, I'm changing the bearings ASAP in that case - I have a 2014 w/ about 40K on it. I check the lateral play pretty much everytime I check my tire pressure and it's solid so far, but that's no indication that I'm safe.
    Now to find out what kit I need to buy.
  20. Motoriley
    Feb 14, 2003
    3,104
    All 5 bearings are 6204. Get a bearing puller, heat gun, cheap IR thermometer. Doing all 5 takes an hour once the wheels are off. New seals as well. Don’t buy at BMW hit your local bearing supply. Check the aluminium spacers as well. If you do a lot of dirt they wear and then the seal lips having nothing to rest against. The early 800s had manufacturing issues for sure. I have seen the bearings go on a lot of bikes of all brands though. Dirt, pressure washing all contribute. I check mine by feel every time the wheel is off. If they feel even slightly wonky it is time to change.
    QUOTE="outty, post: 35376829, member: 408553"]Welp, I'm changing the bearings ASAP in that case - I have a 2014 w/ about 40K on it. I check the lateral play pretty much everytime I check my tire pressure and it's solid so far, but that's no indication that I'm safe.
    Now to find out what kit I need to buy.[/QUOTE]
    ROYAL COACHMAN and outty like this.
