Where is this from?
Discussion in 'Crazy-Awesome almost Dakar racers (950/990cc)' started by mountaincadre, Jun 13, 2019.
  1. mountaincadre
    mountaincadre Long timer
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    20190613_085227.jpg 20190613_085239.jpg So bottoming everything up and there's this, starter motor? But if it is what does it attach to? Also the 2nd picture I've got a brown wire attached to left-hand post of starter motor,(thick Brown wire coming from left hand side of engine) I know I forgot to take photos.
  2. RedRupert
    RedRupert Brit in the Soviet Union
    Jun 12, 2006
    804
    Riga, Latvia / Bergerac, France / Colchester, UK
    looks as if it's a negative cable about 100 mm in length, therefore it should go from the starter mounting to the frame. The other thick negative cable (470 mm) should go from the starter mount to the battery. Maybe you've installed the 470 where the 100 should be?
    mountaincadre and 1coolbanana like this.
  3. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    5,557
    NW Sydney, Australia
    Yeah, agreed, starter to chassis I reckon.
  4. mountaincadre
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    That's what I was thinking, where abouts on chassis though.
  5. mountaincadre
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    Here is the other ,(earth) I'm not sure of,2nd pic is where it coming from, left side of bike. 20190613_130224.jpg 20190613_130204.jpg
  6. mountaincadre
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    Sorry 2nd pic is actual cable.
  7. mountaincadre
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    Bump
  8. opanos
    opanos Been here awhile
    Aug 12, 2015
    349
    Rotterdam, Flatland
    Think the same as mentioned above, grounding starter motor to the chassis...
    #8
  9. mountaincadre
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    Where abouts on the chassis, can't see anything , couple of places on engine but nothing for frame
    #9
  10. gearheadE30
    gearheadE30 @LC8Adventures Supporter
    Jan 20, 2012
    2,079
    Indiana
    It should be in the parts fiche on RMATV and elsewhere if you can't figure out where it goes. I don't remember anything connecting the starter to the frame on my 950, but there is a ground strap on the front right bottom corner of the engine that looks like that.
    #10
    Boatman likes this.
  11. mountaincadre
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    Just had a look gearhead but no joy with rmatv and another couple, they have a general parts fiche but nothing with the part on. It's only 100 odd mm so it must be near as one end goes on the starter , it difinately is the CHASSIS it goes to?
    #11
  12. RedRupert
    Jun 12, 2006
    804
    It doesn't really matter where it goes on the frame, anywhere will do, as long as the contact to good. It's there to ensure a good reliable earth to the frame from the engine. The engine has a reliable earth, at the starter motor mounting, directly from the negative of the battery.
    #12
  13. zimtim
    zimtim Adventurer
    Aug 15, 2012
    78
    UK
    Not sure what you have been doing to your bike.
    But post on rear of starter is the earth and that goes across the engine. (Sorry can't remember where it secures, but look like it is in place)
    Second long earth cable is possible the one from the battery that goes up right hand side of engine and is secured to the front post on starter motor.
    The short earth is possibly the one that connects to the starter relay and then is connected to the bottom of the engine near the clutch cover.
    #13
  14. mountaincadre
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    Zimtim I've got the one on that comes onto the central post of the starter motor, also the long negative from battery to right hand starter motor post,( where bolt goes through to attach to motor) it's the lead/earth from the other post,( where bolt goes through)? The really annoying thing is,( apart from not labelling or photos) is that it's in a set shape as happens with thick wire when it's been in a set position for a while but no matter what position I put it in it doesn't line up with anything on the frame , I'm starting to think it doesn't belong there? Oh aye electrics.
    #14
  15. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,203
    Cremona, Italy
    It's a 990 thing.
    There's a tab on the frame near the starter motor where the short ground cable goes.
    This tab is missing on 950 frames, as well as the short cable.
    #15
    nk14zp, 1coolbanana and DirtyADV like this.
  16. 1coolbanana
    Aug 25, 2009
    5,557
    See in the top of the picture where it bolts to the chassis in between the engine mount arms on 990's
    #16
    zimtim and DirtyADV like this.
  17. mountaincadre
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    Right CB , glad you posted that as looking at yours I can see both starter motor posts, if you don't mind where are the 2 leads going to from the starter motor posts?
    #17
  18. 1coolbanana
    Aug 25, 2009
    5,557
    One goes to the chassis as above, and the other goes directly to battery negative, #5 (being 470), and #12 (being 100)
    The positive terminal on top of the starter goes to the starter relay
    #18
    zeropoint and Salzig like this.
  19. mountaincadre
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    That's great CB , so far I know I have 5 and 7correct, i think its 4 and 11 im having trouble with, ( as well as the small lead in original picture) i put the battery in but as soon as the + lead touched the battery she tried to start, don't know if that makes any difference.
    #19
  20. mountaincadre
    Jul 18, 2012
    1,594
    Mid Calder,Scotland
    CB what are 35 36 and 37?
    #20
