Where are your XT250's...let's see them.
Discussion in 'Thumpers' started by MEDIC-0372, Nov 4, 2008.
  1. 8gv
    8gv Long timer
    Nov 22, 2009
    4,349
    CT exile now in NH
    There are four Yamahas in my stable:
    XT250
    Piano
    Guitar
    Outboard motor
    The XT sounds the best.
  2. CloudSplitter
    CloudSplitter Putterer
    Apr 6, 2014
    1,257
    Northern West Virginia
    Ha. We also have a Yamaha piano/synthesizer and guitar, but our outboard is a Honda.
    As with you, nobody can play them well enough to make 'em sound better than the XT.
    Dualsport Chic and Cyclepath like this.
  3. Cyclepath
    Cyclepath Lost wanderer
    Mar 17, 2006
    2,231
    SW. Wa. state
    I had a Buffet Champion saxaphone when I was young........does that count lol :-)
  4. Jolly Roger 250
    Jolly Roger 250 Adventurer
    Jul 16, 2018
    39
    Lawrenceville, GA
    AdventuresofJB2, you mentioned lowering your XT250 in the link. How did you overcome the rear tire rubbing when bottoming out. I lowered mine 1 inch (I am 5'2") and if I am moderately agressive, my back tire rubs.
  5. EWCMR2
    EWCMR2 Adventurer
    Mar 5, 2019
    41
    SoCal
    E818ED7D-7E39-43EB-9630-1299229A58EA.jpeg My other Yamaha. Well, not mine but I push the buttons on occasion. It make all the bikes seem cheap.
  6. AdventuresofJB2
    AdventuresofJB2 Dystopian Scavenger
    Jul 5, 2014
    81
    Seattle, WA
    I lowered it one full rotation on the back spring for my wife's bike. She hasn't reported any issues with bottoming out, but she weighs a lot less than me. Also, we aren't super aggressive, as our bikes are usually fully loaded with camping gear, etc.
  7. CloudSplitter
    Apr 6, 2014
    1,257
    Another nice day for a ride. This time I went where I knew it would be good, because I'd ridden this double-track in the opposite direction:
    Some puddles, but all except the last one could be ridden around. It was a little one, not this group. IMG_20191028_161830725.jpg
    Unfortunately, the sun was in the face, riding south (that photo shows the bike facing northerly, because I rode back north after going around.
  8. black 8
    black 8 motographer
    Dec 11, 2016
    3,792
    33.202738 -117.384040
    headed out to the CABDR tomorrow on my vintage '81 XT250...
    Skooter, manx16, ONE2NINE and 10 others like this.
  9. EvanJ
    EvanJ Adventurer
    May 13, 2019
    15
    Minneapolis
    Chyeah man, it's nice there
    Dude... 28psi? That's crazy. If I ride dry street I'm never at more than 22F 26R. If in sand, I'm as low as 12F 17R. Snow, 8F 17R.
    If I catch a hard pack gravel road with 1-2" of sand on top, I have to lower front to 18/19 from 22 otherwise steering will wander. On deep loose shale/gravel/river rock/sand/wet soft dirt/mud, 22 is straight up dangerous for me and my bike.
    I ride at minimum a couple hours everyday 7 days a week; if a full day ride on mixed terrain I will easily adjust pressure multiple times a day. Obviously if their hot from the street it turns into a guessing game real quick, but it is possible to make an educated guess. If in the mountains, my pressure will often not increase riding 1st-3rd gear stuff off road.
    2 or 3 psi make a world of difference, especially up front. How much do you weigh? I'm 220 naked, easy 300 maybe 315 with all gear. You're missing out on massive amounts of traction regardless of tire especially off road at 28psi, I'm 100% sure of it.
  10. CloudSplitter
    Apr 6, 2014
    1,257
    Well, I'm also about 220 lb, these days, down from near 250 at times, and I do lower tire pressure when I want more traction, which isn't often. However I hadn't thought of lowering front tire pressure to prevent deep sand/gravel from grabbing the wheel and turning it. Guess this ol' dog's still larnin' some new tricks.
  11. AdventuresofJB2
    Jul 5, 2014
    81
    Seattle, WA
    Nice you made it! Are you hand pumping your tires back up all the time, or did you get one of the electric pumps I showed you?
  12. EvanJ
    EvanJ Adventurer
    May 13, 2019
    15
    Minneapolis
    I play with the front pressure a lot more than rear, it is super helpful, try it out!
    Still using the mountain bike hand pump yeah.
