Which threadlock liquid for caliper bolts?
Discussion in 'The Garage' started by Zapp22, Apr 11, 2019.
  1. Zapp22
    Zapp22 ZAPP - Tejas
    Oct 20, 2004
    13,875
    Tejas Hill Country
    I'm putting the front end back together on a V-strom, and noticed the manual says a lot about threadlock, which I'm no stranger to. Here in 2019, what threadlock are you guys happy using on caliper mounting bolts? I read quite a bit, but find no consensus - some say "my pappy never used no liquid on no bolts" - some say blue is universal - some say Red or you die - and Suzuki puts white paint on those bolts, so do they mean "white" threadlock? Probably for liability reasons, aftermarket performance brake calipers/kits will often if not always ship with the intended threadlocker included and dire warnings about using it properly.
    appreciate the advice.
    z
  2. RetiredandRiding
    RetiredandRiding Retired to Ride Supporter
    May 22, 2015
    1,266
    Da Lat, Vietnam
    I've never previously used threadlocker on caliper bolts. I just tighten them to lb-ft as instructed in the manual.
    When I re-assemble my 1978 Ural, the plan is blue on almost everything that may need to come apart within a few years and red on everything else.
    Fleksta, JimVonBaden and baldman1 like this.
  3. TripleTriples
    TripleTriples Been here awhile
    Feb 6, 2019
    370
    OH
    I've always used antiseize and then torque to spec. Haven't lost one in 20 some years of doing it.
  4. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    15,218
    Silver Spring, Md
    I think paint is applied after assembly so a loose fitting can be spotted immediately. It's not the thread locker.
    ohgood, Zubb and Night_Wolf like this.
  5. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    12,858
    the hills
    Anti-seize,torque and safety wired.
  6. kasuckmo
    kasuckmo Been here awhile
    Jun 21, 2018
    207
    fl
    Just tighten the fucker
    nk14zp, NurseBill, ohgood and 7 others like this.
  7. branthopolis
    branthopolis Long time lurker Noob
    Jul 17, 2007
    346
    Atlanta-ish
    Definitely not Red. A couple drops of Blue wouldn't be the end of the world if it makes you feel better about it.. Anotherguys answer above is the best though.
    SmittyBlackstone likes this.
  8. 23103a
    23103a not n00b
    Mar 6, 2016
    226
    Santa Rosa, CA
    None.. just torque to spec. That's what I do anyways, a little blue wouldn't hurt anything.
    #8
  9. C Squared
    C Squared Now with TURBO! Supporter
    Mar 27, 2008
    10,291
    FDL WI.
    Just understand that lube or antisieze can add 30 percent or more to a dry torque spec. Assemble things the way they are spec'd. Blue or red lock tight? How much chance of coming loose? And, dry prep to threads before.
    #9
    23103a likes this.
  10. B02S4
    B02S4 Aye
    Mar 9, 2009
    1,888
    I use blue. There is no downside to using blue, that I am aware of, for that application.
    #10
    ohgood and jimroid like this.
  11. double_entendre
    double_entendre It's nothing personal; just your existence.
    Aug 11, 2008
    10,745
    Huntington Beach, CA
    I'm a fan of blue and prefer the stick over liquid. Maybe it's a belt and suspenders thing, but on mission critical components, I'm ok with that.
    :fpalm
    Reminds me of an old Cycle World op-ed about a guy who had three torque settings: white knuckle, grunt, and break wind.
    WCGW?
    #11
    SmittyBlackstone and Bigger Al like this.
  12. roger123
    roger123 Long timer Supporter
    Jun 23, 2007
    2,278
    VA Beach, VA
    Anti-seize and tighten has been my routine on most things for 40 years. I grew up in the UP, we put anti-seize on everything to try and give yourself a fighting chance against rust, didn’t usually work......
    I’ve lived down south for many years and it’s still my habit, especially on the boat.
    #12
    Moose Dog and spokester like this.
  13. C/1/509
    C/1/509 Now with more sarcasm
    Jul 21, 2006
    12,932
    LOL - nice torque specs!
    #13
  14. C/1/509
    Jul 21, 2006
    12,932
    Yup - I like the idea of a drop of paint on critical fasteners.
    #14
  15. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    15,115
    New(er) Mexico
    The paint is a torque inspection marking and doesn't lock anything. Sometimes it's applied between the head of the bolt and part, so any rotation of the bolt head causes the paint to crack.
    Unless the manual specifically states to use threadlocker on the caliper bolts, do not use it, but do use a torque wrench.
    #15
  16. TripleTriples
    Feb 6, 2019
    370
    OH
    Caliper bolts are roughly three uggaduggas on the 3/8 impact.
    #16
  17. Ducky 149
    Ducky 149 Been here awhile
    Oct 20, 2006
    804
    Roswell Jawja
    Another vote for none.
    #17
    SmittyBlackstone and Johann like this.
  18. RonKZ650
    RonKZ650 Been here awhile
    Jun 11, 2009
    829
    Lakewood, CO
    None here as well. Thread lock is meant for dealer mechanics as a backup safety measure in case they forget to tighten bolts, which is most the time. Do it yourself and use a torque wrench, no way in the world those bolts will ever come loose.
    #18
  19. KeithinSC
    KeithinSC Long timer
    Oct 18, 2009
    4,971
    Sandhills of SC
    Tighten until stripped. Then back off a half turn.
    #19
  20. baldman1
    baldman1 Long timer
    Jan 18, 2013
    1,533
    Wow nothing like making a simple thing complicated!
    #20
    kwb377 and ohgood like this.
