Will jump starting from a running car damage my bike's electrical system?
Discussion in 'GS Boxers' started by VDRZANE, Jan 19, 2005.
  1. VDRZANE
    VDRZANE Salty Adventurer
    Jul 6, 2002
    386
    Ohio, Earth
    This is a concern I have read about multilple times on this site and others, but have yet to see any suppporting documentation that prooves this theory. What is the issue, a higher amperage rating on the much larger car/truck battery?
    I just had to do my first jump start on my '03 GS Adventure the other day, and this topic came up.
  2. charles960
    charles960 Been here awhile
    Nov 10, 2004
    522
    Sweet South
    I just ran two threads on this stuff. Read down a couple of threads about jump start and buying a battery charger. Lots of good responses to my questions.
    Charles
  3. VDRZANE
    Jul 6, 2002
    386
    Ohio, Earth
    I've already read all of that stuff, thus my question.
  4. Possu
    Possu de-nOObed!
    Jan 9, 2004
    5,230
    Oxford, UK
    There should be no problem as long as the jump leads are connected securely & correctly. Also ensure that neither vehicle touches the other.
    Connect & diconect the leads in the correct order to prevent spark.
    Connect: red/positive first.
    Diconnect: black/negative first.
  5. iillyyaa
    iillyyaa Adwrenchurer!
    Jul 16, 2002
    2,423
    Littleton, MA
    It won't damage the bike, but it may damage you if the hood support collapses while you're hooking the cables to the car.
    I never heard a plausible explanation for why jump-starting a bike from a car could possibly damage the former. Both have ~12V charging systems; with revs up and a working alternator both develop in excess of 14V and are designed to do that. You're safe to do it.
    Ilya
  6. Loadedagain
    Loadedagain making chips
    Jan 1, 2003
    26,766
    West Vancouver, BC
    no problem at all. 12vdc is 12vdc. fly at er
  7. Guzz
    Guzz Gutless wonder
    Feb 15, 2002
    5,140
    Tempe AZ, USA
    I'm always leary of jump starting a bike from a car ever since I fried the electrical system on an OLD Suzuki GS550L. But I've learned my lesson and now understand the reason why you DON'T just go battery to battery.
    Remember you connect in this order:
    1. Dead Positive
    2. Good Positive
    3. Good Negative
    4. Dead FRAME
    Also, if you can get by with it (when jumping a bike from a car), don't start the car. Try to get by with just the car battery.
  8. Finglonga
    Finglonga I got a BUSTED leg!
    Apr 1, 2004
    206
    UKGSer Land
    ...and for feck's sake NEVER use the accesory socket.:eek1
    #8
  9. bmwmick
    bmwmick Old and Slow....Sorta
    Nov 27, 2003
    341
    Arizona, USA
    #9
  10. zouch
    zouch part-time wanderer
    Sep 17, 2002
    2,473
    berkeley, CA USA
    pshaw,... a starter system is only going to draw as much power as the starter requires, and that doesn't matter if it's from its own battery or another vehicles battery (through properly hooked up jumper cables). ideally, though, this should all be done without the 'donor' vehicle running.
    don't suppose we should even talk about having jump-started cars off of the GS here, now should we,...? :D
    (yes, i carry a set of jumper cables on the machine made up to fit into a plug that's hardwired to the battery for easier access... but i note that i've seen battery access points on some of the newer GSs since mine was built.)
    cheers!
    e
    #10
  11. Frank Warner
    Frank Warner Traveller
    Mar 14, 2002
    6,593
    Sydney, Australia
    Added my comment to
    http://www.advrider.com/forums/showthread.php?t=66146
    so as to keep them all in the same place. !!!!
    But here they are again.
    Car electrics have the same limits as bike electrics - running the car motor will only increase the car battery voltage - it will NOT damage the bike/other car if the jumping car is running!!!!!!!!!!!!!!!!!!!!!! In fact the increased voltage (over a non-running situation) will help make up for the voltage drop across the jumper leads.
    If you make the last connection the earthy lead (negative) somewheres away from the battery - earth strap to the motor is good - then you should be away from any battery gas. Similarly the disconnet should be done away from the battery. If you are using the starter motor terminal then that would be OK too.
    #11
  12. ysr612
    ysr612 Long timer
    Aug 7, 2003
    10,124
    Beaumont, texas
    the thing that I would worry about is the max charge rate of the bike batt as most cars are able to charge at 50 to 120 amps and most bike batts are not supposed to be fed current at over about 40 amps. or 10 amps over a longer time.
    #12
  13. xtphreak
    xtphreak from B4 "adventure bikes"
    Jul 21, 2004
    7,980
    Back-n-forth [GA & WNC]
    you're not charging the battery here, you're adding amperage to spin the starter on the bike
    the extra amperage will flow to the motor windings, that's where the lowest resistance is while you're starting the bike.
    there should be no problem with jumping the bike off a car battery if you connect / disconnect correctly.
    just like jumping another car.
    much adeiu over nothing
    ok I can't spell adeiu ... I ain't French thank Gawd
    #13
  14. Frank Warner
    Mar 14, 2002
    6,593
    Sydney, Australia
    Furphy.
    To get 40 amps into a bike battery you 'd be well over 15 volts ...
    If the bike battery is under say 11 volts you may be a current surge into the bike battery from the car battery - but that will be of short duration .. and the running of the motor will have little effect on the surge current magintude (most of that will come from the car battery!).
    #14
  15. TurnMonkey
    TurnMonkey Face
    Feb 7, 2004
    106
    Big Sky Country
    What's the deal about connecting, disconnecting properly? I've never worried about any order of connecting or disconnecting. Thrash away :evil
    I've never had a problem, 31 years of life and jumping cars, never a problem. I'm not a mechanic by profession, so I'm not challenging those that are. It's just I've never heard of an issue like this......
    I have jumped my pickup from my lawn mower, how redneck is that!!!! :rofl :rofl :rofl
    #15
  16. xtphreak
    Jul 21, 2004
    7,980
    the issue is a hydrogen explosion
    your battery produces hydrogen gas ... it's flammable / explosive
    making the final connection CAN cause a spark,
    which CAN cause a hydrogen explosion,
    which CAN fu-k up your day as battery plates and sulphuric acid go flying
    making the final connection (neg) on the motor / ground strap / alt bracket / etc gets the spark away from the battery and that nasty hydrogen gas
    I have seen it happen and hosed down the unfortunate who it popped on
    #16
  17. TurnMonkey
    TurnMonkey Face
    Feb 7, 2004
    106
    Big Sky Country
    I understand the explosive issue and the last connect to a ground source away from the battery, but there was a prev post that listed this:
    1. Dead Positive
    2. Good Positive
    3. Good Negative
    4. Dead FRAME
    I did not understand significance of steps 1-3.
    #17
  18. Frank Warner
    Mar 14, 2002
    6,593
    Sydney, Australia
    It should not be a problem if nothing goes wrong. If something does go wrong then steps 1 to 3 reduce/aviod the problem by providing a secondary safety barrier.
    1. Connect dead positive ; this has the lowest energy so is the least dangerous to have exposed on non connected end of the cable. Any spark should be small even if the exposed cable is connected to something.
    2. Connect good Positive ; removes the threat of step 1. No threat from any exposed ends as they are both connected.
    3. Good negiative ; Potential for sparking - if the other end of this cable is connect to something then this could spark - you want this connection away from the battery.
    #18
