Who else is fed up with connectivity issues?
Discussion in 'Parallel Universe' started by SnoDrtRider, Sep 24, 2019.
  1. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    1,072
    CLT, NC
    Can you clarify
    "phone is connected to the tot"
    You mean tft?
    "the TFT works"
    You mean it gives turn by turn? So you are running Waze with a destination? (or in 'follow' mode?)
    And during all this your Connected app is off?
    You may need to check, as I see my Connected app often self starts and searches for the bike soon as I switch on BT.
    #21
  2. sfsmedic
    sfsmedic Been here awhile
    Jun 3, 2019
    143
    Southern California
    Yes tot = tft with auto correct interfering.
    Connect app is not on. I use waze with my destination plugged in on my phone which sits in a cradle connected to the gps mount.
    Regarding the tft turn by turn piggybacking off waze, I’ve only tried it once. I hate the turn by turn on the tft. It’s awful. So I just use waze.
    #22
  3. sfsmedic
    Jun 3, 2019
    143
    Southern California
    Tested it again today. I was getting turn by turn nav on the TFT and the only app I had open was Waze.
    #23
  4. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    Interesting!
    I have run Connected and Copilot at the same time; I wonder if I shut off connected if the TFT would show directions from Copilot...
    #24
  5. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    7,182
    South Jersey... Close to the Pines
    Tested the set up with the "BMW Connected" app disabled again today and everything worked as it should. I am going to updated the "Connected" team as to the findings. Something with their app is causing the problem.
    #25
  6. sfsmedic
    Jun 3, 2019
    143
    Southern California
    See! I is SMRT
    #26
    heatmizr likes this.
  7. SnoDrtRider
    Mar 21, 2006
    7,182
    Yes you is!
    #27
  8. That.guy
    That.guy Been here awhile
    Sep 28, 2018
    445
    Colorado Springs
    I use the Connected app for navigation all the time with a Pixel 3A phone and a Sena SMH5 headset and don't have problems. It doesn't seem to matter what order the devices are turned on in for them to work.
    #28
  9. sfsmedic
    Jun 3, 2019
    143
    Southern California
    Ok, new bike and now I’m having issues. Everything is hooked up and linked, shows music playing but I have no sound. I did have sound but the last start up i now have no sound.
    #29
  10. SnoDrtRider
    Mar 21, 2006
    7,182
    Not to be Captain Obvious but do you have the phone media volume up all the way? I always turn my volume down and forget to turn it back up.
    #30
  11. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    Maybe someday I will give this another try. When I get a helmet with speakers and comm maybe.
    #31
  12. sfsmedic
    Jun 3, 2019
    143
    Southern California
    Yes, I made that mistake once and will never forget again.
    Never rule out the obvious right?
    #32
    SnoDrtRider likes this.
  13. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    I prefer to say it the way my uncle used to, "always fix the easy stuff first".
    #33
  14. MCMXCIVRS
    MCMXCIVRS Long timer
    Nov 13, 2006
    1,784
    Calgary, Alberta, Canada
    That's an ID-ten-T error. Done it too.
    Curiously, my setup has been working remarkably well the last month. I had issues with getting the music to start on my phone and the BMW app started tracking again. I think it has to do with a recent android update on my phone making things more compatible somehow.
    #34
  15. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    Technology makes our lives easier!
    Lots of technology fucks everything up!
    #35
  16. SnoDrtRider
    Mar 21, 2006
    7,182
    Same here my setup has been working as it is supposed to for about a month now... I think the connected team has finally figured things out...
    #36
  17. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    But unless you've gotten your bike software updated a month ago, wouldn't it be on the Android or device side of things?
    With the speed at which all this moves, it's got to be difficult for any manufacturer to ensure compatibility and all functionality...
    #37
  18. Oilhed
    Oilhed MarkF Supporter
    Oct 17, 2003
    17,561
    Connecticut
    Thats what I bought last year. Already had a Zumo 395 that's suppose to act as a hub with my iPhone. The music controls on the GPS work for a day or two each spring then stop working for the rest of the year. I have to power up in this order iPhone, GPS, Sena for everything to sync. If one doesn't it will never repair itself. And I need to make a phone call before the music will play in my helmet. WTF
    #38
  19. SnoDrtRider
    Mar 21, 2006
    7,182
    The hub should be the TFT the phone gets connected to the TFT and the Sena gets connected to the TFT the GPS gets connected to the headset but you need to turn off the phone and media in the GPS and allow the TFT to take over those controls.
    #39
  20. SnoDrtRider
    Mar 21, 2006
    7,182
    It is on the Phone side... The BMW Connected app on the phone has been updated several times in the past few months every update to the app seems to make the connectivity work better and more reliably.
    #40
