Photos of a Ricochet skid plate on a California model with the canister removed. Went the easy route and capped the throttle body line with a vacuum cap where it meets the canister.
Looks like fun and green stuff in the background. It'll be a while here. About 3' of snow on the ground.
No fair Goofyjumper. It's been snowing along the Front Range of the Rockies for three days. We measured twenty inches of wet snow in the yard today. The XT250 sits idle in the garage pining for Spring.
Meanwhile in my bit of Oz it's 90 something degrees american with 70% humidity. Got caught in a storm a couple of days ago and completely drenched, even with water across the road in a few places (only shallow mind) the XT chugged along without any complaint.
It's so muddy here (Houston Texas) that I can not get onto most of the trails so today I rode to the battleship Texas (1914 - 1948) and played on sand with the XT. Vince
Just got my oversize tubes (but standard weight, Michelins) for my new, oversize, tires. Here are their weights (in the box, to carry as spare): Front, 90/90-21: 19 oz Rear, 130/70-18: 23.6 oz Did anybody else weigh their spare front tube?
Ok, I am wondering about the FI system on the XT. Most systems are about the same, my TU250 had a cat and an oxy sensor, as does my SR400. The Suzuki system worked very well, it had oxy sensor, intake air temp, two throttle position sensors for the two throttles, one cable operated, one motor operated by the ecu (like a CV carb setup I suppose), engine temp sensor, intake pressure sensor, crank sensor. It was not set lean from the factory because it had a cat, air injection and was fuel injected. My SR400 has a cat, air injection, a temp sensor for the engine and intake air, a fuel pressure regulator vacuum port, throttle position sensor, oxy sensor, crank position sensor and an idle speed control (stepper) motor. It also has a speed sensor, although I do not know what it is used for. What does the XT have? Must have a crank sensor, throttle position sensor, engine temp sensor at a minimum and should have intake pressure and temp sensors. Does it have an idle speed control device or is that static? Any sort of fuel pressure regulator tied to the air intake? Single throttle cable operated with position sensor? I guess it has no cat and no oxy sensor, which seems odd. Anyone know what the wr250 has?
As you said , all Injection Systems are more or less similar, with the XT's on the "simple" side of it (no cat., no O2 sensor). Looks like it satisfies EPA norms that way (i'd be curious to know exactly how...). -The TPS, Intake Air Temp. and Intake Vacuum sensors are all integrated in ONE module bolted to the right of the throttle body. -On top-rear of it is bolted the Fast Idle Solenoid (actuated by the ECU, according to engine temp.) It controls an air bypass inside the TB. Hot idle speed can be manually adjusted with the big philips screw beside the cable pulley. -There is no secondary throttle butterfly (and no corresp. tps). -The Crank Pos. Sensor is the usual pulser-type (part of the stator assy.) -The Engine Temp. Sensor is screwed to the back of the cyl. head, adjacent to the int. rubber. -The Pressure Regulator is part of the Pump. The fun of it is the AutoDiagnostic system. It will instantly flash a problem's code number, and even provide detail analysis of that problem, once put in DIAG mode. I checked this by unplugging different devices, and it works great. The un-fun part is that neither the main sensor module, nor the idle solenoid are sold separately ($$$...Honda sells such items for about 80$...).
Thanks very much for the info! And the 300 ohms in the engine temp sensor wire makes everything good if you open things up a bit? A 500 ohm pot might be interesting to try, make adjustments on the fly and see how the bike responds. I had a setup like that on my TU for a bit but noticed no change until it was so rich it ran really poorly. It almost seems like Yamaha put FI on the XT to make it run better, not to meet emissions. No choke, no super lean burn.
