Will a "speed bump" across my driveway using cold-set asphalt repair material survive?
Discussion in 'The Garage' started by spin10k, Nov 7, 2019.
  1. spin10k
    spin10k Long timer
    Oct 6, 2015
    4,844
    St Louis MO
    Will an ~2 inch high speed bump made of the "asphalt repair in a bag" stuff harden and remain stuck to an asphalt driveway? I've thought of using one of those bolt-down plastic speed bumps, but due to the length, that would cost me around $500 + shipping.
    This stuff is made to fill in holes, so I don't know if it will simply "squish" out of the way if I try to build it up into a hump.
    (It's a long story having to do with management of water that comes down my driveway, that I want to intercept before it gets to my house, but I'll spare you the details.)
    TIA
  2. Motopsychoman
    Motopsychoman Not a total poseur Supporter
    Jun 2, 2013
    5,426
    Oaklandish
    How long does it need to be? There appear to be many sources for speed bumps made out of recycled rubber (tires). Seem to cost from $10 to $20 per foot.
    I'd be concerned with summer heat melting a hump made out of soft patch. Have you considered using Sakrete instead?
  3. spin10k
    spin10k Long timer
    Oct 6, 2015
    4,844
    St Louis MO
    Needs to be about 26 feet long.
    Details:
    26' is the approximate width of the area where my driveway meets the street - the idea would be to put it across the driveway, approximately parallel to the street, to prevent water that comes down the street from turning down into my driveway. I used to have a hump there, made by the previous guys who re-did the asphalt on the street, but just yesterday the street was done again, and these guys put so much new asphalt on there that my old hump is now gone. Had I known that they were going to be re-doing the street I would have arranged for them to do it, but it was a surprise, and now they're gone. (It's a private subdivision, and we hire the paving companies to do the work for us.)
    I have thought about Sakrete, but haven't ever used it for anything, and didn't know how much trouble it would be to make and form it. (or if it would stick to asphalt) My quick calculations say that I'd need around 3-5 ft^3, depending on the cross-section of the hump.
  4. spin10k
    spin10k Long timer
    Oct 6, 2015
    4,844
    St Louis MO
    At $10 / foot I think I might go for it, depending on shipping cost.
    I couldn't find anything that inexpensive.
  5. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,746
    Anchorage, formerly Spenard (hub of the universe)
    how about splitting some ABS pipe (tablesaw) fill it with goop, let it cure, flip it over and spike it down. or, use the half pipe as a mold for concrete.... probably want some mesh in there too. just a wag...
  6. PaulTim2000
    PaulTim2000 Been here awhile
    Mar 24, 2015
    354
    Leicester UK
    I was going to suggest splitting some scaffold pole or similar, bolting it down and covering it with asphalt repair to smooth of the transitions from drive to 'hump'
  7. AlpineRAM
    AlpineRAM PartsChaser
    Nov 16, 2007
    575
    Europe, Austria
    For temporary installations we use old fire hose filled with sand.
    For a longer term solution you can fill the hose with fiber concrete, form it and after curing time bolt it down.
  8. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    36,191
    Pittsburgh PA
    The cold patch is not going to be waterproof. It will be porous and the water will run through it. It will divert water during large storms.
    I would be looking at cutting the driveway with a saw and installing a drain across it.
    #8
  9. Granitic
    Granitic Backcountry rider
    Oct 10, 2014
    975
    New Mexico, USA
    Cold patch has gotten sophisticated in recent decades. It is tough but pliable to withstand temperature extremes: "Cold asphalt is not dependent upon warm weather. Highway repair crews like cold asphalt because it retains it pliable properties when the temperature drops, so it can be used in northern climates well into the fall and even early winter months."
    It is certainly not porous because many municipalities use it to fill potholes.
    Sakrete will crack quickly in MO winter conditions.
    #9
  10. Wkendwrench
    Wkendwrench Professional Lurker
    May 16, 2010
    51
    NEOh
    This!
    #10
  11. stormdog
    stormdog Long timer
    Feb 19, 2006
    1,734
    Almost Southern Oregon
    Cold patch will be fine. Use a propane blow torch from harbor freight hooked to a bbq grill tank to warm up and dry the road bed then apply the bagged stuff.
    #11
  12. Motopsychoman
    Jun 2, 2013
    5,426
    Oaklandish
    Check traffic supply places.
    #12
  13. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    8,320
    below the sea
    We had the same problem. I dug out a shallow trench - 6" deep at worst, dropped in some geo textile which got covered in cobble. Then wrapped the textile over and tucked it down, finished off with pebbles to match the rest of the drive. The down hill end I buried some storm drainage pipe and led that away to daylight under some trees and bushes.
    We now don't get the massive pooling every time it rains. Only down side is the greenery grows a lot faster now.
    Whole job took less than a morning, using stuff we had around and a length of scrounged 110mm pipe.
    Additional upside is I was forced to repair the big wheel barrow, which has come in very useful this autumn.
    #13
  14. nickguzzi
    Feb 17, 2010
    8,320
    below the sea
    A pic to illustrate the after, you can see where the pipe went under the hedge, next to the log.
    The neighbour has a large hump, which wears away, leaving big puddles
    #14
    spin10k likes this.
  15. Beezer
    Oct 26, 2004
    9,746
    "The neighbor has a large hump".... excellent Smithers
    #15
