Will I blow myself up?
Discussion in 'Parallel Universe' started by ADVBMR, Jan 11, 2015.
  1. ADVBMR
    ADVBMR Polygamotorcyclist
    May 18, 2007
    931
    Anchorage, AK and Ely, MN
    I want to mount a Centech AP-2 fuse box on a 2013 F800GS. The most accessible place is under the seat, which happens to be on the gas tank. I can secure it with epoxy so no screws. But I don't know if there is a fuel vent under there. I don't want to mount it on the airbox because it's not readily accessible. Any insight out there?
  2. manstache
    manstache Flounder of ADV
    Apr 3, 2010
    1,861
    Around
  3. Gillus
    Gillus High Desert Rat Super Supporter
    Jan 2, 2008
    2,531
    Alamogordo, NM
    1/4" lag bolts :lol3
  4. PunkinHead
    PunkinHead Moobless Adventurer Supporter
    Dec 10, 2005
    11,745
    Land of Walmart Shoppers
    Use adhesive backed Velcro tape.
  5. fast4d
    fast4d Long timer
    Jul 27, 2007
    3,103
    Los Angeles, CA
    3m double side adhesive
  6. RVDan
    RVDan Long timer
    Jun 4, 2010
    7,945
    Abbotsford British Columbia Canada
    If everything is functioning properly there will be no chance of sparks.
    If something powered by that fuse panel shorts out just ride like your ass is on fire.
  7. broncobowsher
    broncobowsher Long timer
    Apr 21, 2010
    4,711
    Baking in AZ
    Don't know the bike, does it have one of those fancy evaporative canisters on it?
    No, it won't blow up.
    But if that has a plastic tank like I think it does, and your wiring is bad enough that you are expecting things to short out, I would be more worried about a wire overheating and melting a hole in the tank
    I also owned a small block chevy that had a leaky carb fitting that never got fixed. And the original spark plug wires were crap and arced all over the place as well. 10 years later the car was dead but never caught fire. You are only dealing with gasoline, it's not like you are playing with pure hydrogen
    :kboom
  8. GreaseMonkey
    GreaseMonkey Preshrunk & Cottony
    Jun 16, 2006
    5,972
    The only county in Illinois with no train tracks
    #8
  9. dtysdalx2
    dtysdalx2 Just send it!
    Aug 1, 2004
    29,425
    Moneyapolis, MN
    +1
    #9
  10. Loutre
    Loutre Cosmopolitan Adv Super Moderator
    Nov 28, 2010
    14,342
    :o)
    :rofl:rofl:rofl
    arg now that my tears have dried: I use double velcro tape. Mine is under the rear rack.
    #10
  11. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,745
    Grand Valley, Colorado
    i doubt you will find any epoxy which will bite into the polyxxxxxxxxx tank. 3M tape or zip ties would work fine.
    #11
  12. imxman
    imxman Been here awhile
    Jul 27, 2013
    271
    OKC, OK
    Considering mounting it on top of the air filter instead. It will be closer to the battery and for the most part to the accessories that you are powering from it. Once it's installed you shouldn't need frequent access to it, thereby diminishing reasons to mount it under the seat to start with.
    This applies to models up through 2012 and frankly I'm not sure if configuration of 2013+ has the room on top of the filter. But certainly check it out anyway.
    #12
  13. MCMXCIVRS
    MCMXCIVRS Long timer
    Nov 13, 2006
    1,764
    Calgary, Alberta, Canada
    I mounted mine under the seat just ahead of the tank. I relocated the diagnostic plug and made a bracket to hold the Fuzeblock. Hasn't blown up yet. The fuel tank vent is way back in the tail section of the bike and even if it was next to the fuse block you install, its extremely unlikely that you'd ever have an issue with vented vapours even if you did a really shoddy job of the wiring. The more probable issue if you were to do a bad job of wiring would be an electrical fire.
    #13