  13. Jolly Roger 250
    Jul 16, 2018
    39
    Lawrenceville, GA
    Thank you for the info. I had put lowering links on mine, which I guess changes the whole dynamics of the bike. I also lowered the front 1 inch as well. I have looked at the back spring, but it looks like a lot of work to get to. Maybe I need to put the bike back the way it was and just do the adjustment with the spring.
  14. EvanJ
    EvanJ Adventurer
    May 13, 2019
    15
    Minneapolis
    It comes out pretty easy, took me about 3 hours to disassemble, adjust preload with a vice/pipe wrench, and re-install the first time.
  15. CloudSplitter
    Apr 6, 2014
    1,257
    You don't need to remove the rear spring to adjust it. Just remove the right side plastic, then use a punch or, say a 1/4 inch diameter bolt or rod, and a hammer to loosen the lock nut, rotate the adjusting nut, then re-tighten the lock nut.
    I adjusted mine as far as the owner's manual recommends, since I'm tall.
  16. flei
    flei cycletherapist
    Apr 1, 2013
    10,605
    Western Mass.
    +1 Yes this works (though it is a bit of a pita).
  17. Jolly Roger 250
    Jul 16, 2018
    39
    Lawrenceville, GA
    Guessing it is a PITA anyway you look at it.
  18. EvanJ
    EvanJ Adventurer
    May 13, 2019
    15
    Minneapolis
    The threaded rings (nuts?) on my rear shock were a bit frozen when I tried to adjust it on the bike, a 2012 model. Took a big ass pipe wrench and all my strength to undo it on the bench.
    A nice time to assess if your stock spring is really doing it for you, or if aftermarket is necessary for setting the appropriate sag.
  19. Halifax614
    Halifax614 Misadventurer
    Apr 12, 2015
    120
    Cairns, Australia
    Copying the example of my DR650 & probably many other bikes, I did this simple modification to the XT250; took only an hour or two to complete. This makes rear wheel removal & replacement much simpler due less parts to juggle with overall, & chain tensioning becomes really easy. Plus one less tool (22mm spanner) to carry.
    Support bike vertically on a central stand, support wheel with a lump of wood or whatever below & remove 19mm nut & fittings from left side & pull out rear axle from the standard r/h side & insert a suitable temporary steel rod right through to hold the wheel loosely in place. Note:- the rear axle will fit quite happily either way from left or right; same diameter all the way.
    Now using your bench drill & normal procedures, step drill to final size a 6.5mm/1/4" hole right through a pair of opposite flats on the 22mm hex head of the axle taking care to space the hole mid-way from base to top.
    Take the l/h adjustment cam, making sure the numbers are on the outside! & carefully tack weld it to the axle head in two or three spots either using the original washer in place, or as I did, one with a reduced OD that matched the axle head diameter. A quick spray with cold galv. & silver paint & she's done... Note:- It doesn't really matter if the cams get swapped about L to R; they are mirror imaged. The adjustment numbers are on the flat face of one & the rounded face of the other. You'll either go CW to increase tension (as mine) or CCW if the cams are swapped L to R. See the DR picture as below for CCW to increase tension.
    Now insert the axle back through the swing arm & wheel from the left side & refit the other cam, washer & nut on the right. Initially tighten only enough to hold it all in place. From behind the bike, with the blade of the phillips screwdriver through the new hole you can now easily set the chain tension by rotating the axle & cam unit as one with the left hand whilst pushing the wheel forward with one knee. Count the dimples & set the right cam similarly. Hold the axle head with the screwdriver & tighten the nut fully & she's done. Simple isn't it?
    Pump the rear brake before riding if you did remove the wheel.
    Modified rear axle & cam 1 at 40%.jpg Modified rear azle & cam 2 at 40%.jpg These two photos at left show the result.
    DR 650 axle & cam.JPG And here is the DR for comparison as ex: factory.
    And referring to the previous few posts re: adjusting the rear shock spring, CloudSplitter's method with a long 6mm or 1/4" rod is the way to go. Take the weight off the rear wheel though.
    CloudSplitter and randypower like this.
  20. bikemoto
    bikemoto Tyre critic
    Oct 24, 2004
    4,398
    Nelson, New Zealand
    Good write-up, but it seems like a lot of unnecessary complication to me. There no need for an implement through the axle head to set the tension as it is simple enough to push on the flats of the snail cam with your fingers. And there's no need to hold the axle head when tightening, either: the main reason to weld the snail cam to the axle is to use the cam and swingarm pin to do that for you, and ditch the 22 mm spanner.
    It takes longer to set up your welding gear than it does to buzz on a couple of tack welds. Pull the axle, remove the washer, stick the axle and cam in a vise, weld it, put everything back where you found it. Job done.
    glitch_oz and randypower like this.
