Will F800GS Givi mount work on F700GS?
Discussion in 'Parallel Universe' started by Muffin, Aug 20, 2013.
  1. Muffin
    Muffin n00b
    Aug 20, 2013
    7
    Just got an 2013 F700GS. Givi lists the proper mount as the SR5107, sadly, I have not been able to find this mount in the US ("coming soon!") and the British site I found it on won't ship. It APPEARS that the F800GS has an identical rear mount and that mount (E194) is available. Does anyone know if the E194 will work on the F700GS?
  2. Muffin
    Muffin n00b
    Aug 20, 2013
    7
    Hmm, zero replies. FWIW, I ordered an SW-MOTECH mount from Twisted Throttle for my Givi Monolock system cases. I'll post an update for others with this issue when it arrives.
  3. servdave
    servdave Adventurer
    Oct 7, 2009
    62
    Brighton
    As far as I can remember I think both the 700 and 650 GS have the same rear. So it should fit both models.
    There is some changes across the two models, so do be carefull with other parts.
  4. Muffin
    Muffin n00b
    Aug 20, 2013
    7
    Ok, I mounted the SW-MOTECH steel topcase mount. Very easy install. Perfect compatibility with two Givi monolock bags tested. The mount without the topcase is very low profile and frankly looks better than the plasticky Givi mounts I've used in the past. A total win and highly recommended.
  5. minton82
    minton82 Adventurer
    May 9, 2013
    36
    Seoul
    I don't know if it's any help to others but I have the E194 (& PL690) mounted on my 2010 F650GS.
