Why brighter more focused LEDs are better.
Discussion in 'Equipment' started by spiderman302, May 16, 2019.
  1. spiderman302
    spiderman302 Recalculating
    Nov 29, 2010
    360
    Ventura County
    This is it in a nut shell
    There seems to be a real problem with automotive and bike lighting. NO ONE is leading the charge to a better system.
    DOT seems to be stuck in the 1970's. It took them 20 years to approve the H4 system. DOT is a follower not a leader.
    Current metrics are dismal at best. Our present low beams only illuminate to 150 feet with the normal 900 lumen halogen bulb, (dual) headlight levels (1800 lumens). 35 mph total stopping distance is 150 feet. 70 mph total stopping distance is 300 feet.
    In order for us to see twice the distance we will need FOUR times the light! Inverse square law.
    50% brighter or twice as bright is NOT enough, we need 400% brighter to see twice as far.
    So the low beam bulb needs to increase from 900 lumens to 3600 lumens, (or 7,200 lumens total ) for us to be safe at freeway/highway speeds.
    This is exactly why the new brighter and correctly focused leds bulbs are needed.
    Now I will argue that 4 times is a minimum and that 10 times brighter is the better number.
    Our vision is logarithmic so a 10 fold increase is not a big deal.
    Now the glare issue is made into a stumbling block. The 700 cd number was derived and held over from the incandescent days before the H4 system, projector systems, and better lens/reflector designs. The newer systems with their sharp low beam cutoff can work with much brighter bulbs and still pass the 700 cd glare requirement. The interesting thing is, at the higher light levels on the road you the driver are less affected by on coming glare. With more light you do see better and your eyes respond faster. If everyone increased their low beam light level 10 fold then the 700 cd glare threshold could be increased a little.
    We are already doing this. Most of you have changed your headlights to brighter LEDs and added aux lighting to your bikes as well. There is a new truck on the road that has 4 low beams and fog lights too. The newer cars and bikes are using brighter leds. It would be nice if there were aux LOW beam led lights (narrow fog with hot spot with a sharp cutoff ) that we could add. How about a LOW beam led light bar...... future cars will not have two low beam headlights but led lights all across the front of the car.....
    If properly focused and shaped, more light is better.
    If we can increase the light level to what is needed for the speeds we drive then everyone will benefit.
    Unfortunately there is still a lot of junk lights out there that is making progress difficult..
    OK,I stirred the pot, time to go ride........
    oops, I got my numbers wrong the low beam is 900 lumens and the high is 1500 lumens. I corrected the mistake.. Thanks
    Jim K. and Richarde1605 like this.
  2. George Hanson
    George Hanson Been here awhile
    Feb 4, 2016
    777
    PA
    Ok, so what LED bulb that I can use in a stock round headlight bucket fits that description?
  3. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    6,449
    below the sea
    I can't comment on any of the LED's available, but my last car despite having projector headlamps, was not good to drive at night on its halogen. I bought some very cheap HID Chinese (but turned out good quality) burners and the rest of the stuff.
    I found the improvement on dip beam so good, I rarely had to use mainbeams. As the OP mentions, the quality of the cut off makes this possible and workable.
    Seems like once dazzle is under control, the sky is the limit.
  4. petertakov
    petertakov Been here awhile
    Jun 19, 2012
    460
    That is the question he's been hoping for and here is the answer he'll give you - Evitek. Job done - time to start yet another Evitek promo thread. Have I mentioned Evitek?
    worwig likes this.
  5. George Hanson
    Feb 4, 2016
    777
    PA
    But does it work?
  6. petertakov
    Jun 19, 2012
    460
    Even with the sharpest beam cut-off a light that is too bright won't work because the roads are not perfectly level or flat and if you suddenly get hit by 10k lumens of blinding blue light because of a bump on the road or whatever you are effectively blind for several seconds at least. Most people with blinding aftermarket LED abominations don't care much about on-coming traffic ... until it passes straight through them, that is. Modifying headlights is illegal and rightfully so, I just wish cops were more strict about it. This is one of the most reckless and dangerous mods one can do to a vehicle.
    Unfortunately, this forum is turning into a p!ayground for people selling all sorts of crap.
    Navy Chief and Sonny S. like this.
  7. George Hanson
    Feb 4, 2016
    777
    PA
    Perhaps, although not as dangerous as not being able to see shit at night, like on my Scrambler. Absolutely worthless headlight
  8. petertakov
    Jun 19, 2012
    460
    Well, then your scrambler has a shit headlight, but that's not because it's not LED and it will most certainly not get better if you put an aftermarket LED bulb in it - be it Evitek or similar DIY crap. The shittiest headlight I have aver seen is on the new Yamaha MT09 and it's stock LED. One of the best is on my Kawasaki W800 (halogen H4 with a properly designed lens) - It puts a lot of cars to shame.
    If you are riding off-road, put whatever you want, but on the road it's just stupid, dangerous and illegal. As long as there are no road certified LED retrofits by reputable manufacturers (Philips, Osram, GE) then it means it can't be done properly. There is much more to a headlight than just blunt lumens. The LED cult will try to make you believe that LED is better because it's supposedly brighter but that is a lie. It's not brighter - it's just more efficient and that is the only reason it is being pushed nowadays. The brightness of road legal bulbs is not limited by the halogen technology - there already are halogen bulbs that are too bright to be road legal. LED light is also way worse for your eyesight and that has been discussed to death already.
