Wife's '09 F650GS keeps blowing headlight bulbs... ?
Discussion in 'Parallel Universe' started by Mollygrubber, Oct 8, 2014.
  1. Mollygrubber
    Mollygrubber Eschew obfuscation
    Feb 2, 2010
    1,672
    Vancouver, BC
    Need your advice here, electrical geniuses... Mrs Mollygrubber's '09 650 keeps blowing headlight bulbs, both high and low beams, but the little front running light is still OK. She says her digital display intermittently goes blank too, when she stops in traffic (?).
    I'm not that electrically savvy, I can add lights and run wiring etc., but the vagaries of CANBUS systems is a little beyond me. Are these issues related, or a computer issue, or is it more likely a simple short? I haven't torn into it yet, didn't have the heart after just dropping multiple thousands on her car :lol3.
    Any pre-emptive advice appreciated, thanks!
  2. Bollocks
    Bollocks Farts with an Accent™
    Oct 14, 2005
    7,124
    Watauga lake, 10-E-C
    They all do that, it's called a feature.
    9Realms likes this.
  3. Reaver
    Reaver Why am I still here?
    Aug 7, 2008
    22,497
    CR
    When's the last time you cleaned and tightened the battery connections?
    How old is the battery?
  4. Mollygrubber
    Feb 2, 2010
    1,672
    Vancouver, BC
    Hmm. That's a good point. Original battery, and all these shenanigans started right after I installed her GPS. I know I snugged down the connections (twice - I checked that first, and removed the GPS for good measure), but I didn't consider the state of the battery, because she really doesn't ride all that much. I guess a lightly used 5 year old battery is still a 5 year old battery :lol3. OK, I'm a dumbass. I'll get it replaced.
  5. Reaver
    Aug 7, 2008
    22,497
    CR
  6. Mollygrubber
    Feb 2, 2010
    1,672
    Vancouver, BC
    Thanks man, you're a sweetheart :freaky
  7. Dorito
    Dorito Dreamer and Doer
    Jul 31, 2010
    7,612
    Maryland
    Mine ate bulbs for the first 50K miles. Like one every 7-9K miles. I attributed it to off-road riding. However, it's been a good streak...about 12K on this bulb !
  8. ibgary
    ibgary Long timer
    Oct 18, 2013
    2,049
    Colorado
    That sounds strange. 7 bikes and over 200k miles and only 1 headlight.
    Sent from my HTC One_M8 using Tapatalk
    #8
  9. malloy
    malloy Long timer Super Supporter
    Sep 25, 2006
    6,336
    SOUTH OF THE BORDER
    #9
  10. vtbob
    vtbob wanderer
    Jun 20, 2009
    690
    Western Vermont
    FWIW
    Get the output of your Rectifier/Regulator. Simple volt meter check. Vary the RPM of the engine.
    I don't know the specific specs...but some one on this site does.
    I believe the charging voltage is approx 14.5 volts.....I believe much higher than that could be a problem..
    Also chech the ground side of the RR to see if it too is a good reliable connection.
    #10
    runnr548 likes this.
  11. Glenn247
    Glenn247 Long timer Supporter
    Feb 25, 2014
    2,099
    Lynchburg, VA
    Another twin eating headlight bulbs. Just had another one burn out so that makes two in 21k miles
    So can someone suggest a better bulb and where to purchase from online?
    #11
  12. runnr548
    runnr548 BMW Pilot
    Mar 16, 2012
    206
    The Atomic City
    Regulator/rectifier issue is the most likely problem.
    #12
    roookie1 likes this.
  13. CheckerdD
    CheckerdD Long timer
    Apr 30, 2005
    1,496
    Dave Rankine, Reno NV
    my 1200 used to blow a bulb a year. Big deal.
    #13
  14. charliektm400exc
    charliektm400exc Been here awhile
    Sep 21, 2006
    309
    Hobart
    #14
    Daryloftexas likes this.
  15. Daryloftexas
    Daryloftexas Been here awhile
    Mar 12, 2017
    207
    arizona
    take a real good look at the connector for the headlight. ive had my 800 for about 13,000 miles and had one bulb go out, was the stock bulb and bike was at 21,000. also make sure the rubber boots where the headlight is mounted are still in good shape/ bolts tight and all that.
    #15
  16. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,866
    Middletown, PA
    Aug 2017 edition of Motorcycle Consumer News. Go to page 6, Downtime. There is a discussion on electrical issues, particularly about headlight bulbs blowing out. Discussion revolves around the "halogen cycle" that helps bulb filaments last longer but provides no protection from burning out if bulb voltage drops to 70-80 percent of rated voltage (like 10.2VDC). Maybe check voltage at the bulb? Article also mentions vibrations but the suggestion was to check voltages first.
    #16
    charliektm400exc likes this.
  17. Woody2627
    Woody2627 Grey Wobbler
    Nov 11, 2008
    7,736
    Jindabyne
    I fitted my 4th this morning, at 60k. Lights don't last forever.
    #17
  18. ChicoProf
    ChicoProf Been here awhile
    Aug 17, 2013
    746
    Chico, CA
    I've replaced two headlights on my F700 across 3+ years and 18,000 miles. Doesn't seem like a big deal to me at $7 a bulb off amazon. I usually keep a spare, or if I don't have my tank bag, I swap the high beam into the low socket til home.
    #18
  19. SubAtomicGenius
    SubAtomicGenius Moto Villian
    May 30, 2014
    1,904
    Dark Side of the Moon
    Was
    Was going to mention vibration as well, may also be worthwhile for to check out the torque on the headlight adjustment bolts.
    How do you find the LEDs from Cyclops, no worries about those vibrating and burning out!
    #19
  20. nickgindy
    nickgindy KLR Basher
    Jun 30, 2011
    3,272
    Indianapolis, Indiana
    Glad I'm not the only one. My bike is at 48k and has burnt a headlight bulb every 7-8k as well. Last night I just noticed this. This upsets me even more. [​IMG]
    Sent from my XT1585 using Tapatalk
    #20
