Which paint to block old odor from wall?
Discussion in 'The Garage' started by Alexander B, Sep 8, 2019.
  1. Alexander B
    Alexander B Long timer
    Apr 24, 2013
    1,177
    Sweden
    Garage was earlier used as home for one or more large dogs, and there was lots of grime and greasy dirt on the walls and the floor. The epoxy covered floor cleaned up ok after lots of hot water, strong detergent and elbow grease. Still seems ok after a few weeks.
    The walls, not so much. Drywall (gypsum), and they were painted prior to the dogs moving in. I have scrubbed and cleaned every square inch of the walls and ceiling, as above using hot water, strong detergent and lots of effort.
    Came out well, and remained "odorless" for many days, after which I then painted all walls and ceiling with a "masonry coating" paint. It is for basements, outhouses etc, and will allow "humidity" to transfer from inside the wall, to the room, where it can evaporate. Standard paint and method for Sweden, and normally totally fine.
    However, after some weeks, the smell of dog fur has now permeated the fresh paint (2 layers), and the garage smells like a badly kept kennel again. I can smell the odor coming from within the walls themselves.
    Any recommendations on how to proceed? My only hope is to find an "airtight" paint to keep the odor locked in the drywall.
    Please note that I am in Sweden, so specific brands and labels may not be available to me. However, indications on "acrylic is better than oil based" etc are very welcome. Many thanks in advance!
  2. branchkin
    branchkin Been here awhile
    Apr 30, 2015
    154
    hills of north Ga.
    Oil based does the best job of sealing an item, but it sounds like it's already got at least one layer of water based paint. If there is much moisture coming through the drywall and the paint, oil based will eventually turn loose.
    Alexander B likes this.
  3. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,055
    Replace the drywall.
  4. mglsite
    mglsite Long timer
    Sep 11, 2008
    1,175
    Covington, La.
  5. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,377
    Anchorage, formerly Spenard (hub of the universe)
    kilz is a joke
  6. wheelspin63
    wheelspin63 Been here awhile
    Oct 17, 2008
    135
    Newnan, Georgia
    "Flood" the garage with ozone, then use quality oil based primer. Topcoat with oil or latex.
    Tmaximusv and Alexander B like this.
  7. Alexander B
    Apr 24, 2013
    1,177
    Sweden
    Not an option right now.
  8. Alexander B
    Apr 24, 2013
    1,177
    Sweden
    Thanks, all!
    #8
  9. Motopsychoman
    Motopsychoman Not a total poseur Supporter
    Jun 2, 2013
    4,736
    Oaklandish
    One last suggestion: BIN primer. It's shellac. It sticks to anything dry and seals everything I've ever run across.
    #9
  10. TeneRay
    TeneRay Bitch, I'm fabulous
    Aug 16, 2009
    3,099
    MO
    Kilz has its limitations. I renovated a home that had a smoker and cats. Three layers on everything took care of the bulk but on hot, humid days the odor will creep back. It's not intolerable but noticeable in one part of the house.
    #10
  11. foxtrapper
    Sep 6, 2011
    4,055
    Surface sealers, even if 100% effective, don’t seal outlet openings, floor joints, etc. So the odor will be reduced, but it won’t be defeated. Just as you’ve already experienced.
    It’s a garage, the drywall work doesn’t have to be done to the quality level a house wall does. If the drywall was laid horizontally, you likely only need to replace the lowest level.
    #11
    spokester and phreakingeek like this.
  12. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    2,493
    Wnc
    I have a lot of experience with this. I would use zinsser cover stain. It dries quickly. Use plenty of ventilation! And a respirator.... Not a dust mask.
    Kilz, shellac bin, also work. The paint stores will also have their specific lines that will handle this.
    #12
    ozmoses likes this.
  13. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,670
    USA??
    Coverstain- one of the best,multi-purpose, primers I've used in 30+ years of using primers.
    #13
    Amphib likes this.
  14. Amphib
    Sep 19, 2018
    2,493
    Wnc
    Its my go to. I always have it stocked in the van. It works well for everything. Too many others you'll need to reprime with something else.....whether it's tanin bleed, poor adhesion....plus it sands extremely smooth, sticks to anything, dries extremely fast, and is found in many places.
    #14
  15. Alexander B
    Apr 24, 2013
    1,177
    Sweden
    Thank you for all the help!
    Unfortunately, those branded products are not available here. (Paint and many construction products are almost under oligopoly in Sweden. A handful of manufacturers split the market between themselves.)
    There is one product specifically targeting my problems, but it is approx. $200/gallon, incl vat. I will try some oil based paint first.
    #15
  16. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    7,649
    below the sea
    Here in UK I would use a cheap oil based primer or undercoat. Does not need to be an expensive one.
    MY SiL is a pro decorator and advises this for rooms that have had habitual smokers in, or lots of dogs/animals. Same for water leak stains.
    Water soluble stains will be released by water based paints, so they just reappear again and again, undercoat seems to discolour pretty quickly, but it usually has greater obliteration power.
    One of the waterbased acrylic based paints over the top should hold its colour longer because it is the oil binders in oil based paints that cause discolouration over time.
    I would spend some time carefully sealing each and every joint with decorators caulk. Walls, floors and ceiling window and door frames, everywhere. The smelly solids may have got forced into any crack or crevice or seam.
    #16
  17. ydarg
    ydarg Miscreant
    Nov 11, 2015
    2,062
    Above the Equator
    This. I've bought and sold three smoker's houses now, the only way to permanently get the smell out is to gut the drywall (and ductwork but that's a different discussion) and redo all the trim.
    #17
  18. Beezer
    Oct 26, 2004
    9,377
    as mentioned, shellac is a good sealer & pretty cheap too. it goes over anything and everything sticks to it on top.
    #18
  19. AviatorTroy
    AviatorTroy Long timer
    Oct 15, 2007
    2,413
    Castle Rock, CO
    Take it from someone with a lifetime of experience with rental properties... Cat piss, smokers, greasy kitchens, engine blocks left in the basement you name it I’ve seen it. Oil based Kilz is what you want. If odors are still present they are coming from surfaces you can’t paint as mentioned previously.
    #19
    Tmaximusv likes this.
  20. Gruesome
    Gruesome Alter Heizer
    Apr 28, 2007
    1,501
    Chicago
    Running an ozone generator for a few days sounds like a good idea. I'm not sure what it will do to wire insulation though, and other plastic parts you can't remove.
    #20