    #8
    Sonny S. likes this.
  9. Sonny S.
    Sonny S. Been here awhile
    Nov 23, 2015
    809
    Maryland
    I've had vehicles with 6 Volt systems and sealed beam headlights and I NEVER hit something because I couldn't see it. Lighting has gotten out of control because it's CHEAP to produce CHEAP lights. You can't even look at a candy bar in the grocery store without being blinded by bright LED's.
    #9
    petertakov likes this.
  10. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    27,053
    Nippon
    Phillips you say?
    https://www.philips.com.sg/c-p/12985BWX2/x-tremeultinon-led-headlight-bulb/specifications
    In the US, there is NO DOT (Federal) regulation covering the light source, ONLY the lens/enclosure. Those must be DOT marked to be road legal (so yes, all of your aux lighting is illegal) you can look this up yourself its CFR Title 49 Section 7.2.
    Its also the DOT we have to blame for the fact that motorcycles here don't get the standard LED marker/signal lights that everyone else does, because there is some ancient surface area requirement so the smaller, lower power, more reliable AND brighter markers standard literally the rest of the world over and we get "euro signals" with an orange halogen in a clear enclosure.
    Now when you get into states and localities this becomes a different ball of wax, some states prohibit modification full stop, others don't regulate at all.
    That all LEDs are illegal is erroneous, at least in the US, it goes back to Audi's "smart lights" system that was flat out banned due to a 60s era NSTA requirement that the main lighting of an automobile be switchable (because the US is about 50 years behind in such matters) seen here https://www.roadandtrack.com/new-ca...volutionary-audi-headlight-tech-banned-in-us/
    In Japan its damn near anything goes as long as its both focused properly and bright enough (you will get dinged for both at annual inspections) as long as your aux lights are 1) switchable 2) Below the main beam 3) the switch is labeled.....all of which the guy running Shaken-jo may or may not get you for (a friend got dinged for the label, with a light-bar mounted over his cluster)
    #10
  11. petertakov
    Jun 19, 2012
    460
    @Tripped1 take a look at the "homologation" line in the spec you shared - there is a big "NO" there that you've missed. And I am not saying ALL LEDs are illegal - just the retrofits and just in the civilised world. But I agree with you that LEDs are the best option for blinkers, signals etc. and that is why almost all new bikes in Europe come with them, so you got that wrong too :-))
    #11
  12. Tripped1
    Aug 6, 2009
    27,053
    Nippon
    Not in the US. Want to see the stock turn signals from my US Spec KTM . I promise you they are different from the LED units on European spec bikes.
    https://books.google.co.jp/books?id=vhEJBAAAQBAJ&pg=PA677&lpg=PA677&dq=49+U.S.C.+30115&source=bl&ots=6nwamygpGt&sig=ACfU3U2GXLYtIPTYQ9Q6hSm3OdYvnlfukg&hl=en&sa=X&ved=2ahUKEwjbn4TruaTiAhWGVbwKHTvhBkIQ6AEwB3oECAkQAQ#v=onepage&q=49 U.S.C. 30115&f=false
    Page 342
    Only that the lightsouce must conform to Section 11 i.e. since DOT is not a certifying authority. You are supposed to "conform" to there standards
    By this FMVSS-108
    file:///C:/Users/kenke/Downloads/TP-108-13.pdf
    There is no maximums listed in the test spec. So in by US (Federal) law if it meets the minimum and is marked correctly. The light source is legal. Like I said after that its state by state. Focus is more important than power, I ran into this one with the LED in my KTM. emitters are just a bit to far forward and high (compared to halogen) so I had to shim the baseplate across the to top to get it into a proper lower than horizon beam.
    That bike also has relatively large 55w aux lights
    That photo is full bright, when not on "brights" those all pulse modulators that spool all of that down to 20% of max intensity, I can also have a thumb wheel for the aux lights so I can bring them up a bit so I can see where I am going without firing off the lights of doG.
    Stock that main bright light was only good for going maybe ~50mph 80km/h and then ONLY if the bike was vertical the aux lights are a spot flood pattern than lets me see where I am going when the bike is off center. Now I have options depending on environment.
    There roads here frequently feature greater than 90* corners in the mountains, stock lighting was a leap of faith after dark OR a matter of humping someone's rear tire that DID have adequate lighting. The drivers in Japan run their brights nearly full time after dusk outside the cities/towns for that very reason.
    #12
  13. petertakov
    Jun 19, 2012
    460
    @Tripped1 sorry, I tried but I still can't really understand what is your point? In a sentence or two, if possible.
    #13
  14. Tripped1
    Aug 6, 2009
    27,053
    Nippon
    'Only that the lightsouce must conform to Section 11 i.e. since DOT is not a certifying authority. You are supposed to "conform" to there standards
    By this FMVSS-108
    So yes, retrofits can and are legal (at least in the US) whether or not you like them.
    #14
  15. petertakov
    Jun 19, 2012
    460
    I never said they are illegal in the USA and I couldn't care less, to be honest.
    #15
  16. Tripped1
    Aug 6, 2009
    27,053
    Nippon
    They aren't illegal in Japan.
    ...and trust me they DO check both focus and brightness.
    #16
