1. eNewsletter Sign Up
Where can I get some warmer riding gears?
Discussion in 'Alaska' started by vincentmoy, Apr 29, 2010.
  1. vincentmoy
    vincentmoy Adventurer
    Apr 15, 2009
    48
    Anchorage, Alaska
    Hi all,
    So, I'm the kind of person that is always cold. I've ridden down to Dimond from E. Anchorage last weekend on the Seward hwy and by the end of the trip I was shaking. So I'm looking to get some overpants and some thicker gloves and not spending too much.
    Do you guys have any good places?
  2. AKTroy
    AKTroy BE AWARE OF TRAINS
    Feb 23, 2006
    2,235
    Seward, AK / Port Saint Lucie FL.
    Ummm, ever hear of "Alaska Leather"?
    From what I understand the gal that runs it has the best selection of stuff in town. Of course you know how rumors get started.
  3. AKDuc
    AKDuc Alaska Born Ducatisti
    Apr 20, 2006
    6,886
    Anchorage, Alaska
    Yep, some of us make it a priority to invest in quality gear. But here are a few low cost tips that'll make a big difference.
    First, make sure your helmet has a chin curtain on it. A Shoei chin curtain fits into most brands of helmets and really cuts down on wind around your face. Maybe wear a thin balaclava too.
    Another good trick is to put a folded up newspaper in front of your chest. It adds insulation and helps fill in the gap in a jacket created when you reach forward to the bars. Make sure your neck is well covered by a turtle neck or something too.
    Hands are a tough one. If you don't already have some nice winter recreation gloves you want to wear while riding, some less expensive well insulated motorcycle gloves with nice gauntlets can be had.
    Good luck, Mark H.
  4. ThatGuy
    ThatGuy Brownie Supporter
    Oct 27, 2006
    10,591
    Anchorage, Alaska
    Mark hit the nail. Layering up with non cotton clothes, neck covers (dickies) and even throwing some hand warmers in the gloves work for me.
    Try the flea market here, I've found some good
    deals on heated vests.
  5. ADVBMR
    ADVBMR Polygamotorcyclist
    May 18, 2007
    931
    Anchorage, AK and Ely, MN
    You can get by with some ski gloves for warmth but you won't have the protection. As for pants, you should seriously think about biting the bullet and make the investment. My First Gear pants (bought at Alaska Leather)are warmer than others I have, waterproof, have great protection and lasted for quite a few years now. I use a turtle fleece neck gaiter for any ride longer than a half mile, and it's the best inexpensive accessory I've found. I used to carry a piece of cardboard to put inside my jacket over my chest and wore a down vest. It was better than nothing but I found a deal on a heated jacket liner this winter and there's nothing like it.
  6. AKmud
    AKmud Muddy Gruver
    Sep 2, 2009
    1,334
    Lincoln, AR
    +1 for First Gear stuff.
    I have the Kathmandu jacket and pants which have zip out liners. ~$500 for the set, but it is really warm, has armor, and is waterproof. I have ridden down to 27* and it was fine for an hour ride. I wouldn't want to spend all day in those temps, but at 35-40* it would be no problem.
  7. akkurt
    akkurt Rode hard
    Feb 28, 2007
    188
    Wasilla "Palenville" Alaska
    Layers...
    Layer one; Polypropylene! Socks, long underwear, long sleeve under shirt.
    Layer two; Fleece Good quality thick fleece with gathers at ankles and waist
    Layer 3; Lined first gear pants. Windproof parki pullover Big bulky thick fleece baklava pulled down around neck, and tucked under parki
    Layer 4; Lined Olympia jacket.
    Boots; Danner high tops with thinsulate. (rockies are warmer)
    Gloves; Good quality lined leather with thinsulate. Break them in good first otherwise you will never feel your heated grips.
    Shoie modular helmet with the vent closed. I pop the front at stop lights so it doesn't fog up.
    Hands still get a little cold so I may try some heated gloved when it gets cold again.
    Leather riding gear is either to hot or too cold, sell it to somebody who would rather look cool, than ride everyday.
    Go to Alaska leather, bring your wallet, tell them your cold. They will fix you right up.
