Wheels bearing aftermarket part no?
Discussion in 'Dakar champion (950/990)' started by Mane, Nov 12, 2019.
  1. Mane
    Mane Been here awhile
    Apr 16, 2002
    845
    Guatemala
    Hi Folks,
    I looking to replace the wheel bearings (Front/Rear) on my KTM 990 Adv 2008 and wonder if anybody knows the equivalent parts in NSK? I've and local NSK dealer I would like to try my luck before paying OEM prices...
    Bonus points for the seals.. hehehehe
    Regards,
    Mane
  2. zimtim
    zimtim Been here awhile
    Aug 15, 2012
    101
    UK
    The numbers are on the side of the bearings.
    All the different manufacturers will use the same numbers (hopefully)
    Also double check the.bearings on your cush drive. As for some reason there were different sizes between the.years.
    Mane likes this.
  3. charlie264
    charlie264 Long timer
    Oct 27, 2007
    11,793
    Blighty
    Go Japanese if you can get um.
    Mane likes this.
  4. uk_mouse
    uk_mouse Aquatic adventurer
    Jul 20, 2006
    1,940
    UK
    950/990 front 6906, rear 6205.
    The sprocket carrier bearing is different, old style is 3206 (expensive) new style is 6006 x 2.
    Front dust seal 35x47x7
    Rear dust seal 30x52x7
    Crazygreek and geometrician like this.
  5. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,136
    Mill Spring, NC
    Also... bearing # is right on the parts diagram. Rear is 6205RS.
  6. uk_mouse
    Jul 20, 2006
    1,940
    UK
    Good point! I edited my reply cos I made a typo in one of the numbers. All the wheel bearings should probably be of the 2RS variety (ie 2 rubber seals) although I've used 2Z (2 metal shields) in the past when only those were available.
  7. Mane
    Apr 16, 2002
    845
    Guatemala
    Thank you very much folks!
    Regards,
    Mane
  8. Mane
    Apr 16, 2002
    845
    Guatemala
    When you say old style do you mean 950?
    Regards,
    Mane
    #8
  9. zimtim
    Aug 15, 2012
    101
    UK
  10. Mane
    Apr 16, 2002
    845
    Guatemala
    While replacing the wheel bearings do you guys also replace the spacers?
    I'm thinking about leaving the old ones (since KTM don't sell separatly). What do you guys think?
    Regards,
    Mane
    #10
  11. Boatman
    Mar 9, 2005
    14,136
    Mill Spring, NC
    Unless something has caused damage to the spacers there really isn't any reason to replace them.
    #11
    Mane likes this.
  12. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,236
    SWEDEN, Norsjö
    Have yet to change a wheel bearing that I have installed myself.
    If cleaning and replacing seals and spacers and every now and then popping of the seal on the bearing to add some grease they should last a very long time.
    If replacing them I use a rotary tool to notch the spacer between bearings so it's easier to get them out the next time should that day ever come.
    And as far as spacers go I'm quite sure they can be bought separately. Know I have replaced mine once the groove in them got a bit big, they are just aluminum.
    /Johan
    #12
    Mane likes this.
  13. Boatman
    Mar 9, 2005
    14,136
    Mill Spring, NC
    Hmmm, which spacers? Outer spacers or the internal?
    I was talking about the inner spacer.
    I think Dirty is talking about the outer spacers.
    #13
  14. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,236
    SWEDEN, Norsjö
    Inner spacer tube between bearings can be bought separately also.
    60009014000
    BEAR. SPACERTUBE FRONT 03
    But if replacing everything the KTM kit used to be a good price at least. Was a few years since I compared prices with both buying separate parts or aftermarket.
    /Johan
    #14
    Mane and Boatman like this.
  15. uk_mouse
    Jul 20, 2006
    1,940
    UK
    Probably, but I'm not sure exactly when they changed. The definitive way to find out which you've got is to see if there are two bearings in your sprocket carrier, I suppose.
    #15
  16. desmorado
    desmorado Been here awhile
    Sep 3, 2013
    112
    Estonia
    Hi, for example the front bearing is more than just 6906 RS. It`6906 DDU2CG23S6NM - where the CG23 means that the inner diameter is reduced by 23 hundrets of mm to ease the axle removal/refitting. If one puts ordinary 6906 bearing in place, hammering the axle out/in is possibly foreseen. Same applies to rear wheel.
    BR
    #16
    Dusty, Mane and DirtyADV like this.
