Will Metal Box disrupt TPMS signal?
Discussion in 'GS Boxers' started by Longrider9, Aug 1, 2020.
  1. Longrider9
    Longrider9 Been here awhile
    Dec 30, 2015
    136
    ONTARIO, CANADA
    2014 GSW..my tpms has always activated quickly as I started riding.
    I now have a Cymark tool kit where my rear (plastic frame) pillion seat was.
    I’ve noticed that my tpms signal does not come on until I have ridden a few Kms.
    Coincidence???
    My rear will lose signal occasionally but usually comes back on later (suspect battery in rear is going weak).
    Could my metal Cymark toolbox be disrupting my tpms signal?
  2. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    If you're still with original TPMSs, their battery may be getting weaker and weaker thus the signal isn't transmitted faster...
    It's all frequency operated so it's unlikely that your toolbox is the culprit - ymmv...
  3. lewisjr1
    lewisjr1 Long timer Supporter
    Sep 26, 2008
    5,707
    DC metro
    Original tire sensors? If so it's more likely to be the batteries.
  4. Longrider9
    Dec 30, 2015
    136
    ONTARIO, CANADA
    Not original batteries. Front sensor is fine. Rear becomes intermittent and I'm replacing it with tire change.
    Both my sensors would read on dash within a few hundred feet of the bike moving.
    Now it takes about a mile or more for them to read on dash????
    I recently installed an Innovv K2 dual dash cam on the bike (control unit under seat in picture).
    Could this be causing a lag in my bike reading the tpms sensors??
  5. zeeklu
    zeeklu Adventurer
    Dec 6, 2003
    24
    Budd Lake, NJ
    I have the SW Motech rear seat plate on my 2014 and was having the same problems with my rear sensor. They replaced my rear TPMS sensor last Saturday and now it works fine. It's probably the same on your bike.
  6. Bluetooth Tuner
    Bluetooth Tuner Adventurer
    Sep 10, 2019
    63
    London
    The sensor will travel through plastic and foam seat easier than metal box, however the sensors are in the wheels so traveling upwards, and towards the TPMS box, so like most say looks like your batteries are getting to end of life, or sensor is faulty. :nod
  7. Longrider9
    Dec 30, 2015
    136
    ONTARIO, CANADA
    Took a ride today without the Cymark box on pillion seat area. Both sensors displayed on dash almost immediately as I began to move.
    With box on, both sensors take a few miles to show pressures on dash???? Not an issue as long as both sensors keep showing pressure.
    Replacing rear sensor (only 1 year old) and see what happens.
    Thank you all for your responses.
  8. JurgenB
    JurgenB daily rider
    Mar 11, 2007
    485
    Coloradio
    I have had similar issues on my 2014 after installing Clearwater Darlas and bunching excess wiring under the pillion seat. Also, batteries were getting weak. I replaced the rear sensor and rerouted the wires - that solved the problem.
    #8
    Bluetooth Tuner likes this.
