Who uses their "Kill Switch"?
Discussion in 'The Perfect Line and Other Riding Myths' started by Big Doobie, Jul 4, 2012.
  1. Big Doobie
    Big Doobie Frustrated Redneck
    May 11, 2006
    539
    Tater Country Pee-yay
    I know they suggest using the kill switch, when one is finished riding, but I don't know why.
    I've been riding for years and use the key.
    Let my buddy ride my bike, went the start it, and had a WTF moment. Until I realized he'd turned the bike off using the kill switch.
    So what is the point?
    Please enlighten me.
  2. DAKEZ
    DAKEZ Long timer
    Mar 18, 2007
    19,888
    Begin Op Zoom
    It interrupts the electrical current thus turning the bike off. DUH!!!
    :D
  3. Handy
    Handy Sunburnt
    Sep 17, 2011
    1,667
    The great state of Idaho
    I don't use it often, usually only when my bike is taking a nap on it's side. I tend to think of as an emergency kill switch so you can shut down your bike in a hurry without taking your hands off the bars.
    I accidentally flipped mine once in the middle of nowhere with the bike off. Went to start it up and had an "Oh shit" moment! Luckily it didn't take me too long to figure it out.
  4. EggChaser
    EggChaser Been here awhile
    Aug 31, 2008
    536
    Hamsphire/Surrey Borders
    There has been quite a discussion about this on the Explorer forums, as the manual actually says don't use the kill switch unless it is an emergency and some dealers have implied that the on board electronics learn things as you use ride which are reset of you use the killswitch hence the reason why you should not use it.
    From the feedback in the other discussions, it appears that some US-based Motorcycle Safety courses tell you to use the killswitch so that out of habit it is the first thing you reach for in a real emergency.
    Not that I used the killswitch with any bikes to stop the engine normally, always used the key.
  5. trc.rhubarb
    trc.rhubarb ZoomSplat!
    Nov 15, 2011
    8,517
    Concord, CA
    I've always used it and never had an issue. Good habit to have for muscle memory at least for when you need it. Don't really know why, I just do.
  6. nwdub
    nwdub Banned
    Jul 25, 2011
    1,097
    PNW
    i use the kill switch EVERY time.
    never had an issue. It's like braking with both brakes or looking through the turn, if you don't practice it, you wont do it when you need to
    JG77, Flashdog and rpiereck like this.
  7. BykBoy
    BykBoy Meshuganeh Super Supporter
    Aug 21, 2003
    606
    Reston, VA
    I never used the the kill switch on my 2001 Triumph Tiger 955i. On the Tiger, the radiator fan would keep going after the ignition key was turned off. I took this as a sign from the manufacturer that it was OK to use the ignition key to turn the bike off.
    Now that I have a KTM 990, I started using the kill switch for one reason: the fan on the radiator stays on when I use the kill switch, but it does not when I turn the ignition key off. I take this as a sign from the manufacturer that I should use the kill switch to turn off the engine and let the fan keep going.
    tigerboy likes this.
  8. abnslr
    abnslr rides a motorcycle
    Mar 1, 2012
    496
    Trans-national vagrant
    I've been using mine, but only because the MSF instructors encouraged doing so. Since my procedure for turning off the motor is pretty rote, I don't think it's building the reflexes they were talking about, though...
    1. come to a complete stop
    2. put transmission in neutral
    3. extend side stand and rest motorcycle on it
    4. remove right hand from throttle and turn kill switch to "off" position
    5. return kill switch to "run" position
    6. turn ignition to "off" position
    7. dismount
    :huh
    Damn, after looking at it that way I think I'll just change to switching off the ignition!
    #8
  9. Big Doobie
    May 11, 2006
    539
    Thanks wise-ass. :rofl
    Seems like a dumb question, but I just couldn't imagine a situation where I saw an advantage to using it.
    And I felt like a dumb ass when it took me as long as it did to figure out why my bike acted dead.
    #9
  10. Flashmo
    Flashmo Whatever...
    Dec 21, 2008
    2,687
    Vagabond Hippie
    I never use the kill switch. I shut the bike off by putting the side stand down, then reach for the key. Unless the bike is in my garage, it is always parked with the tranny in gear.
    My wife uses her kill switch, when I jump on her bike I used to have to spend a couple minutes figuring out why it would'nt start "this time". Now I check for that kill switch first thing.
    #10
  11. fast4d
    fast4d Long timer
    Jul 27, 2007
    3,103
    Los Angeles, CA
    Only when parking on a grade so
    I can kill before releasing the brake while in gear
    #11
  12. dolomoto
    dolomoto Destroyer of Motorcycles
    Jun 9, 2005
    3,170
    Veneto, IT
    The Engine Cutoff Switch is useful as it shuts the engine off while the rider is still fully in control (both hands on bars, left foot on ground, right foot on peg). It eliminates the drama some manufacturers have designed into their bike with the various locations of ignition switches (by the headlight, behind riders leg, etc).
    YMMV.
    #12
  13. Waco
    Waco Renegade Sickle Hound
    May 16, 2002
    15,150
    Waco, Texas
    I used to use it always, because the safety people recommended it. Then I read in the manual that it's only for emergencies, so I quit using it. I figured that I might wear it out if it wasn't designed for regular use. You have to turn the key off anyway, you might as well leave the kill switch alone.
    #13
  14. atomicalex
    atomicalex silly aluminium boxes Super Moderator Supporter
    May 21, 2012
    11,105
    Detroit mostly
    I use it because getting to the key is awkward.
    #14
  15. kalonji
    kalonji nihilism or nothing
    Sep 16, 2009
    3,221
    Witness Protection
    I use mine to turn the bike off a block away, then shift into neutral, once in neutral I turn the key off and coast into the driveway. Other than that I just use it randomly when the situation may call for it.
    :huhI like using other people's kill switches when on group rides at a stop light. Who expects that?:ear
    #15
  16. Cpt. Ron
    Cpt. Ron Advrider #128
    Jul 9, 2001
    3,755
    Sacramento, CA
    #16
  17. Dolly Sod
    Dolly Sod I want to do right, but not right now
    Aug 18, 2003
    18,873
    Richmond, Va
    :huh
    #17
  18. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    7,967
    Southern Illinois USA
    Who's "THEY"? I generally just put the sidestand down, then turn the key to off as I dismount. Wonder what "THEY" say ‘bout that?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    <o:p> </o:p>
    BTW What good is it to have the fan running when the water pump isn’t? Cooling the radiator? <o:p></o:p>
    #18
  19. Dolly Sod
    Aug 18, 2003
    18,873
    Richmond, Va
    I would seem the next question in this thread should be, who has removed their side stand kill switch? :rofl
    #19
  20. Waco
    May 16, 2002
    15,150
    Waco, Texas
    I've read that coasting in neutral with the engine off is kind of a no-no, because a few things are still rotating in the transmission, but the oil pump isn't running. But, I can't imagine that doing this for short distances hurts anything.
    #20
