Where are your XT250's...let's see them.
Discussion in 'Thumpers' started by MEDIC-0372, Nov 4, 2008.
  1. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,765
    日本
    Most people are gearing up, not down. Other than at 60 mph+ on the highway, where it gets a bit too buzzy, I'm happy with it as well. If I only did back roads, no issues.
  2. Milano.B
    Milano.B Been here awhile
    Feb 15, 2004
    104
    Southern California
    Agree, Yamaha engineers settle on the sweet spot for 15t CS. Yes we would love the 6th gear transmission but that might be next life.
    Here are pics of that Double Black Diamond Trail, both riding XT225
    It is Much Steeper that it appears (see tree angle on right center).
    We stop to inspect the terrain (looking down)
    My friend has 14t CS and mine is OEM 15t
    Below picture, this is what we have to Climb, Going UP and UP :eekers :eekers :eekers... hiking up midway with riding boot was difficult.
    Essentially we are riding on the ridge line.
    There is no option to go back as it there was a super steep hill.
    His XT climbed up no problem (real Serow).
    Friend is a better rider so he rode mine up with some struggle (including a few Unintentional wheelie).
    After that ride I developed a Deep Respect for the XT :thumb
    Although I don't do Black Diamond trail anymore but still ride Easy trail with the XT250.
    Even on new 'easy trails', certain portion of it, it would be nice to have 14t...
    16t should be OK on the black top but not an option on dirt.
    On the freeway, I can feel some slight power increase for the XT250 compared to the XT225.
    No problem cruising 65-70mph.
    NicKel78 and twinrider like this.
  3. twinrider
    Aug 20, 2002
    17,765
    日本
    Black Diamond looks fun. When I went from a DR250 to a KTM 350 EXC-F it me go from Clark Kent to Superman on stuff like that.
    I also tried the 14T on my XT. Great on dirt, but not on the highway.
  4. JB44
    JB44 Been here awhile
    May 16, 2003
    254
    FL, GA, NC
    Sounds too easy to be true.... :-)
    I'm pretty sure there is no 30 mm wrench in the XT tool kit, but I will check.
    jb
  5. CloudSplitter
    CloudSplitter Putterer
    Apr 6, 2014
    1,368
    Northern West Virginia
    That sounds worth a try, especially if in trouble on the trail, but unfortunately won't work well for an XT250, since the wheel nuts are 19 mm and the countershaft sprocket is 30 mm (per the first post on this topic, but the threads are 18 mm). Also the chain sprocket ratio is working to reduce torque at the countershaft, but the mass of the wheel should help if we yank it against the chain slack. The only tools I carry with that large an opening are channel-lock pliers and a crescent wrench. Maybe the crescent will work out
    As for workers producing that 1,800 ft lbs, mentioned above, they COULD, and DID, do it with a 10 foot pipe on the bar of the torque wrench. but there were 4 nuts per clamp, and 12 clamps per machine, so they couldn't be relied on to tighten them all properly. If not all tightened, the clamps could move during production. Thus the need for a large impact wrench. Of course that was no picnic, either, since it weighted around a hundred pounds. By the way, the square drive size on those sockets was 1 inch, I think.
    buckthedog likes this.
  6. CloudSplitter
    Apr 6, 2014
    1,368
    If you could find an aluminum tire iron with a 30 mm box end wrench on the other end, I'd recommend that, but both Tusk and Motion Pro jump from 27 mm to 32 mm. Of course I haven't verified that 30 mm size that jb44 mentioned, but I believe him. Then again, it's likely that you can make it out of the wilderness with a worn sprocket, so maybe I'd stick with the 22 mm on one, and 12 mm on the other, that I have now. Very much better than those two steel ones I used to carry.
    Edit: Now I've found a tire lever with a 30 mm box end, but they won't ship to the USA. Maybe some more time searching will find a source for these Sherco levers:
    https://www.roadrunnermoto.com.au/tusk-aluminum-tire-tyre-lever-spoon-with-axle-span
    randypower and JB44 like this.
  7. nvklr
    nvklr Been here awhile
    Jul 11, 2008
    751
    Carson City
  8. CloudSplitter
    Apr 6, 2014
    1,368
    Aha. Found a source for the Tusk tire lever with 30 mm box end:
    http://www.gnarlyparts.ca/Tusk-Aluminum-Tire-Iron-with-Axle-Wrench_p_2557.html
    I also found that Walmart lists them, but is out of stock. Oh well.
    Thought you might be able to get one at the Tusk site,
    http://www.tuskoffroad.com/
    but they just point you to Rocky Mtn, who don't carry the 30 mm size.
