Will a low shock and stand off a f650 work on a 800?
Discussion in 'Parallel Universe' started by theshnizzle, Sep 19, 2016.
  1. theshnizzle
    theshnizzle Long timer
    Mar 24, 2011
    3,833
    Lost somewhere
    I know a lot of the parts are swappable between the 650,the 700 ad the 800. Maybe I should ask first if there is some quick way to check which parts are swappable because I cant imagine they all are. Anyway, I have a low shock and sidestand from a 650,will it bolt right onto a 800 to give me a lower height similar to a 650 ?
  2. Woody2627
    Woody2627 Grey Wobbler
    Nov 11, 2008
    7,736
    Jindabyne
    It will probably bolt on, whether you have a rideable bike afterwards is a different matter. Long travel forks at the front, low shock at the back? I don't think so.
  3. farqhuar
    farqhuar Human guinea pig
    Mar 3, 2008
    3,591
    Islands in the sun, Oztralia
    Not sure I agree Woody.
    On my last bike (G650 Sertao), I put a set of kouba links on the rear to lower the rear end 2", and left the front end as is.
    It worked great on and off - road, and gave me a lot more confidence in sand as it slowed the steering down.
    Best thing I ever did to the bike and can't see why it wouldn't work on the 800 twin.
  4. Woody2627
    Nov 11, 2008
    7,736
    Jindabyne
    I know what you are saying, and don't disagree, but the way I read the OP, he wants to put a shock off a lowered 650 on to an 800. I could be wrong here, but my thinking is that shock is shorter than a standard 650 shock, which is shorter than an 800 shock, so the total lowering could be 3 or 4 inches. But if he has the shock in his hot little hand, it will cost nothing to try it. I hope he let's us know how he goes.
  5. itsatdm
    itsatdm Long timer
    Jun 19, 2004
    5,440
    Nor Ca.
    You can't compare lowering links to a bike that has no links and connects directly to the swing arm. I can tell you this, a 5 mm shorter shock on my F800 results in a 15mm lower seat. A f800gs rear shock is 17inches eye to eye. What ever longer that is than your current shock will result in a taller rear end between 2 1/2 -3 inches per inch, taller than your current ride height.
  6. Cavi
    Cavi Been here awhile
    Apr 22, 2007
    344
    Red Bluff , Ca
    and for the front you can slide the forks up in the tree an inch or more
  7. Loutre
    Loutre Cosmopolitan Adv Super Moderator
    Nov 28, 2010
    14,349
    :o)
    We had someone ask that question about two years ago. I called my dealer and said that he bolted a 650 onto a 800 because of reasons. didn't report on how it did behave though.
  8. theshnizzle
    Mar 24, 2011
    3,833
    Lost somewhere
    I asked my local dealer if I could bolt on a low shock to lower a regular height bike and he told me it was impossible.....that you can only get a lowered bike from the factory.
    He was adamant about it and dismissed my insistence that it could be done.
    Sigh.....
    #8
  9. Reaver
    Reaver Why am I still here?
    Aug 7, 2008
    22,497
    CR
    Well Dear, you do have a way of using many words.......
    Dealers won't take the risk or liability on such mods, therefore it can't be done.
    #9
  10. africadero
    africadero ronny-king
    Dec 25, 2009
    180
    belgica
    #10
  11. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    1,189
    Lanark County near Ottawa ON
    #11
  12. Reaver
    Aug 7, 2008
    22,497
    CR
    3/4" diff last I measured.
    #12
  13. RBMann
    RBMann Been here awhile
    Aug 17, 2006
    305
    North of Seattle
    Even if it can be done, you will end up with a really low rear and a poor shock.
    #13
  14. theshnizzle
    Mar 24, 2011
    3,833
    Lost somewhere
    Can I buy touratech at wallymart? :D Otherwise waaaaĆ y out of my price range.....
    #14
