Why you should NOT buy a Ural motorcycle
Discussion in 'Hacks' started by bokad, May 28, 2012.
  1. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    11,211
    Omicron Persei 8
    Gasoline here in the USA weighs 6.8lbs/gal so that's only 27.2 additional lbs. That being said, I can think of more than one reason to NOT have all of that fuel (and weight) up front and some of my reasons would include physics. The physics and safety issues of having that fuel located there are not exclusive to Urals.
  2. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    8,995
    Tacoma - ish, WA
    Actually, Strong, the guy said above it's 10 gallons so they must be 2.5 gal Roto's (there are 4 of them) giving him 10 gallons or 68 lbs of extra gas. So my guesstimate of 50 lbs was too low!
    The guy who posted the pic is free to carry his extra fuel anyway he wants. Not for me to say. I'm guessing that he has not experienced his pusher going airborne because he has enough tongue weight on that trailer to keep his pusher planted. In other words, the trailer tongue weight is counterbalancing the 68 lbs. I posted my first comment about this simply because I was concerned that some noob would see that pic and say "Aha! What a perfect place to carry extra fuel!"
    rg sw wa., BMWBUD, Bobmws and 4 others like this.
  3. JustKip
    JustKip Long timer
    Apr 28, 2007
    8,687
    Fresno, CA
    Assuming the trailer is always on while the fuel is hanging off the front. Otherwise, it's a catastrophe waiting to happen.
    rg sw wa., Bobmws and norton(kel) like this.
  4. High Octane
    High Octane Long timer Supporter
    May 31, 2013
    2,520
    South Dakota
    What he said.
    rg sw wa. likes this.
  5. MojaveSidecar
    MojaveSidecar Been here awhile
    Dec 30, 2003
    662
    Wrightwood CA
    Ouch...
    rg sw wa., Bobmws and steam powered like this.
  6. Lomax
    Lomax Nanu-Nanu Adventurer Supporter
    Jul 15, 2004
    11,470
    Westminster Colorado
    I have had the pusher wheel come up a couple of times and it is not very confidence inspiring. :lol3 OK more like :p3rry
  7. BMWBUD
    BMWBUD I couldn't hack it. Back on two wheels.
    May 15, 2006
    2,569
    Mid-Wurst Southern Illi-noise
    rg sw wa., Strong Bad and Bar None like this.
  8. Bar None
    Bar None Long timer Supporter
    Mar 2, 2007
    13,093
    SWFL WNC
    Could be one hell of a fireball.
  9. Strong Bad
    Oct 29, 2007
    11,211
    Omicron Persei 8
    I did my calcs based on your question (are those 2-gal Rotopax?) and a very quick glance. With a bit closer look it appears that he has both a 2 gal and a 3 gal on each side. So your 68lbs is correct.
    rg sw wa. and DRONE like this.
  10. RomaDakota
    RomaDakota Experts agree!! Supporter
    May 15, 2006
    2,885
    Goldilocks Zone
    I have done quite a bit of sliding and drifting with my Dnepr. On a hard left turn the sidecar wants to dive with NOTHING in it or on the nose. I cannot image that much weight up there. I generally get a chuckle when anything is bolted to the nose of these things.
    rg sw wa. and JustKip like this.
  11. Tom48
    Tom48 Long timer
    Jul 22, 2004
    1,057
    Fremont NH
    I have a 06 Ural. No major problems. Some have issues, but mine will be my last.
  12. Bar None
    Mar 2, 2007
    13,093
    SWFL WNC
  13. edmKC
    edmKC n00b
    Apr 26, 2012
    3
    After going through two Hall sensors from Ural, I bought a few of part number CYHME1AV here: http://www.hallsensors.de/Hall-Vane.htm
    I just used the plug from one of my failed sensors. The wires are the same colour so I just soldered like to like. Works well and cost about $15CAD so WAYYYY cheaper than Ural.
    Mechanista and DRONE like this.
  14. tbird649
    tbird649 Been here awhile
    Dec 28, 2009
    236
    West Sussex, UK
    Brilliant!!! Thats exactly what I was looking for a couple of years ago when mine failed. Found the equivalent sensor on several sites, but always discontinued or out of stock. I will order a spare. Thanks for posting.
  15. mangizmo
    mangizmo Adventurer
    Oct 7, 2018
    24
    UK
    Great post, I just knew there must be an alternative, thanks :-)
  16. JoshBMW
    JoshBMW Been here awhile
    Sep 3, 2010
    632
    Nampa, ID
    Well I screwed up. Put $ down on a shiny terra-cotta red one. I’ll post when I pick it up.
    rg sw wa., Mechanista, gec343 and 6 others like this.
  17. MGV8
    MGV8 Long timer Supporter
    Aug 29, 2010
    1,012
    Canoe BC
    I always carry two Roto's but on the rear of the Ural car. I like the weight out board. Totally different subject as I ran into an interesting issue with our ferry system. ( BC ) The Gal wasn't going to let me on because I had two fuel cans. Apparently one container up to 25 litres. Asked me to leave one behind. Luckily the Harley guy ahead offered to carry it for me, cause I wasn't going to leave a hundred dollar roto behind. Really makes no sense but rules are rules I guess.
    Back to regular lurking
    rg sw wa., Bobmws, CROSSBOLT and 2 others like this.
  18. Bar None
    Mar 2, 2007
    13,093
    SWFL WNC
    You will be fine. Had two Urals over a 6 year period and only issue was two flat pusher tires.
    Probably outta start a new thread for your new rig, just saying. 2018 or 2019 ?
    rg sw wa. and CROSSBOLT like this.
  19. gec343
    gec343 Long timer
    Jan 13, 2005
    1,068
    Evart, Michigan
    Congratulations on ordering the new Ural. I've had my 2019 Gear Up for just over 3 months, 2600 miles. No issues and I absolutely love the rig. Pugsley loves it even more!
  20. knuckle
    knuckle Been here awhile
    Jun 8, 2008
    102
    Cistern, Tx
    You will like that terra-cotta red. I had a cT that color. I think it is one of the better colors they have come out with.
