Who else is fed up with connectivity issues?
Discussion in 'Parallel Universe' started by SnoDrtRider, Sep 24, 2019.
  1. Oilhed
    Oilhed MarkF Supporter
    Oct 17, 2003
    17,561
    Connecticut
    I’m sorry I didn’t realize this was a BMW thread. I’m using the set up on Harley with no bike audio system.
    Basically the Zumo doesn’t work as advertised.
    #41
  2. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    1,072
    CLT, NC
    I can't see how to get the Connected app to update. What's the secret?
    Do I need to uninstall / reinstall?
    #42
  3. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    7,182
    South Jersey... Close to the Pines
    What phone?
    #43
  4. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    Android
    #44
  5. SnoDrtRider
    Mar 21, 2006
    7,182
    Open the Play store... On the top left you will see three lines which is the menu button normally called "The Hamburger". Open the menu and click on "My apps and games" the screen will open that shows all your apps and the ones needing updates will say "Update" next to them. You can also click the "Update All" button to update them all which I do at least once a week.
    I usually have my phone plugged in doing this so I know the battery is sufficiently charged to get through the process.
    The time it takes depends on how many apps need updates.
    You should have "Automatic Updates" turned on to keep all of your apps up to date. You should be able to set the phone to "Update on WiFi only" in order to save data use.
    #45
  6. heatmizr
    Jan 5, 2012
    1,072
    CLT, NC
    Thank You - My wife just showed me that while you were probably typing it... when the hell did they move all that functionality into the Play store?? I've always gone into my phone settings under Apps...
    Okay I think I'm updated now, it's a bit more complicated for me because I have two phones... One I use primarily as the Nav on the bike which I really need the Connected app on (which typically doesn't have Wi-Fi turned on), and the other is my main phone which I also like to have it on as well.
    #46
  7. SnoDrtRider
    Mar 21, 2006
    7,182
    THat has been one of the functions of the Play Store since pretty much the beginning of Android I had it on my Original Motorola Droid 10 years ago.
    #47
  8. pbrown007
    pbrown007 n00b
    Oct 15, 2020
    3
    Franklin, TN, USA
    Gang, I'm running into the exact same issue. I've used all kinds of Bluetooth devices (ear buds, power beats, SLR2) and I've experienced the same issues. Works in the beginning then stops working...especially when I turn the bike off for a quick stop. It's even worse often because I see it connected, but no sound comes through even though it says the music is plahing. I have to essentially re-establish the connection. I'm anxious to try turning off the Connected app...I always have it on and wonder if that's the issue. Thanks for contributing here and I'll reply back if turning off the BMW app fixes my issue.
    #48
  9. sfsmedic
    sfsmedic Been here awhile
    Jun 3, 2019
    143
    Southern California
    Mine required a SENA update and that helped my issue.
    #49
  10. dolomite
    dolomite Adventurer
    Oct 14, 2019
    87
    Albuquerque, NM
    Yes, update your Sena firmware and stop using the Connected app. Also follow this pairing order. All of that and I haven't had any issues in months.
    #50
  11. pbrown007
    pbrown007 n00b
    Oct 15, 2020
    3
    Franklin, TN, USA
    Thanks to both dolomite and sfsmedic. I will try this approach. I have a new SMH10 on the way and will follow the pairing instructions.
    #51
