    Dismiss Notice
Where are your XT250's...let's see them.
Discussion in 'Thumpers' started by MEDIC-0372, Nov 4, 2008.
  1. randypower
    randypower Been here awhile Supporter
    Jul 2, 2016
    299
    Spring Branch, Texas, USA
    Probably very handsome and witty too, I imagine!
  2. buckthedog
    buckthedog Eastbound and down
    Oct 21, 2011
    790
    South Mississippi
    Well, shucks... My wife thinks I am. Thank you for the compliment :jack The older I get, the better I was.
    randypower likes this.
  3. bikeneil
    bikeneil Been here awhile
    Apr 12, 2010
    630
    Southern Ohio
    I can’t remember for sure the valve clearance on the XT250, is it .05 - .10 mm intake and .10 - .15 mm exhaust?
    Thanks in advance for any info.
  4. NicKel78
    NicKel78 Been here awhile
    Jun 1, 2020
    109
    Kerrville, TX
  5. bikeneil
    Apr 12, 2010
    630
    Southern Ohio
  6. EvanJ
    EvanJ Adventurer
    May 13, 2019
    47
    Minneapolis
  7. flei
    flei cycletherapist
    Apr 1, 2013
    10,912
    Western Mass.
    It’s a really good ride report! Testimony to what these bikes (and their riders) can do. I’d urge all XT250 owners to check it out!
  8. AdventuresofJB2
    AdventuresofJB2 Dystopian Scavenger
    Jul 5, 2014
    83
    Seattle, WA
  9. CloudSplitter
    CloudSplitter Putterer
    Apr 6, 2014
    1,329
    Northern West Virginia
    Nice RR. I hope you get as much fun out of those new bikes as you did out of this one. The fuel injection in the WR will be great in the mountains, as it is in the 2013 and later XTs. Looking forward to your next trip RR.
  10. Mdh01
    Mdh01 Been here awhile Supporter
    Jan 26, 2014
    160
    Rochester, MN
    I recently picked up a 2013 XT 250 and find the front brake really poor. Very little stopping power, so little grab that I can't lock up the front tire on pavement (which isn't all that bad!). Wondering if others experience this with the front brake?....rear brake works fine.
  11. NicKel78
    Jun 1, 2020
    109
    Kerrville, TX
    I have a newer bike but had a 225 back in the day and the brakes have always been spot on with both. Have you tried flushing and putting in new brake fluid? That stuff is hygroscopic and should be changed on regular intervals. Once it starts absorbing water then stuff starts going south and braking power will fade off. Also check the soft brake lines to make sure there are not any damaged sections that are swelling when the brakes are applied which would also decrease braking power.
    Mdh01 likes this.
  12. Graybush
    Graybush I like turtles.
    Nov 27, 2013
    878
    Shi Tpa Town, Pensacola, FL
    Pull back the boot at the base of the brake lever and check the bolt circled in red. If it backs out, it will cause the front brake to be really soft.
    buckthedog, nvklr and NicKel78 like this.
  13. Mdh01
    Jan 26, 2014
    160
    Rochester, MN
    Thanks! Here’s a photo of mine. Looks like it might be backed out a little.
  14. EWCMR2
    EWCMR2 Adventurer
    Mar 5, 2019
    48
    As far north as you can get in the southeast
    Nope. Sounds like you have a problem. Is lever firm or spongy?
    If it’s firm I’d look at glazed pads/rotor or piston stuck in caliper.
    If spongy - bleed system to eliminate air as culprit, the move on to internal master leak.
    NicKel78 likes this.
  15. Mdh01
    Jan 26, 2014
    160
    Rochester, MN
    Thanks. Brake lever is firm and feels like proper pressure. I wondered too about glazed pads or a an issue with the disk.
    The pads may not have been broken in correctly by the previous owner. I will replace the pads and clean the disk as a next step.
    EWCMR2 likes this.
  16. sonnystile
    sonnystile Long timer Supporter
    Mar 8, 2013
    1,198
    I’m about to list my 2017 in the flea market with just over 500 miles...
  17. gseur
    gseur Been here awhile
    Feb 13, 2009
    669
    Valais, Switzerland
    Just a few pics of my Tricker to get in
  18. buckthedog
    Oct 21, 2011
    790
    South Mississippi
    Never knew that about the bolt. Thanks!
  19. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    10,198
    Southern New Jersey
    How much gas does that hold?
    It looks much better then what we get with its silly fake radiator guards....
  20. gseur
    Feb 13, 2009
    669
    Valais, Switzerland
    Only 6l included 1,9l reserve.
    That gives a range between 130 & 160km before reserve. Enough in the Alps. I’m looking for a little additional tank on the rack (Rotopax but perhaps too big) or, why not, each side of the tank, under the little side covers. There is place for about 3/4l each side. Would be a neat solution.
