Why? Because I can. An ongoing F800 project.
Discussion in 'Parallel Universe' started by GregCo3000, Mar 2, 2016.
  1. GregCo3000
    GregCo3000 Adventurer
    Jul 14, 2014
    41
    Philadelphia, PA
    I'm the sort of guy who loves his '11 F800GS, but is never quite happy enough. But thats more of an internal flaw of mine over a problem with the bike. So, I figure I should start cataloging some of my work. I think you'll dig some of it.
  2. GregCo3000
    Jul 14, 2014
    41
    Philadelphia, PA
    Last summer, I built a luggage system around 3 pelican cases and a rotopax tank. My photos are limited, but I took a 12,000 mile tour around North America and it help up great.
    It's a 304 stainless tube structure with a variety of waterjet cut gussets and tabs. Uses only factory mounting points.
    Up front, I made a double duty crash bar/highway peg setup. 4130 chromoly tube with kevlar-reenforced nylon pegs turned on a CNC lathe at work.
  3. GregCo3000
    Jul 14, 2014
    41
    Philadelphia, PA
    Here's one of my first projects in the winter of 2014/15 after I picked up the bike.
    These are some super shorty levers with ball bearings at all pivots. CNC machined from 6061-T6 aluminum on my HAAS at work. They are very stiff and solid - no bouncing around, no play. The clutch is a workout in the whoops though. Working on a version two for this season.
  4. GregCo3000
    Jul 14, 2014
    41
    Philadelphia, PA
    This winter, I decided to reconfigure the front end. I started by doing the fork conversion. My doners were from a '99 Husqvarna. Here's a couple photos of the fixture I made on/for my bridgeport mill for the leg boring operation. I also turned some caps on my lathe for the old fork legs to accept the BMW cartridges. Now I have some legs for a future unknown project (Honestly, probably a hipster bike flip for a little extra cash in my pocket).
  5. GregCo3000
    Jul 14, 2014
    41
    Philadelphia, PA
    Next, I picked out my new head lamps - a Hella 90mm halogen projector low beam and a 120mm xenon driving lamp for my high beam. Instead of the parking light, I'll just setup a little red LED on the dash. While I ultimately decided against this orientation, I did make a pretty cool bracket for them. It's 0.065" 304 stainless cut on a waterjet then bent in a brake and welded.
  6. GregCo3000
    Jul 14, 2014
    41
    Philadelphia, PA
    Next, I got a couple big pieces of aluminum and some Husqvarna plastics - A 2015 fender and fork leg gaurds from Acerbis. I love Husky's styling and hope to add a Husky to the stable one day.
    With all the pieces together, I modeled new crowns and programmed the Haas. These pictures show some of the machining process, and post-ops on my bridgeport at home. Cutting the steer-tube clamp slit with a slitting saw is a really terrifying process, but with lots of light cuts and plenty of cutting fluid, it turned out great.
    I brush blasted the finished parts and brought them in for a black anno finish. Finally, I setup one more time on the bridgeport to finish dimension the clamp bores. Our CNC mill at work isn't the best, so I don't trust the roundness or precision required for the clamping interfaces. I chose to clean them up with my boring bar at home.
  7. GregCo3000
    Jul 14, 2014
    41
    Philadelphia, PA
    More crown pics.
  8. GregCo3000
    Jul 14, 2014
    41
    Philadelphia, PA
    Time for some bar clamps. I machined the standoffs at home out of 2" round stock aluminum. I started with machining some flats on the ends of the stock. This will help register the part when I flip it later. Next I bored the clamping surface the machined flats which will be the sides of the clamps. Then I split the stock in half at the bore and turned a taper and through bolt hole on the, now, two parts. The top clamp is one piece which I machined on the HAAS cnc. It has a hole pattern for my Garmin mount and is otherwise only exceptional in it's fancy looks. This was all bead blasted and anno'd aswell.
    #8
  9. GregCo3000
    Jul 14, 2014
    41
    Philadelphia, PA
    More clampy pics.
    I also made custom stainless hardware that passes through my silicone vibration damping stack. Turned on the HAAS cnc, these have an M10 internal thread and I used a rotary broach to put an 8mm hex on the cap side. The top nut for the steering tube is very similar, but has an M20x1 male thread.
    #9
  10. Loutre
    Loutre Cosmopolitan Adv Super Moderator
    Nov 28, 2010
    14,349
    :o)
    fill out that profile
    #10
  11. epicxcrider
    epicxcrider Been here awhile
    Nov 2, 2011
    659
    Seattle, WA
    Welcome Buddy :)
    #11
  12. soyanarchisto
    soyanarchisto Long timer Supporter
    Sep 1, 2005
    7,532
    Sunny PDX
    Nice! Can't wait to see the finished project.
    #12
  13. HandKPhil
    HandKPhil Been here awhile
    Oct 26, 2009
    686
    Southeast Michigan
    Mad machining skills. I'm a mechanical designer who uses Autodesk Inventor every day at work. I can model just about anything up and make nice drawings, but I have no machining skills or equipment. I have to pay others to realize my fancy parts :-(
    #13
  14. Tyrann
    Tyrann n00b
    Jan 20, 2016
    3
    Oslo, Norway
    awsome
    #14
  15. GregCo3000
    Jul 14, 2014
    41
    Philadelphia, PA
    Welp, Philly strikes again. Stolen two weeks ago. Here's where I ended up.
    Looking at a 650X Challenge now. I figure I can knock 20lbs off it in no time...
    #15
    klimtachakka likes this.
  16. sarathmenon
    sarathmenon Armchair Adventurer
    Mar 29, 2012
    1,540
    SFO Bay Area
    I feel so worked up when motorcycles get stolen. A motorcycle is more personal to someone compared to a car. Hope you get some decent money from insurance.
    #16
    kiwimichel likes this.
