1. eNewsletter Sign Up
When to change brakes?
Discussion in 'Asia' started by Taelan28, Apr 20, 2012.
  1. Taelan28
    Taelan28 Thunder
    Dec 26, 2009
    60
    Yongin South Korea
    Hey I got a 125cc Daelim Daystar. Its what I need and what I can handle.
    Im concerned about the brakes. I've ridden over 10,000km and haven't changed the brakes. When they start to go bad will they cut out quickly or will I have a few hundred km to go before I crash?
    Thanks in advance.
  2. Taelan28
    Taelan28 Thunder
    Dec 26, 2009
    60
    Yongin South Korea
    Wtf 54 views and no one can tell me what the warning signs are to change tbe brakes or a mileage number?
  3. Tosh Togo
    Tosh Togo Long timer
    Nov 21, 2010
    1,594
    There is no "mileage number" for brakes- they wear out due to use, not time.
    If your bike has a disc brake front, eyeball the thickness of both pads: there should be a thickness spec for them, and many brake pads also have a deep groove across the face of the friction material that's a wear indicator. It's common for one pad to wear much faster than the other; once either one becomes too thin they both need to be replaced together, as a set.
    Your bike's rear drum is similar, although to eyeball the thickness of the brake lining the wheel needs to come off first...it's possible that it may have a wear indicator of its' own: it's usually a little pointer on the brake-shoe actuating shaft.
    It's RTFM time for more info about how thin is too thin. :deal
    Most people just take a peek at the rear brake lining when the wheel's off for a tire, take note if & when it starts getting thin, and then replace 'em... but unless you ride like a pirate, the rear brakes normally last as long as the bike does. :D
    Unless it's due to contamination, they do not suddenly "wear out", but the warning signs of waiting way too long is the sound of metal-on-metal when the brakes are used. :cry