  8. Kay9Cop
    Kay9Cop Adventurer
    Jun 17, 2009
    92
    Wasilla, AK
    I'm probably one of the odd balls in that I like leather. I condition my leathers every fall when I'm done riding and they stay flexible and strong. If the leather is well conditioned it will repel water. I rode from Anchorage to Fairbanks in my Harley FXRG gear and never got wet. The jacket and pants have windproof panels behind all of the zippers, so no wind gets in uless I want it to. The venting works pretty well as long as I'm at 45mph or higher, but leather is definitely hotter than nylon. I've ridden down to 8* and not been cold in my leather gear, but I used the same layering principles already mentioned.
    I'm not necessarily opposed to nylon/cordura gear, but not all cordura is the same. Only 1000 denier cordura is stronger than leather. The more common 500 and 600 denier cordura is less than half as tear resistant in a crash. Suits like the Aerostich Roadcrafter, one that I'm considering purchasing, are 500 denier in the body and 1000 denier at the ballistic panels. The 500 denier is more flexible, lighter, and cheaper, but at least on the Roadcrafter, isn't used to cover the back and butt, two areas I think are likely to take impact in a crash. So if you're going to buy nylon gear, take a close look at the construction.
    One thing about dressing for the cold...wear looser fitting boots and gloves if you can. You need to add layers and still have some dead air to keep warm and circulate. This can be very difficult to do on a motorcycle. I wear boots two sizes bigger during the winter. I also wear large mittens over regular insulated motorcycle gloves. If you get the mittens large enough and use one of those cords that go on under your sleeves like your Mom used to make you wear as a kid so you wouldn't lose your gloves, you can just shake off the mitten if you need the dexterity.
    #8
  9. vegasphotog
    vegasphotog Las Vegas Cheechako
    Jun 1, 2005
    3,333
    Covered in Desert Dirt since 2007
    I am a BIG FAN of the hippo hands...
    #9
  10. Kay9Cop
    Kay9Cop Adventurer
    Jun 17, 2009
    92
    Wasilla, AK
    You know, I've never tried those things but I may this fall.
    #10
  11. See-Double-You
    See-Double-You Long timer
    Sep 10, 2003
    2,174
    Anchorage, AK
    Firstgear makes an overpant which isn't too expensive ($150ish) and it's available in short/reg/long sizes. I'm pretty sure Barb @ alaska leather can hook you up.
    #11
  12. AKmud
    AKmud Muddy Gruver
    Sep 2, 2009
    1,334
    Lincoln, AR
    I haven't used them on my road bike, but they work VERY well on the wheelers in the winter! Combined with hot grips, hands stay toasty. :thumb
    #12
  13. AK Bear
    AK Bear Long timer
    Feb 22, 2003
    1,624
    Anchorage
    How big are you? I've got some good first gear stuff, insulated pants and a coat with a liner that are well used that I seem to have out grown. I'll donate them for $100. With an electric vest it is an unbeatable combination. They will fit a 40 or 43 inch chest and a33to 35 inch waist very well.
    I have some warm ski gloves I'll throw in if I can find them, but that's a big "if".
    #13
  14. See-Double-You
    Sep 10, 2003
    2,174
    Anchorage, AK
    Hey Bear, that reminds me of something. I'm PMing Philspace to see if we can get our own FS thread sticky like the other regionals have.
    #14
  15. akrider
    akrider mild adventurer
    Apr 24, 2003
    1,848
    Anchorage, Ak
    I keep seeing guys talking about buying or selling used, outgrown clothing and very ofter parts.......
    Any interest in having a ADV swap meet?
    Find someone to let us use their parking lot. Everyone just bring a table or something along with the Sale/Trade items and just hang out?
    Pretty simple.
    Interest?
    #15
  16. Andrewmc
    Andrewmc Been here awhile
    Mar 5, 2010
    516
    Palmer, AK
    That sounds like a great idea. I'd go.
    #16
  17. AK Bear
    AK Bear Long timer
    Feb 22, 2003
    1,624
    Anchorage
    Those are some good ideas. I'm going to be on a ride from the 5th till the 17th so please wait till I'm back!
    #17
  18. PistonPants
    PistonPants Crankcase Scavenger
    Jun 11, 2008
    771
    Cantwell, AK
    For the hands there's no substitute for heated grips.
    Piston
    #18
  19. ADVBMR
    May 18, 2007
    931
    No way. We were planning on selling all your shit while you're gone! Have a great trip!
    #19
  20. PowerT
    PowerT Long timer Supporter
    Jun 27, 2005
    1,138
    Just West of Foat Wurth, Tejas
    For me the best non-electric item I have is the Klim balaclava with windstopper gore. Of course the best electric is Gerbings. It feels like cheating...warm cheating but cheating.
    #20
