    Dismiss Notice
Where to carry spare clutch cables
Discussion in 'The Garage' started by crash007, Mar 24, 2013.
  1. crash007
    crash007 Adventurer
    May 18, 2009
    20
    Bought a spare clutch cable just in case. Not sure how much I can coil it up without damaging the cable.
    Where do you guys carry a spare on the bike?
    Crash
  2. greywolf
    greywolf Unpaved road avoider
    Apr 2, 2006
    1,406
    Evanston IL
    The time honored method is to cover the ends so dirt can't get in and tape it alongside the present clutch cable.
  3. GordonH
    GordonH Been here awhile
    Sep 20, 2011
    105
    Novi, MI
    Zip tie it to your existing cable. Old enduro trick. You know where it is and you don't have to spend time in the woods routing it.
    Gordon
  4. BykBoy
    BykBoy Meshuganeh Super Supporter
    Aug 21, 2003
    606
    Reston, VA
    I did this with my old Triumph Tiger. Had spare clutch and throttle cables running along side with the existing cables. Never had to use them, but felt good having the spars in place.
  5. duck
    duck Banned
    Mar 19, 2004
    10,403
    Seattle (Berkeley with rain)
    Unless you put right angle bends in it you're not going to hurt it. I coil my spare cables coiled uptight enough to fit in a quart zip lock bag in the tail cowl.
    There's really no need to route it next to the existing one. It's kind of a Murphy's law that anything you carry a spare of will be the last thing to break.:deal
  6. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    26,812
    Über Alles,California
    KLR clutch cable will last about 25,000 miles, just change it then and don't worry about it.
  7. SteelB12
    SteelB12 Our Purity of Essence Supporter
    Mar 6, 2009
    5,781
    South Central, VA
    Crap, I am over that. Good thing I have the spare already zip tied next to it. :D Now the original will never break
  8. Bob_M
    Bob_M Been here awhile
    Nov 24, 2009
    463
    Tiverton, RI
    Lube it then seal he ends with RTV & tape. I had a spare routed and zip tied to the installed cable for about 25 years on my Honda 750. Of course I never needed it.
    #8
  9. mark1305
    mark1305 Old Enough To Know Better Supporter
    Feb 7, 2005
    6,716
    Merritt Island, FL
    I have the spare on the F 650 routed with the operating cable. Lubed and coated with chain wax at the ends. Plus a section of narrow bicycle tube ziptied over the upper end and folded over to provide extra protection for weather and road grime. I agree, with a spare mounted, the operating cable will never break. :evil
    The spare for the airhead I do carry coiled up with other spares.
    The cliche, "Six of one, half dozen of the other..." still works.
    #9
  10. anonny
    anonny What could go wrong?
    Mar 20, 2007
    6,830
    Beautiful Revelstoke BC
    Or just keep it at home, you can ride without a clutch.
    #10
  11. PeterW
    PeterW Long timer
    Nov 11, 2005
    4,723
    Gold Coast
    Did that, don't recommend it. I was stuck on a snow covered road, with the only viable speed being 70kph in 3rd.
    That was the day I learned that if you had no options you could just slide a bike into a snow bank, keep on leaning and it'd build you a berm and you'd get round a lot more scared, but otherwise intact.
    Almost made it home as well, wouldn't you know it, one set of lights from home, got pulled over by a cop for the one wheel launch from the lights ....
    Pete
    #11
  12. ohgood
    Sep 21, 2010
    10,052
    alabama
    that's the stuff !
    i'm one of those reallllly lucky people that always felt a 'funny' pull as i left for work, and ignored it. then it popped on my way home, pulling into the parking lot.
    now, it's either brand new or taped to the brand new one. (it looks naked when it's missing the spare)
    :clap
    #12
  13. Damian_74
    Damian_74 Been here awhile
    Feb 4, 2008
    807
    Brisbane, Australia
    Grease, seal the ends with heat shrink and zip tie to the original.
    Has got me out of trouble twice so far! On my DRZ and my F650Dakar.
    #13
  14. Lone Rider
    Lone Rider Registered User
    Jan 29, 2002
    25,130
    out and about
    Nuff said.
    :deal
    #14
  15. HrtofAg
    HrtofAg Adventurer
    Mar 29, 2011
    28
    Chico
    Lots of good advice. I think I like (KLR650) replacing it at 25,000 miles and running the old one along the new one for an extended trip. That would minimize the likelihood of having to do the repair on road.
    #15
  16. ttpete
    ttpete Rectum Non Bustibus Supporter
    May 13, 2009
    7,639
    Dearborn, MI
    Just a tip. Most cables fail at the handlebar lever because the cable end can't swivel in the lever recess due to lack of lubrication. The cable then flexes and the wires break. All that needs to be done is to give the end a shot of chain lube every time you do the chain. Just use a paper towel to prevent overspray.
    #16
  17. joexr
    joexr Banned
    Jan 4, 2011
    5,022
    This is very true . I once rode home about 20 miles on an RD , pulling the end of the broken throttle cable with my fingers , thru the hole in the ignition key .
    #17
  18. jeep44
    jeep44 junk collector
    Mar 23, 2008
    2,611
    Canton,Michigan
    I had the clutch cable break on my Royal Enfield Bullet (broke at the handlebar,right at rhe "barrel" in the clutch lever) No problem, I think-I have another in the toolbox. What I didn't have is the right wrench to change it in the toolkit-it needed a 14mm. Somehow I managed with a leatherman tool, but it hammered home the message that spares are useless if you don't have the means to change them.
    #18
  19. vintagespeed
    vintagespeed fNg
    May 9, 2011
    3,444
    Rancho Cucamonger, CA
    haha YOU dont ride where i ride. good luck with that!
    #19
  20. Ricardo Kuhn
    Ricardo Kuhn a.k.a. Mr Rico Suave
    Sep 20, 2001
    17,305
    Minneapolis (don't even ask how i end up here.
    For the last 20 years I have carried a "Back up cable/housing" Ziptie in parallel to the clutch cable (rear brake cable in two bikes) that way you don't need to take the bike apart with a hot engine and you can be on the way in a few minutes, one thing you want to do is to seal the ends (fingers of blue mechanic gloves {easy to see at night}) and wrap with orange electrical tape so you don't need to take out the players to cut the zipties..
    #20
    Hybridchemistry likes this.
