which SKF barings for G 650 and F800GS
Discussion in 'Parallel Universe' started by Krummemusic, Jul 13, 2014.
  1. Krummemusic
    Krummemusic Adventure Dreamer
    May 31, 2013
    147
    Singapore
    Valued Forum,
    appreciate if anyone could tell me which SKF bearing (wheels, steering) I can use from for G 650 GS (2012) and F800GS (2013)
    Uli
  2. YrianX
    YrianX Viking Adventurer
    Feb 21, 2014
    220
    Oslo, NORWAY
    On my 09 F800GS The SKF number for the front & rear wheel bearings are "6402-rs2" (you need 5: 2 front, 2 back and one for the sprocket carrier)
    I think the dimensions are 20mm x 47mm x 14mm and you want the ones rubber sealed on both sides, hence the "rs2" or "2rs" moniker. normally the C3 ones with normal internal spacing are used but I think you can get away with the C5 that has more internal spacing between the balls as well if you can not get hold of the others...
    Be ware that there are different internal diameter on the dust/grease seals if you plan to change those as well due to the spacer going in one side only. Don't remember exactly what it was at the moment though (30mm and 35mm possibly) you will have to check yours .
    Can't help you with the steering bearing I'm afraid...
    Per
  3. yaycep
    yaycep Been here awhile
    Jun 9, 2014
    556
    Freiburg, Germany
    The steering head bearing is 320/28 XQ (28x52x16mm)