    OK, now you can get one, and not too expensive ($20 plus $9, shipping to the US), but do you want to. I'd take off that cover and see if it looks like it would work, first, and then think about whether you want that or the 12 mm small one to fit the valve stem and rim lock nuts. You could always just store your OEM 12 mm wrench with your tire levers, as well as your spark plug socket and 22 mm tire lever, so maybe a 30 mm wrench makes more sense.
    Edit: As I think about it, I like the idea of using the bottom of an old crutch for an adjustable-height support for the right side of the bike, when changing tires. Before placing it to support the engine, you might be able to use it to extend the length of your tire lever/box wrench.
    JB44 and nvklr like this.
  9. Tiger Ride
    Tiger Ride Been here awhile
    Jul 7, 2017
    126
    For those really steep rocky trails, w/ cruddy stuff at the top?
    ...It may be.
    Found myself shifting a lot b/t 1st and 2nd, and 2nd and 3rd.
    Hard to keep momentum/traction.
    Fussy - for a bike w/ so much torque.
    W/ the 16T... not so much.
    Ride the same kind of ridge trails in the Mojave... 1st and 2nd do fine.
    Just need to be able to ride that extra 1/3-2/3 mph faster at 5-10 mph to make the same power.
    Traction/momentum - is also better w/ the little extra speed.
    And the up-rated springs really help out with that.
    This is in Los Padres NF.
    The 16T adds 1 mph/15 mph... or 4mph at 60.
    With the bigger D606 rear tire, it trues the speedo and acts as a half an overdrive.
    65 mph - is an honest 65 mph cruiser.
    GR
    NicKel78 and JB44 like this.
  10. Tiger Ride
    Jul 7, 2017
    126
    Had a nice trail ride up in Idyllwild OHV this Friday.
    Beautiful day, not much dust, Buddy and I owned the place - not a crossed bike/quad/SUV in Six(6) hours of riding.
    "It's good to be the King."
    8>)
    GR
    NicKel78 and randypower like this.
  11. CloudSplitter
    Apr 6, 2014
    1,368
    Nice bike. Best color, too.
    Watch out you don't get anything behind that exhaust.
  12. CrashBar
    CrashBar Just Wanna Ride Supporter
    Feb 3, 2008
    375
    Somerville Ma
    Looking at a 2010 XT250, low miles and claimed mostly street use. Other than checking out any carb issues from sitting, anything else mechanical to look for unique to the XT? Looks stock. I'm familiar with the used bike drill but I need a runner and desperately need to a avoid another "project".
  13. CloudSplitter
    Apr 6, 2014
    1,368
    CrashBar, that question was recently addressed here:
    https://advrider.com/f/threads/yama...o-modifications.1341366/page-54#post-40953457
    Just read a couple pages, starting there.
  14. CrashBar
    Feb 3, 2008
    375
    Somerville Ma
  15. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    10,359
    Southern New Jersey
    I thought my 2019 XT250 was geared perfect and did not miss a 6 speed trans.
    1st was low enough with a great amount of low end torque and 5th was nice at 70 mph with nice gears between.
    Even with taller tires, the gearing was still good.
  16. CaseyJones
    CaseyJones Ridin' that train
    Aug 10, 2010
    4,716
    Western Montana
    Did the XT250 ever come with a carb?
    I thought they went with FI when they upgraded the engine from 225 to 250.
    Are you sure it's not an XT225? Or, could it be a Frankenstein project, with the block off a 250 but the carb off a 225?
  17. buckthedog
    buckthedog Eastbound and down
    Oct 21, 2011
    940
    South Mississippi
    They came with carbs until 2012 or something like that. But yes, they did for the first few years of their run.
    CaseyJones likes this.
  18. randypower
    randypower Been here awhile Supporter
    Jul 2, 2016
    310
    Spring Branch, Texas, USA
    Yeah, 2008-2012 were carb and have been known to be notoriously difficult to start after sitting for a couple of weeks or longer. When I had my 09, i bought a high powered lithium battery to have enough cranking power.
    The easy workaround is to drain the carb before parking it for more than a day or two.
  19. TDC_ERock
    TDC_ERock Been here awhile Supporter
    Apr 9, 2007
    353
    Lowcountry, SC
    Indeed. I have the 2013 - first year with FI.
  20. bikeneil
    bikeneil Been here awhile
    Apr 12, 2010
    637
    Southern Ohio
    I had a 2008 for 10 years and never had any starting problems after sitting, only replaced the battery once and never drained the carb.
    tlrmark and AZ TOM like this.
