wheel bearing help. Nov 15
Discussion in 'The Garage' started by burpnbill, Nov 4, 2019.
  1. burpnbill
    burpnbill Adventurer
    Mar 3, 2016
    96
    RI
    ive been reading how to replace mine. rear started making noises yesterday. I see the part # for the bearings is 6204-2RS. I been noticing some places have p/n 6204-2RSH or 6204-2RSC3. are those different or the same size? also, anyone know of any local places to get the steel wheel spacers, mine are grooved. I found them from the UK for $50 for all 3.
  2. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    2,981
    Beaverton, OR
  3. burpnbill
    Mar 3, 2016
    96
    RI
    Cool thanks
  4. anonny
    anonny What could go wrong?
    Mar 20, 2007
    6,700
    Beautiful Revelstoke BC
    The 6204 relates to the bearings physical size (ID, OD and width) the 2rs means 2 rubber seals, and the C3 means a tighter tolerance bearing if I remember correctly.
  5. burpnbill
    Mar 3, 2016
    96
    RI
    So i can get it with or without the C3?
  6. ragtoplvr
    ragtoplvr Long timer
    Oct 18, 2007
    10,546
    central USA
    C3 is a looser clearance, absolutely essential on alternator. The alternator can easily hit 12,000 RPM, the bearing heats and a C2 will seize. MUST BE C3
    Rod
    snglfin likes this.
  7. Andiflip
    Andiflip Adventurer
    Mar 16, 2006
    53
    Dumaguete City , Philippines
    C3 is the standard tolerance.. C2 is tighter tolerance... most bearings are manufactured to C3 tolerance.
  8. bwringer
    bwringer Gimpy, Yet Alacritous
    Jan 22, 2008
    3,020
    Indianapolis
    C3 will be fine. These are standard industrial bearings, made for far higher speeds and loads than they ever see in motorcycles.
    Motorcycle wheel bearings fail from improper installation (installed too deep or in the wrong sequence so they're side loaded, or pounding on the inner race) or from water/dirt getting in. They never really actually wear out.
    #8
    ohgood likes this.
  9. fast1075
    fast1075 Not a Lemming Supporter
    Dec 28, 2013
    1,788
    Flaw'da
    Truth! Or a crushed spacer from overtorque.
    #9
  10. ohgood
    Sep 21, 2010
    9,503
    alabama
    take em to motion industries and get a pair for $14
    they'll last as long as they don't get wet
    #10
  11. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    7,271
    below the sea
    Make sure you get a real brand. Most are nasty crap. An industrial supply house anywhere in the world will have both. The price difference is not great - usually you will pay less than any retail, especially a car or motorcycle orientated one.
    Just for asking, I usually get 70% discount.
    #11
  12. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,649
    Hiding off Hwy 6, B.C.
    SKF6204 2RSC3? I don't have to replace them so often now in the blade spindles on my riding mower.Spindles came with cheap Chinese bearings and only good for a year of beating on them cheapos.SKF C3s are good for 2-3 years.
    Must be one of the most common bearing in the world the 6204.
    Spacers? Very important as they set the preload.I'd go OEM unless a machine shop could guarantee replacements are exactly to OEM specs.
    #12
  13. burpnbill
    Mar 3, 2016
    96
    RI
    Ordered the skf6204, and new seals.
    #13
  14. burpnbill
    Mar 3, 2016
    96
    RI
    Is this grease ok? Or should i get some that says marine use?
    #14
  15. dtysdalx2
    dtysdalx2 Knowledge is horsepower
    Aug 1, 2004
    22,615
    Moneyapolis, MN
    There have been a lot of ebay and amazon knock offs lately. Not genuine OEM stuff.
    #15
  16. HeavyMetal
    HeavyMetal Been here awhile
    Oct 12, 2009
    342
    Kimberly, ID
    That grease is fine.
    Unless you're riding in a lake.
    #16
  17. burpnbill
    Mar 3, 2016
    96
    RI
    Ok need advise. Drive side bearing came out easy. Brake side was the one destroyed, everything came out except the OD part of the bearing housing. There's nothing to grab onto to bang out from other side. Was trying to create a lip with dremel to get some purchase until battery died. Waiting for it to recharge. Any ideas.
    #17
  18. burpnbill
    Mar 3, 2016
    96
    RI
    This is what the Breakside one look like when it came out. Notice the bad Groove in the spacer.
    #18
  19. katbeanz
    katbeanz earthbound misfit, I Supporter
    Feb 12, 2005
    9,716
    Kansas City
    Driven at an angle, 1/2" round stock or a long chipping hammer bit & alternating sides might catch enough to walk it out. The hub is a big enough heat sink and the race is small so hard to get enough temp difference for thermal expansion. Some cans of computer duster if held upside down will spray liquid freon.
    https://en.wikipedia.org/wiki/Freeze_spray
    If something was stubborn or big I'd usually stick weld a bead on the inside of the old race, when cool it shrinks it enough to often fall out. Sometimes a slide hammer with a hook works.
    #19
  20. burpnbill
    Mar 3, 2016
    96
    RI
    Yeah theres not enough to grab with the rod. May try welding a bead then may give me something to bang on.
    #20
