Where do you carry your InReach type device?
Discussion in 'Mapping & Navigation' started by lacofdfireman, Oct 5, 2020.
  1. lacofdfireman
    lacofdfireman Long timer Supporter
    Jan 29, 2008
    1,609
    St. George, UT
    I recently bought an older DeLorme InReach SE and reading the literature it says it needs to have a clear view of the sky. I’ve read that some recommend not mounting to your bike because in the unfortunate event you crash you will be separated from your bike and unable to get to your device possibly. So that basically leads me to putting it in my jacket somewhere. The issue with this is the InReach won’t have a clear view to the sky so it might not pick up satellites and be able to give off track points every 10 minutes. But maybe I’m wrong. That’s why I’m hear to ask the experts. Where do you carry your tracker?
    Also any tips or tricks to improve battery life. I turned it on yesterday and without using it at all but leaving it in tracking mode and Bluetooth mode after 24hrs I’m at about 13%. Is that normal?
  2. 250senuf
    250senuf Long timer
    Feb 17, 2008
    4,003
    Nelson area, Kootenai, BC, Canada
    I carry mine in the left chest pocket of my jacket, screen toward my body. Tracking works fine.
    If you started with the inReach fully charged I wouldn't consider that amount of drain normal.
    Did it get a satellite lock or was it always searching. I don't see the "3D" showing that it has a lock.
    Was it new old stock (ie: it's been sitting in the box on a shelf since new)? It could be that the battery has been sitting too long without a charge. You might want to see if the battery can be replaced under warranty, if you have warranty as the first owner.
  3. Addapost
    Addapost Been here awhile
    Jun 20, 2016
    581
    Massachusetts
    +1 Jacket chest pocket.
  4. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    3,762
    Wnc
    I picked up a used one. I keep it in the tank bag (mosko nomad), it works fine in that position. On my last trip, sending 3-5 texts a day, I charged it 3x over a 14 day trip and I don't recall it ever getting very low.
  5. Mountainman13
    Mountainman13 Been here awhile
    Mar 29, 2017
    224
    On the camelback strap if im offroad. On the handlebars if not.
  6. Adanac rider
    Adanac rider O.S.T.R. Supporter
    Dec 5, 2006
    1,573
    N.V.I.
    I keep my Spot in left front pocket of Aerostitch , It has a loop that I hitch a mini carbiner on .
  7. Stalky Tracker
    Stalky Tracker Been here awhile
    Feb 24, 2008
    191
    Here
    Right lower sleeve pocket on my Roadcrafter.
  8. Aces&8s
    Aces&8s Adventurer
    May 22, 2020
    22
    North Carolina
    My Klim Badlands has the pocket on the upper arm. But with my luck I'd land on it breaking my humerus and the Inreach. So for now mine goes in the Mosko Nomad tank bag as well.
    #8
  9. Zubb
    Zubb he went that-a-way... Supporter
    Sep 8, 2002
    3,367
    San Diego
    It's a problem. I don't wear pocketed up jackets. Don't use a camel back or a tank bag. I ride as much sand and dirt as I do pavement (time wise). Any place I put it is not ideal. I'll probably just ram mount it and be done with the dilemma.
    #9
  10. Lost-Again
    Lost-Again Adventurer Supporter
    Jul 12, 2016
    58
    Texas
    I keep my inreach mini within arms reach on my body. From pockets to backpack straps.
    #10