Brett, I hate noise, so I wont touch the muffler. With the spark arrester removed, it makes a much "healthier" sound, and should be enough to "open it up", but...not for me... Adding more than 500 ohms to the ETS made mine way too rich, too, so I went down to 300, and is satisfied that it wont hurt the engine. In April, I'll see how it affects mileage, plug color in more detail. A better idea would be a Power Commander (but it would KILL my KISS pride...). And yes, the engine runs great, stock . I just wanted it to run a tiny bit richer, knowing they are all running hot and lean nowadays. I have the shop manual, here, with all the data on the FI. A very simple system to understand and test, once one has a basic grasp of its operation. I hear you'll buy yours later. Why not ask for a carbed 2012 ? They are still available here in Canada. I could have asked for one, but was too much in a hurry to ride the 2014 in stock! The carbed one you'd already know by heart, just like the 225... Thinking about it , I'd be just fine with the simpler carb version.
I do not like noise either so my plan is to drill out the muffler like the Z1-mod but using a hole saw the same OD as the outlet and then packing the muffler with muffler packing. I think that will take out some of the "bark" but allow a little freeer breathing. Vince
I tried this on a 80ish bike of mine. Spent a whole summer trying to get it right, and reliable. At the end, I came back to stock. There was always something getting loose, blocked, fluffing out etc.. Modifying a stock muffler can become a more troublesome adv than presumed, if one wants both the cake, and the eat. But who knows...
Brett, Reading back, I see your TU has both a cat, and an O2 sensor. With such FI systems (called closed-loop), the O2 sensor will "correct" any enrichening attempt (ex:300 ohms resistor) to pre-determined values. So that mod would be useless, indeed. When the R value becomes way too high for the sensor to make the appropriate correction, the ECU loses control and the mixture gets suddenly very rich. Modding a closed-loop FI system is a very sophisticated proposition. In my opinion, it should never be attempted. But the XT can take it, and feel better.
Not really true. The oxy sensor only has control at mid throttle, mid rpm's (where the epa tests it!). Idle, full throttle (where the TU spent most of its time) the oxy sensor was out of the loop. My SR400 is like that also, narrow band sensor, limited adjustment range, and only operational at mid throttle and rpm's. People tend to think bike systems are like car systems, in control all the time and they are not. It sure would be nice if they were, automatic adjustment from idle to full throttle red line with open exhaust and air intake, or stock, the ecu would just set the air fuel ratio correctly. The bike systems use maps and just use the oxy sensor (if equipped) for fine tuning over a narrow range.
I never said your bike's ECU could cope with any shit you'd throw at it. Can you read English? I never said your O2 sensor had a "wide operational range", either. Quite the contrary. Again, can you read English ? You sound like a guy just out of wikipedia, with not much real knowledge of the things you are talking about. I wont comment anymore.
You seem to be wound up a bit tight for some reason. I was just pointing out that the resistor mod (changing the engine temp sensor readings) works even with a cat and oxy sensor, but at mid throttle and mid rpm the oxy sensor will adjust or try to adjust the mixture to what it wants to see. Not a problem at all because its at mid throttle and mid rpm's, not maximum power points, or at idle. I have been messing with fuel injection on bikes and cars since its been out. Here is what you said: With such FI systems (called closed-loop), the O2 sensor will "correct" any enrichening attempt (ex:300 ohms resistor) to pre-determined values. So that mod would be useless, indeed. When the R value becomes way too high for the sensor to make the appropriate correction, the ECU loses control and the mixture gets suddenly very rich. And I said its not true because its not, its only true at mid throttle and mid rpm's, otherwise a resistor mod DOES impact things just as much as on a system with no oxy sensor. You need to differentiate between narrow band part time systems and full time wide range systems. If you change the coolant temp sensor readings on a car, you would get no change once in closed loop. A bike is not often in closed loop, and any 250cc bike is rarely in closed loop, maybe at 40 to 50 mph cruise... No need to get upset about bike talk. I did not say you were stupid, or an ass, just that what you posted above was not correct. Many people think the oxy sensor is always in control and its not, and when it is in control, it does not have much adjustment range.
Finally got around to weighing my spare. It's 32 oz. No wonder I couldn't stuff it in the spare tool pouch spot! http://www.amazon.com/gp/product/B008DE44L6?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
