who makes throttle cables?
Discussion in 'Equipment' started by tony v, Oct 8, 2002.
  1. tony v
    tony v visegrip
    Jun 13, 2002
    16
    USA, San Francisco
    I'm looking for a lead on somebody who makes after market throttle cables. I put a pair of risers on GXSR and the damd cables are an inch to short. Can ya help a brother out?
  2. Chopperman
    Chopperman I am dead
    Sep 17, 2001
    27,033
    Barnett has everything you need to make them yourself.
    I had to do it when I put mikunis on my BMW and when I discovered that the hand controls for the Goose were unobtanium.
    All it takes is silver solder (not resin core), flux and a propane torch.
    http://www.barnettclutches.com/pages/cables/cable_guide.html
    I got my stuff from a local independant bike shop.
  3. Chopperman
    Sep 17, 2001
    27,033
  4. jocflier
    jocflier Dammit, that hurt... Supporter
    Jul 7, 2001
    2,849
    Menlo Park, California
    Tony..
    Your in the Bay area..contact Motion Pro in San Carlos..
    Joc
  5. johnjen
    johnjen Now, even more NOW!…
    Nov 28, 2001
    17,021
    Chop, have you ever used stock BMW cables and modified tham to suit??? Thats what I've used and they work really well... I especially like the teflon insert (no lube necessary or wanted). They do cost a little more but they last and since you don't lube them, they're virtually maintanence free... JJ
  6. Sa-tevo
    Sa-tevo Jetmechs' Winston Wolf
    Jul 30, 2002
    505
    Near the compound of Peachtree City Georgia
    How do you wash out or neutralize the flux in the cable after soldering, to stop it from corroding the cable later on?
    Which leads to:
    Ta-da
    Have your nipples ever fallen off?
  7. Steverino
    Steverino Arrogant Horse's Ass #1
    Nov 16, 2001
    36,679
    Virtually maintenance free until they fray and get stuck in the cable guide. DAMHIK
  8. Chopperman
    Sep 17, 2001
    27,033
    most modern cables have a teflon insert.
    and as for those that aint. lubing takes a couple minutes twice a year.
    #8
  9. Chopperman
    Sep 17, 2001
    27,033
    Nope. I used resin core once and it broke eventually. I then found out about using silver solder and it works much better.
    #9
  10. Stephen
    Stephen Long timer Supporter
    Feb 19, 2002
    3,476
    Austin, Texas, USA
    Boy, this is nothing compared to what you can hear on the topic on the Bevelheads (that's old Ducatis for you beemergeeks...real Ducatis for you Beltheads) list.
    Silver solder. No, plumber's solder. Torch. No, solder pot. No, iron. No, old iron that you heat with a torch. Don't let the solder wick up the cable. No, use solder liberally so the cable won't flex at the lever joint. No, don't. Use cable pliers. No, use a Dremel cutoff wheel. No, use a grinder. No, use cable pliers cuz a grinder or cutoff will get hot and detemper the cable. No, it will anneal the cable. Fray the end. Don't fray it, bend each strand to 90 degrees with pliers. No, use a hammer. Don't use a hammer, it'll work-harden the cable. Hold the end in a vise. Don't use a vise, you'll squash it. Put a tiny tack in the end before soldering to swedge it. Don't need a swedge. Gotta have a swedge. Bag the soldering, just use a screw-type barrel. A screw-type! That's worse than riding on a plugged tire! Plugged tires are fine. What type of oil is best...oh wait, that's a different thread.
    All that said, I'll try to be helpful now. We used brass tubing secured with...ta-daaaah...J-B Weld on the throttle cables of my friend's R69US with Dellorto carbs (round slide...) after failing to get solder to stick to the bloody teflon-coated cable (that's right, the cable). Been working fine for tens of thousands of miles now. Would NOT use it on a brake or clutch cable...but hey, let's hear it for JB Weld and scraps on hand.
    #10
  11. Chopperman
    Sep 17, 2001
    27,033
    :thumb
    When I do my x-country gig on the old goose, I am taking not only a spare cable but a few screw barrels as well. By virtue of doing so...the cable on the bike will never fail. Sometimes you have to carry a few pounds of PM talismans.
    #11
  12. fish
    fish Banned
    Jul 6, 2001
    47,727
    Gold Country
    Amen to that, brother choop. Since I keep a stop-n-go tire plugger kit on my bike at all times, I will never have another flat tire. I also keep a sightglass in the kit, so I'll never have to worry about one blowing out. I also keep a spare key on the bike, so I'll never lose a key again. I hope it works for my firstaid kit too :uhoh
    #12
  13. tony v
    tony v visegrip
    Jun 13, 2002
    16
    USA, San Francisco
    Hey thanks alot for the feed-back. I made some calls and found what I needed.
    #13
