Where do you keep your InReach while riding?
Discussion in 'Mapping & Navigation' started by lacofdfireman, Apr 10, 2018.
  1. lacofdfireman
    lacofdfireman Long timer
    Jan 29, 2008
    1,197
    St. George, UT
    Been trying to figure out the best place to keep my Inreach as I ride. Supposedly you should have a clear view of the sky for it to work properly which means it would need to be mounted to your bike somewhere. But with that in the event of a crash your separated from your bike that could be a ways away from ya. Could also break off and who knows where it could end up.
    Next idea is to wear it on your clothing somewhere. Not sure what kind of case they make or where you could hang it on your jacket to keep a visual of the sky. If you put it in a pocket which would be the most obvious place for me you lose your clear view of the sky.
    So just curious how people are mounting them, what type of cases are being used etc. or do you just turn it off and put it in your pocket until you need it?
    Sent from my iPad using Tapatalk
  2. chasejj
    chasejj Been here awhile
    Mar 14, 2008
    292
    Orinda,CA
    This
    motorcycle john likes this.
  3. gt750
    gt750 Adventurer
    Dec 18, 2016
    70
    Edmonton, AB., Canada
    You can partially zip your breast pocket and keep the antenna poking out. The Tracker Packer looks to be the best though.
  4. Phoenix101
    Phoenix101 Long timer
    Nov 24, 2008
    2,598
    Right Side of WA
    pack it on you in case you crash...
    EnduroRdr likes this.
  5. EnduroRdr
    EnduroRdr Woods Racer & D/S Rider
    Feb 15, 2008
    2,544
    Formerly BR-LA, LR-AR, Houston-Tx, now South MS
    I keep mine on my person in a pocket.
    Jacket pocket if wearing one or side pocket of riding pants when it’s hot weather.
  6. sphyrnidus
    sphyrnidus born to ride
    Apr 2, 2009
    303
    Netherlands
    Decisions, decisions.. I think the clear view of the sky is not bothered by clothing. That said I don’t like to wear things on me. I saw a friend go down and he broke two ribs due to his cellphone in his jacket.
  7. Dirtroadbandit
    Dirtroadbandit Former lurker
    Nov 9, 2014
    33
    Arkansas ozarks
    Top pouch in my small backpack...
  8. BBJIdaho
    BBJIdaho BBJADV
    Jul 6, 2015
    7
    The Woodland, Texas
    Handle Bar Mount
    Sent from my SM-G950U using Tapatalk
    #8
    Cabrito likes this.
  9. Tricepilot
    Tricepilot Bailando Con Las Estrellas Super Moderator Super Supporter
    Apr 30, 2006
    10,759
    San Antonio
    I have a Wolfman pillion bag on my 2015 GSA. I keep my inReach in the top pocket of that, zippered shut, with the device facing the sky. If it can signal the satellite it can and does obviously send the signal through the thin layer of fabric of the bag's exterior.
    Unless you want to, you do not need to (and I wouldn't) mount the device on your handlebar, if the only reason for doing so is you think that's the only way the thing will connect to the constellation above. The reason I know this is that on the handlebar is where I initially mounted mine, for that very reason. Then later I moved it to the Wolfman bag.
    Your posters here will debate keeping the device on your person versus on the bike. I used to subscribe to the "hey, if you're thrown from your bike and you need to punch the 911 button" argument, but hey, I got over it. If it's your day, it's your day.
    Went to Guatemala (again) in February and had the inReach in the place described and it didn't miss ping the whole 4014 mile trip.
    #9
  10. motorcycle john
    motorcycle john Been here awhile
    Jun 24, 2016
    172
    nebraska
    Mine seem to track ok on the passenger seat in my semi tractor and it haven’t been activated yet
    Sent from my leap frog
    #10
  11. max384
    max384 Bandaided Supporter
    Nov 23, 2011
    5,998
    Eagle Rock, PA
    I either keep mine on my handlebars or in my front left breast pocket on my Klim Badlands jacket. I like having it on me in case I'm thrown from the bike, but I also like keeping it charging on my handlebars with the screen on so I can keep an eye on the statistics on the screen. What I basically do is keep it on the handlebars if I'm on the road and in my pocket if I'm offroad. I know it's not foolproof, but it works for me. By the way, I've had absolutely zero issues with it losing connectivity when in my pocket.
    #11
    Parcero likes this.
  12. Motorius
    Motorius Road trippin'
    Dec 7, 2016
    3,746
    Seattle & Phoenix
    Resurrecting an old thread here to remind people, as I discovered today, that sometimes the Inreach does NOT ping even though it appears it’s in the ‘wide open’.
    In looking at my track today I was amazed to find...nothing. Inreach mounted on bike in exact same RAM X-holder as past few days. Only difference was I had rotated it about 25 degrees.
    All I can think of is somehow the metal frame on the windscreen threw off the antenna Xmit/Rec by acting as a resonant antenna of its own on the wrong wavelength.
    Lesson learned—double check your signal is actually getting out.
    #12
  13. max384
    Nov 23, 2011
    5,998
    Eagle Rock, PA
    And you definitely didn't have tracking off, or other settings disabled? That's surprising such a small change would result in no service.
    #13
  14. Motorius
    Dec 7, 2016
    3,746
    Seattle & Phoenix
    Pretty sure it was on as I never turned it off. It was pretty weird.
    #14
  15. max384
    Nov 23, 2011
    5,998
    Eagle Rock, PA
    That is weird. Did you get to test it out since then? Did you get it tracking again?
    #15
  16. Motorius
    Dec 7, 2016
    3,746
    Seattle & Phoenix
    Will try again today. If I got it wrong I’ll post as well.
    Edit: checked tracking a moment ago & it was off. All I can think now is when I put it in the Ram x-mount I accidentally turned it off at the same time.
    #16
    max384 and SPX like this.
  17. Bike Guy
    Bike Guy Been here awhile
    May 20, 2005
    849
    sierra foothills, hwy 49
    Your track problem might have been your speed over highway 4 yesterday. As your signal couldn’t keep up. :-) LOL
    #17
    Motorius likes this.
  18. Motorius
    Dec 7, 2016
    3,746
    Seattle & Phoenix
    Yeah. LOL!
    #18
  19. DJWMoto
    DJWMoto Adventurer
    Jun 27, 2016
    10
    Melbourne, Australia
    I use the Garmin backpack tether for when riding off road but also have a mount for it on the F800GSA windscreen bars (using the garmin bike mount) for if i need to charge it when doing road sections.
    #19
    ADVwxyz likes this.
  20. Jailor8
    Jailor8 Long timer Super Supporter
    Feb 13, 2010
    3,393
    Here and there, but usually, leaving Illinois
    Front jacket chest pocket for mine and use the supplied lanyard. Never had a issue tracking.
    Of course you could mount it to the bike, and Bluetooth it to your phone, if you have your phone on you and they stay connected, you can activate/operate it from your inreach phone app. ........ Assuming your not separated from the bike so far your out of Bluetooth range.
    Thinking out loud here. ...I wonder how well it would work mounted to your bike that's now twisted up and on top of it.....?
    #20
